Paraview 4 with Redhat...is it possible?
Like Tree5Likes
Old   February 21, 2014, 09:05
Unhappy Paraview 4 with Redhat...is it possible?
ferdinando.forno is on a distinguished road
Hi to all,
I'm trying to build paraview with the command
./makeParaView4
but I obtain this warning:
sed: can't read /openfoam/ThirdParty-2.3.0/ParaView-4.1.0/VTK/Utilities/kwsys/kwsysDateStamp.cmake: No such file or directory
and then:
Version information
    qt        4.8.5
    version   4.1.0
    major     4.1
MISMATCH!
    specified 4.1.0
    found
but, more importat, I get these errors:
[ 84%] Generating moc_pqProxy.cxx
/openfoam/ThirdParty-2.3.0/build/linux64Gcc/ParaView-4.1.0/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QListData::detach_grow(int*, int)'
/openfoam/ThirdParty-2.3.0/build/linux64Gcc/ParaView-4.1.0/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QListData::detach(int)'
/openfoam/ThirdParty-2.3.0/build/linux64Gcc/ParaView-4.1.0/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QAbstractProxyModel::setItemData(QModelIndex const&, QMap<int, QVariant> const&)'
collect2: error: ld returned 1 exit status
make[2]: *** [bin/pvserver] Error 1
make[1]: *** [CommandLineExecutables/CMakeFiles/pvserver.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
Scanning dependencies of target PacMan
[ 84%] [ 84%] Building CXX object CoProcessing/Catalyst/CMakeFiles/vtkPVCatalyst.dir/vtkCPInputDataDescription.cxx.o
Generating moc_pqQVTKWidgetEventTranslator.cxx
[ 84%] Building CXX object Plugins/TestPlugin/CMakeFiles/PacMan.dir/PacMan_Plugin.cxx.o
[ 84%] /openfoam/ThirdParty-2.3.0/build/linux64Gcc/ParaView-4.1.0/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QListData::detach_grow(int*, int)'
make[2]: *** [bin/pvrenderserver] Error 1
make[1]: *** [CommandLineExecutables/CMakeFiles/pvrenderserver.dir/all] Error 2
Generating moc_pqQVTKWidget.cxx
[ 84%] Building CXX object CoProcessing/Catalyst/CMakeFiles/vtkPVCatalyst.dir/vtkCPPipeline.cxx.o
[ 84%] Generating moc_pqRecentlyUsedResourcesList.cxx
[ 84%] Generating moc_pqRenderViewBase.cxx
[ 84%] Generating moc_pqRenderView.cxx
[ 84%] Generating moc_pqRepresentation.cxx
[ 84%] [ 84%] Building CXX object CoProcessing/Catalyst/CMakeFiles/vtkPVCatalyst.dir/vtkCPProcessor.cxx.o
Generating moc_pqRubberBandHelper.cxx
[ 84%] Generating moc_pqScalarBarRepresentation.cxx
Scanning dependencies of target NonOrthogonalSource
[ 84%] [ 84%] Generating moc_pqScalarBarVisibilityAdaptor.cxx
Building CXX object Plugins/NonOrthogonalSource/CMakeFiles/NonOrthogonalSource.dir/vtkShearedCubeSource.cxx.o
[ 84%] Generating moc_pqScalarOpacityFunction.cxx
make[2]: *** [bin/pvdataserver] Error 1
Building CXX object Plugins/NonOrthogonalSource/CMakeFiles/NonOrthogonalSource.dir/vtkShearedCubeSourceClientServer.cxx.o
make[1]: *** [CommandLineExecutables/CMakeFiles/pvdataserver.dir/all] Error 2
I have installed qt version 4.8.5.
How do I fix it?
Is it possible?
Thanks in advance.
ferdinando.forno is offline   Reply With Quote
Old   February 22, 2014, 14:46
Retired Super Moderator
Bruno Santos
Greetings ferdinando.forno,
I haven't tried this myself, but it should be possible.
Have a look into this wiki page for ideas: http://openfoamwiki.net/index.php/In...HEL#CentOS_5.8 - section CentOS 5.8, steps 12 and 13.
Best regards,
Bruno
Old   February 24, 2014, 05:49
Hi Bruno,
if I am right the link you have posted is about ParaView 3.12.0. I have tried to modify instructions for ParaView 4.1 with no luck. Other suggestions?
Best regards,
Ferdinando Forno
EDIT:
Even if I try to build paraview from source, process fails.
