[OpenFOAM.org] Installation of ParaView 4.1.0 with OpenFOAM 2.3.0 on OpenSuse 13.2 |
November 24, 2014, 06:58 |
Hrushikesh Khadamkar
Rep Power: 15 |
I have successfully compiled OpenFOAM 2.3.0 on OpenSuse 13.2. However, I am unable to get paraview running. FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake Please see attached log file for the same. Can anyone help me with this error? |
November 24, 2014, 07:16 |
So, you've got rather wide range of solutions:
December 11, 2014, 17:49 |
OpenFOAM-2.3.1 and openSUSE 13.2
Rep Power: 14 |
i had compiled OpenFOAM-2.3.1 and ThirdParty-2.3.1 on openSUSE 13.2 just fine. Problem with compiling ParaView is gone. Note that i used guide from: http://openfoamwiki.net/index.php/In...#openSUSE_12.3 -Ondra |
December 13, 2014, 08:35 |
#4 | |
Rep Power: 15 |
However I installed paraview versioon 4.2.0 from OpenSUSE repository.Then I added following alias command in my ~/.bashrc file which was given at HTML Code:
https://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-2.3.0 Code:
alias paraFoam='paraFoam -builtin' |
December 14, 2014, 12:10 |
#5 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings to all!
@elones: Quote:
sed -i -e 's=//#define GLX_GLXEXT_LEGACY=#define GLX_GLXEXT_LEGACY=' \ ParaView-4.1.0/VTK/Rendering/OpenGL/vtkXOpenGLRenderWindow.cxx On a side note: I'm currently writing detailed instructions on how to build OpenFOAM 2.3.0 on openSUSE 13.2, which are being written here: http://openfoamwiki.net/index.php/In...#openSUSE_13.2 - as soon as I manage to complete writing them, I'll update this post. edit: Finished writing and testing the instructions on a 64-bit virtual machine with openSUSE 13.2. If anyone can test on 32-bit, it would be helpful! Best regards, Bruno
Last edited by wyldckat; December 14, 2014 at 14:46. Reason: added Alexey to the thanks + see "edit:" |
January 28, 2015, 07:56 |
Brugiere Olivier
Rep Power: 17 |
Greetings to all,
I've tried to install Openfoam v2.3.1 on opensuse 13.1. I've already install 2.2.2 without problems but now I can not build ptscotch. I've some problems : '/usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lmpi collect2: error: ld returned 1 exit status' I've used the guide. I think it's a problem with my openmpi version : mpirun --version mpirun (Open MPI) 1.7.2 Thanks to your help Best regards Olivier |
January 28, 2015, 15:13 |
Bruno Santos
Rep Power: 128 |
Greetings Olivier,
A few questions:
Bruno
January 29, 2015, 02:44 |
Brugiere Olivier
Rep Power: 17 |
Greetings Bruno,
I've already installed Openfoam 2.2.2 and I've used this version with other Openfoam 2.3.0. But I've made some modifications on my compter and now I can not compile Openfoam 2.3.0 and 2.3.1. I've a problem with ptscotch library. I can used OpenFoam but not SnappyHexMesh in parallel. So if you have some tips... Best regards Olivier |
January 29, 2015, 05:13 |
#9 |
Brugiere Olivier
Rep Power: 17 |
Hi all,
I've upgraded my opensuse 13.1 to 13.2 and I think it will work. Best regards Olivier |
January 29, 2015, 15:39 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Olivier,
I hope upgrading to openSUSE 13.2 works for you. If not, without more specific information, my best tip based on a guess is what I already indicated: http://openfoamwiki.net/index.php/In...nFOAM_versions Best regards, Bruno |
February 4, 2015, 10:08 |
#11 |
Giovanni Caramia
Rep Power: 17 |
I successfully installed version 2.3.1 on opensuse 13.2 following the instruction on
http://openfoamwiki.net/index.php/In...#openSUSE_13.2 the only thing I had to do (not indicated) was to make these two link: Code:
ln -s /usr/lib64/libGL.so.1 /usr/lib64/libGL.so (because of nvidia driver installation) ln -s /usr/lib64/mpi/gcc/openmpi/lib64/libmpi.so.1 /usr/lib64/libmpi.so.1 Code:
icoFoam -help icoFoam: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory ldd $(which icoFoam) linux-vdso.so.1 (0x00007fff25374000) libfiniteVolume.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libfiniteVolume.so (0x00007f39242ee000) libsampling.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libsampling.so (0x00007f3923db1000) libOpenFOAM.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libOpenFOAM.so (0x00007f392346a000) libdl.so.2 => /lib64/libdl.so.2 (0x00007f392323e000) libstdc++.so.6 => /home/caramia/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/CGAL-4.3/lib/libstdc++.so.6 (0x00007f3922f36000) libm.so.6 => /lib64/libm.so.6 (0x00007f3922c35000) libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f3922a1d000) libc.so.6 => /lib64/libc.so.6 (0x00007f3922675000) libPstream.