I installed QT 4.8.5, indeed:
$ qmake --version
QMake version 2.01a
Using Qt version 4.8.5 in /usr/local/Trolltech/Qt-4.8.5/lib
I ever have problems with libvtkGUISupportqt:
/openfoam/Software/ParaView-v4.1.0/ParaView-build/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QMetaType::registerTypedef(char const*, int)'
/openfoam/Software/ParaView-v4.1.0/ParaView-build/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QListData::detach(int)'
/openfoam/Software/ParaView-v4.1.0/ParaView-build/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QAbstractProxyModel::setItemData(QModelIndex const&, QMap<int, QVariant> const&)'
/openfoam/Software/ParaView-v4.1.0/ParaView-build/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QListData::detach_grow(int*, int)'
make[2]: *** [bin/SciberQuestToolKit-TestBOVIO] Error 1
make[1]: *** [Plugins/SciberQuestToolKit/SciberQuest/Testing/CMakeFiles/SciberQuestToolKit-TestBOVIO.dir/all] Error 2
Best regards,
Bruno
Old   March 1, 2014, 18:46
Bruno Santos
Hi Ferdinando,
I've finished writing and testing the following instructions on CentOS 6.5: http://openfoamwiki.net/index.php/In...HEL#CentOS_6.5
So it should work on RHEL 6.5 as well.
I didn't try to use Qt 4.8.5, because at that time I forgot that there was already 4.8.5, so I went with 4.8.4.
Let me know if it works for your or if you're using another version of RHEL.
Best regards,
Bruno
Old   March 3, 2014, 06:21
Hi bruno,
I'm trying to follow your guide even if I have RHEL 6.3.
I have a problem with step nine:
./getGcc gcc-4.8.1 gmp-5.1.2 mpfr-3.1.2 mpc-1.0.1
downloading gmp-5.1.2.tar.bz2 from ftp://ftp.gnu.org/gnu/gmp/gmp-5.1.2.tar.bz2
--2014-03-03 12:07:02--  ftp://ftp.gnu.org/gnu/gmp/gmp-5.1.2.tar.bz2
           => “gmp-5.1.2.tar.bz2”
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:3128... failed: Connection refused.
Connecting to localhost|127.0.0.1|:3128... connected.
Logging in as anonymous ...
RHEL machine is under proxy (pc at office), could this be a problem?
Thanks in advance.
Best regards,
Ferdinando
Hi Ferdinando,
Best regards,
Bruno
Old   March 3, 2014, 07:13
Bruno Santos
Hi Ferdinando,
Then you'll need to download the files manually. When you run the getGcc script, it tells you which files it tries to download, for example:
Download the file:
manually and place it inside the folder "download", which should be located inside the "ThirdParty-2.3.0" folder.
If the script locks up trying to download a file, use Ctrl+C, download the file manually and place the file inside the folder mentioned above. Then run the script again and it will ask for another file, since the other one is already done.
Best regards,
Bruno
Old   March 4, 2014, 04:42
Hi bruno,
I wish to thank you. I have successfully built those packages.
Now I have another problem with ./makeCmake (point 12 of the installation guide).
I got this error:
Linking CXX executable ../bin/ccmake
/opt/centos/devtoolset-1.0/root/usr/libexec/gcc/x86_64-redhat-linux/4.7.0/ld: CMakeFiles/ccmake.dir/CursesDialog/cmCursesMainForm.cxx.o: undefined reference to symbol 'keypad'
/opt/centos/devtoolset-1.0/root/usr/libexec/gcc/x86_64-redhat-linux/4.7.0/ld: note: 'keypad' is defined in DSO /lib64/libtinfo.so.5 so try adding it to the linker command line
/lib64/libtinfo.so.5: could not read symbols: Invalid operation
or this one
/openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/lib/gcc/x86_64-unknown-linux-gnu/4.8.1/../../../../x86_64-unknown-linux-gnu/bin/ld: CMakeFiles/ccmake.dir/CursesDialog/cmCursesMainForm.cxx.o: undefined reference to symbol 'keypad'
/openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/lib/gcc/x86_64-unknown-linux-gnu/4.8.1/../../../../x86_64-unknown-linux-gnu/bin/ld: note: 'keypad' is defined in DSO /lib64/libtinfo.so.5 so try adding it to the linker command line
make[2]: *** [bin/ccmake] Error 1
make[1]: *** [Source/CMakeFiles/ccmake.dir/all] Error 2
depending on gcc version. How can I resolve?
Thanks in advance.
Best regards,
Ferdinando Forno
Hi Ferdinando,
Download the file:
Best regards,
Bruno
Old   March 4, 2014, 05:21
Bruno Santos
Hi Ferdinando,
I did a quick search online and the problem seems to be related to the GCC version used.
You can use the default GCC installation that RHEL has got, for building CMake and it should work as intended. To do so, run:
export CC=/usr/bin/gcc
export CXX=/usr/bin/g++
./makeCmake
Best regards,
Bruno
Old   March 4, 2014, 07:43
Hi Bruno,
thanks for you constant support.
I have tried with your export commands but it gives me that error again (log attached)
Any hints?
Thanks in advance,
Ferdinando Forno
Hi Ferdinando,
./makeCmake
Best regards,
Bruno
Old   March 4, 2014, 08:17
Bruno Santos
Sorry, I forgot about ld:
export LD=/usr/bin/ld
./makeCmake
Old   March 4, 2014, 08:53
Hi Bruno,
even with these command, I get that error
I think It switches to thirdParty compiler during building.
In the attached log you can see:
-- The C compiler identification is GNU 4.8.1
-- The CXX compiler identification is GNU 4.8.1
-- Check for working C compiler: /openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/bin/gcc
-- Check for working C compiler: /openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/bin/g++
-- Check for working CXX compiler: /openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/bin/g++ -- works
Is it normal?
Thanks.
Best regards,
Ferdinando
./makeCmake
Old   March 4, 2014, 09:22
Bruno Santos
Sorry again, I should have checked the contents of the script "makeCmake". The script has these two lines:
[ -n "$WM_CXX" ] && export CXX="$WM_CXX"
[ -n "$WM_CC" ] && export CC="$WM_CC"
Either comment out those two lines inside the script, or run:
export WM_CXX=$CXX
export WM_CC=$CC
./makeCmake
Old   March 4, 2014, 10:15
I have commented out those line and I have run
export WM_CXX=$CXX
export WM_CC=$CC
./makeCmake
but during gmake compiling software returns to use ThirdParty compilers:
Building CXX object Source/CMakeFiles/CTestLib.dir/CTest/cmCTestMemCheckCommand.cxx.o
/openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/bin/ld: CMakeFiles/ccmake.dir/CursesDialog/cmCursesMainForm.cxx.o: undefined reference to symbol 'keypad'
/openfoam/ThirdParty-2.3.0/platforms/linux64/gcc-4.8.1/bin/ld: note: 'keypad' is defined in DSO /lib64/libtinfo.so.5 so try adding it to the linker command line
collect2: ld returned 1 exit status
while in the beginning it compiles with /usr/bin/gcc-g++-ld:
Starting build: cmake-2.8.12.1
CMake 2.8.12.1, Copyright 2000-2012 Kitware, Inc.
C compiler on this system is: /usr/bin/gcc
C++ compiler on this system is: /usr/bin/g++
Makefile processor on this system is: gmake
/usr/bin/g++ is GNU compiler
I have attached compiling log.
Best regards,
Ferdinando Forno
export WM_CXX=$CXX
export WM_CC=$CC
./makeCmake
Old   March 4, 2014, 10:33
Bruno Santos
Sometimes things will only work if we use a crowbar
Try this:
mv $WM_THIRD_PARTY_DIR/platforms/linux64/gcc-4.8.1 $WM_THIRD_PARTY_DIR/platforms/linux64/gcc-4.8.1.bak
./makeCmake
mv $WM_THIRD_PARTY_DIR/platforms/linux64/gcc-4.8.1.bak $WM_THIRD_PARTY_DIR/platforms/linux64/gcc-4.8.1
This way it will not pick-up the "ld" that was built into gcc-4.8.1, which was built with makeBinutils.
Old   March 4, 2014, 10:55
I have no luck:
/opt/centos/devtoolset-1.0/root/usr/bin/ld: CMakeFiles/ccmake.dir/CursesDialog/cmCursesMainForm.cxx.o: undefined reference to symbol 'keypad'
/opt/centos/devtoolset-1.0/root/usr/bin/ld: note: 'keypad' is defined in DSO /lib64/libtinfo.so.5 so try adding it to the linker command line
I'm thinking about to use TNT instead of a crowbar.
What is wrong with RHEL?
Try this:
./makeCmake
Old   March 4, 2014, 11:16
Bruno Santos
Ah, I don't know how exactly you're loading "devtoolset-1.0" into the shell environment, but make sure that you start a new shell environment without it.
This is because that toolset also uses a more recent GCC+Binutils versions, which is breaking the build with CMake
Old   March 4, 2014, 11:53
Hi Bruno,
even with compilers installed Paraview doesn't build.
[openfoam@danbtopenfoam ~]$ OF230
[openfoam@danbtopenfoam ~]$ gcc --version
gcc (OpenFOAM) 4.8.1
Copyright (C) 2013 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
[openfoam@danbtopenfoam ~]$ g++ --version
g++ (OpenFOAM) 4.8.1
[openfoam@danbtopenfoam ~]$ ld --version
GNU ld (GNU Binutils) 2.23
Copyright 2012 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) a later version.
This program has absolutely no warranty.