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/openmpi-system/libPstream.so (0x00007f3922467000) libtriSurface.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libtriSurface.so (0x00007f39221d2000) libmeshTools.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libmeshTools.so (0x00007f3921c20000) libsurfMesh.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libsurfMesh.so (0x00007f3921923000) libfileFormats.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libfileFormats.so (0x00007f39216a8000) liblagrangian.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/liblagrangian.so (0x00007f3921489000) libconversion.so => /home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/libconversion.so (0x00007f392120e000) libz.so.1 => /lib64/libz.so.1 (0x00007f3920ff8000) /lib64/ld-linux-x86-64.so.2 (0x00007f39257a5000) libmpi.so.1 => not found libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f3920dda000) echo $MPI_ARCH_PATH /usr echo $WM_MPLIB SYSTEMOPENMPI echo $LD_LIBRARY_PATH | tr -s ' ' '\n' /home/caramia/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/CGAL-4.3/lib:/home/caramia/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/gperftools-svn/lib:/home/caramia/OpenFOAM/ThirdParty-2.3.1/platforms/linux64Gcc/ParaView-4.1.0/lib/paraview-4.1:/home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/openmpi-system:/home/caramia/OpenFOAM/ThirdParty-2.3.1/platforms/linux64GccDPOpt/lib/openmpi-system:/usr/lib64:/home/caramia/OpenFOAM/caramia-2.3.1/platforms/linux64GccDPOpt/lib:/home/caramia/OpenFOAM/site/2.3.1/platforms/linux64GccDPOpt/lib:/home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib:/home/caramia/OpenFOAM/ThirdParty-2.3.1/platforms/linux64GccDPOpt/lib:/home/caramia/OpenFOAM/OpenFOAM-2.3.1/platforms/linux64GccDPOpt/lib/dummy Last edited by wyldckat; February 4, 2015 at 14:41. Reason: Added [CODE][/CODE] |
February 4, 2015, 13:56 |
#12 |
Giovanni Caramia
Rep Power: 17 |
I am sorry but the link
--> FOAM FATAL ERROR: bool IPstream::init(int& argc, char**& argv) : attempt to run parallel on 1 processor Thank you. Last edited by wyldckat; February 4, 2015 at 14:42. Reason: Added [CODE][/CODE] |
February 4, 2015, 14:50 |
#13 | |
Bruno Santos
Rep Power: 128 |
Greetings Giovanni,
Bruno
Last edited by wyldckat; February 5, 2015 at 15:12. Reason: see "edit:" in point #4 |
February 5, 2015, 03:13 |
#14 |
Giovanni Caramia
Rep Power: 17 |
Hi Bruno!
Thank you for the quick response. Everything works after sourcing /etc/profile.d/mpi-selector.sh. Thank you very much!! |
March 13, 2015, 03:40 |
plz help
#15 |
behrouz
Rep Power: 11 |
hi everyone
i installed openFOAM-2.3.1 on opensuse 13.2 and i try to run cavity(in tutorials) so when i type 'paraFoam' in terminal the error occured az below: FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers ./Allwclean ./Allwmake so im lost!!! i search for solution in sevral pages but i just confused!! note:im a beginner and am just start linux,so plz answer very simple, thanks |
March 14, 2015, 06:21 |
#16 |
Bruno Santos
Rep Power: 128 |
Greetings behrouz and welcome to the forum!
It would help if you had detailed which installation instructions you have followed. Without knowing which instructions you followed, then I suggest you try following these instructions: http://openfoamwiki.net/index.php/In...#openSUSE_13.2 You could also try running: Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers wmSET $FOAM_SETTINGS ./Allwclean ./Allwmake If it does not solve the problem, then please do detail which installation instructions you have followed. Best regards, Bruno
March 14, 2015, 08:48 |
#17 |
behrouz
Rep Power: 11 |
Dear Bruno Santos
first of all: Thanks a lot for your reply second of all: I will test your code and sahre result with you |
March 14, 2015, 12:59 |
#18 |
behrouz
Rep Power: 11 |
Dear dear Bruno Santos
your guide work,and my problem solved. THANKS A LOT my friend <3 |
May 27, 2015, 10:54 |
#19 |
stephane sanchi
Rep Power: 18 |
Dear OF-users,
These days I successfully installed OpenFOAM-2.4 on openSUSE-13.2. At the beginning I had problem in compiling preview-4.1. Then, thanks to B. Santos, I followed the step 13 (see below link) and it compiled without trouble. http://openfoamwiki.net/index.php/In...#openSUSE_13.2 Regards, Stéphane. |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case | romant | ParaView | 3 | April 7, 2014 15:42 |
New OpenFOAM Forum Structure | jola | OpenFOAM | 2 | October 19, 2011 06:55 |
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 | aero_ | ParaView | 14 | August 2, 2010 18:13 |