[openfoam@danbtopenfoam ~]$ cmake --version
cmake version 2.8.12.1
[openfoam@danbtopenfoam ~]$ qmake --version
QMake version 2.01a
It gives me this error:
[ 84%] /openfoam/ThirdParty-2.3.0/build/linux64Gcc48/ParaView-4.1.0/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QListData::detach_grow(int*, int)'
/openfoam/ThirdParty-2.3.0/build/linux64Gcc48/ParaView-4.1.0/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QListData::detach(int)'
/openfoam/ThirdParty-2.3.0/build/linux64Gcc48/ParaView-4.1.0/lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QAbstractProxyModel::setItemData(QModelIndex const&, QMap<int, QVariant> const&)'
[ 84%] make[2]: *** [bin/pvserver] Error 1
Generating Documentation HTMLs from xmls
[ 84%] Generating moc_pqServerConfigurationCollection.cxx
Generating moc_pqServer.cxx
/openfoam/ThirdParty-2.3.0/build/linux64Gcc48/ParaView-4.1.0/mak/*** [bin/pvdataser-
/openfoam/ThirdParty-2.3.0/build/linux64Gcc48/ParaViewm4.1.0*lib/libvtkGUISupportQt-pv4.1.so.1: undefined reference to `QAbstractProxyModel::setItemData(QModelIndex const&, QMap<int, QVariant> const&)'
I have attached complete log.
Any suggestions?
Thanks in advance.
Best regards,
Ferdinando Forno
Hi bruno,
finally I have compiled cmake removing devtoolset-1.0 from PATH.
Now I'm trying to compile Paraview with
./makeParaView4 PARAVIEW_INSTALL_THIRD_PARTY_LIBRARIES:BOOL=ON
We'll see if it will work.
Thanks for all.
Best regards,
Ferdinando
Old   March 5, 2014, 11:03
Default qt4 compilation problem
  #18
dfeid is on a distinguished road
I went through what is described here and webpage "Installation/Linux/OpenFOAM-2.3.0/CentOS SL RHEL", but I firstly faced problem with CGAL compilation.
I believe that I overcame this barrier following the instruction from http://www.openfoam.org/download/source.php but I am not sure since I am not familiar with Linux OS
At the continue, I received error from the qt4.8.4 compilation.
Attached you may find the log file from the qt compilation
I 'd appreciate any help on this matter
Thanks in advance
dfeid is offline   Reply With Quote
Old   March 5, 2014, 15:09
Bruno Santos
Greetings dfeid,
That's a strange error message you've gotten in the log file.
A few questions:
  1. Which Linux Distribution are you using and in which architecture?
  2. What do these commands give you?
    gcc --version
    g++ --version
    ld --version
    cmake --version
  3. As for the problem with CGAL, it would be useful to know what exact error you've gotten and what did you exactly do to repair it.
Keep in mind that the instructions were designed to be followed to the letter. If you miss one single command, or even just one letter, whichever one it is, it's likely to fail building the necessary packages .
Best regards,
Bruno
Old   March 5, 2014, 16:06
Dear Bruno
First of all thanks for your prompt answer
Going at the row of your questions
1. I am using CentOS 6.5 x86_64 Linux distribution
2. The version of the tools is given below:
[Dimitris@CFD13 ~]$ of230
[Dimitris@CFD13 ~]$ gcc --version
[Dimitris@CFD13 ~]$ g++ --version
[Dimitris@CFD13 ~]$ ld --version
[Dimitris@CFD13 ~]$ cmake --version
3. Regarding with the problem with the CGAL I attach the log file recorded after the first unsuccessful try (I assume that you will you help somehow)
Because I didn't managed to get a solution with this.
I decided to install the binary files following the step 1 from the Source Pack Installation of OpenFOAM webpage giving the followings:
yum-config-manager --nogpgcheck --add-repo http://dl.atrpms.net/el6-x86_64/atrpms/stable
yum install --nogpgcheck qtwebkit qtwebkit-devel
yum install --nogpgcheck CGAL CGAL-devel
But, as I wrote before, I am not familiar with Linux OS and I don't know if it works
I hope with my writings that you could be able to have a view of the situation
Thanks again
Best regards
Dimitris
paraview, qmake, rhel6
Installing OpenFOAM and ParaView in VirtualBox(Ubuntu on Win8) chrisb2244 OpenFOAM Installation 2 August 21, 2013 13:24
Newbie: Install ParaView 3.81 on OF-1.6-ext/OpenSuse 11.2? lentschi OpenFOAM Installation 1 March 9, 2011 02:32
paraFoam reader for OpenFOAM 1.6 smart OpenFOAM Installation 13 November 16, 2009 21:41
Building Paraview, Redhat PaulK OpenFOAM Installation 6 October 12, 2009 13:01
[OpenFOAM] Both paraview and paraFoam crash on Redhat Linux WS v4 64bit sek ParaView 4 August 17, 2006 16:26
