Problem compiling Paraview (Thirdparty)
Old   October 7, 2013, 16:48
Default Problem compiling Paraview (Thirdparty)
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
I try to compile paraview-3.12.0 which comes with the thirdparty.
While compilation I get the following error message:
-- Configuring development install...
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
OPENGL_gl_LIBRARY (ADVANCED)
    linked by target "vtkVolumeRendering" in directory /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/VTK/VolumeRendering
    linked by target "vtkWidgets" in directory /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/VTK/Widgets
    linked by target "vtkParallel" in directory /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/VTK/Parallel
    linked by target "vtkPVVTKExtensions" in directory /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/ParaViewCore/VTKExtensions
    linked by target "PointSprite_Rendering" in directory /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/ParaView-3.12.0/Plugins/PointSprite/Rendering
-- Configuring incomplete, errors occurred!
Here is the first error I got in the logfile:
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/platforms/linux64/gcc-4.7.2/bin/gcc
-- Check for working C compiler: /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/platforms/linux64/gcc-4.7.2/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/platforms/linux64/gcc-4.7.2/bin/g++
-- Check for working CXX compiler: /home/shor-ty/OpenFOAM/ThirdParty-2.2.x/platforms/linux64/gcc-4.7.2/bin/g++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Found Git: /usr/bin/git
-- Determined Source Version from file : 3.12.0
-- Looking for Q_WS_X11
-- Looking for Q_WS_X11 - found
-- Looking for Q_WS_WIN
-- Looking for Q_WS_WIN - not found.
-- Looking for Q_WS_QWS
-- Looking for Q_WS_QWS - not found.
-- Looking for Q_WS_MAC
-- Looking for Q_WS_MAC - not found.
-- Found Qt4: /usr/bin/qmake (found suitable version "4.8.1", required is "4.6.0")
CMake Warning at CMakeLists.txt:110 (MESSAGE):
  Warning: You are using Qt 4.8.1.  Officially supported version is Qt 4.6
Thanks in advance
Tobi
Tobi is offline   Reply With Quote
Old   October 11, 2013, 18:30
Retired Super Moderator
Bruno Santos
Hi Tobi,
I don't know if you've already fixed this problem or not, but if not, I'm able to give a better suggestion/solution/fix if I knew which Linux Distribution and version you are using in this case
In addition, are you certain that you've already installed the correct graphics card drivers?
Best regards,
Bruno
Old   April 8, 2014, 15:21
johny
johny is on a distinguished road
Hi Bruno,
Could you please help me out? I've the same problem as Tobi. Error messages are appended to this mail.
My linux version is
:~$ lsb_release -a
No LSB modules are available.
Distributor ID:    Ubuntu
Description:    Ubuntu Trusty Tahr (development branch)
Release:    14.04
Codename:    trusty
How do I know whether I've the right video drivers. Invoking the command
:~$ lshw -c video
WARNING: you should run this program as super-user.
  *-display
       description: VGA compatible controller
       product: G96 [GeForce 9500 GT]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=nouveau latency=0
       resources: irq:43 memory:fd000000-fdffffff memory:e0000000-efffffff memory:fa000000-fbffffff ioport:cc00(size=128) memory:fea80000-feafffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Cheers,
J
    linked by target "vtkVolumeRendering" in directory /home/rinoy/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/VTK/VolumeRendering
    linked by target "vtkWidgets" in directory /home/rinoy/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/VTK/Widgets
    linked by target "vtkParallel" in directory /home/rinoy/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/VTK/Parallel
    linked by target "vtkPVVTKExtensions" in directory /home/rinoy/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/ParaViewCore/VTKExtensions
    linked by target "PointSprite_Rendering" in directory /home/rinoy/OpenFOAM/ThirdParty-2.2.0/ParaView-3.12.0/Plugins/PointSprite/Rendering
    Starting make
make: *** No targets specified and no makefile found.  Stop.
Command exited with non-zero status 2
0.00user 0.00system 0:00.00elapsed 75%CPU (0avgtext+0avgdata 1048maxresident)k
0inputs+0outputs (0major+314minor)pagefaults 0swaps
    Done make
    Installing ParaView to /home/rinoy/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc45/paraview-3.12.0
make: *** No rule to make target `install'.  Stop.
    Installation complete for paraview-3.12.0
    Set environment variables:
        export ParaView_DIR=/home/rinoy/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc45/paraview-3.12.0
        export PATH=$ParaView_DIR/bin:$PATH
        export PV_PLUGIN_PATH=$FOAM_LIBBIN/paraview-3.12
Done
Originally Posted by wyldckat View Post
Hi Tobi,
Best regards,
Bruno
johny is offline   Reply With Quote
Old   April 8, 2014, 15:41
Bruno Santos
Greetings Johny,
You're using the Nouveau drivers, which are open source. I don't know how good they are nowadays, but my suggestion is that you install the NVidia drivers (not open source ), which officially support 3D performance with NVidia graphics cards.
After you've managed to install the NVidia drivers, the makeParaView or makeParaView4 scripts should work as intended.
Best regards,
Bruno
Old   April 10, 2014, 12:43
johny
Hi Bruno,
Thanks for the reply. Its getting more confusing when it comes to find the right driver for my computer. Could you please let me know which one is the right NVIDIA driver for my processor and version of ubuntu. And if you direct me where to find it would also be great help.
~$ lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation G96 [GeForce 9500 GT] (rev a1)
~$ lsb_release -a
Release: 14.04
Codename: trusty
Looking forward to your reply.
Cheers,
J
Greetings Johny,
Best regards,
Bruno
Old   April 10, 2014, 16:10
Bruno Santos
Hi Johny,
Ubuntu 14.04 is still in beta stage, so it's probably not yet very stable.
But anyway, this page should explain how to install the official NVidia drivers for Ubuntu: http://askubuntu.com/a/307478
The actual driver model needed for your card should automatically be installed this way.
Best regards,
Bruno
Old   April 11, 2014, 05:25
johny
Hi Bruno,
Thanks again for the quick reply. It was pretty difficult to still get the drivers installed and as you said I thought it would be a better idea to start do do the whole process in a new installation.
I installed the new stable version of ubuntu
:~$ lsb-release -a
No command 'lsb-release' found, did you mean:
 Command 'lsb_release' from package 'lsb-release' (main)
lsb-release: command not found
rinoy@bryan:~$ lsb_release -a
Description:    Ubuntu 13.10
Release:    13.10
Codename:    saucy
Installed the nvidia drivers picking up the instruction from the link you provided
~$ lshw -c video
  *-display
       physical id: 0
       version: a1
       width: 64 bits
       clock: 33MHz
       configuration: driver=nvidia latency=0
       resources: irq:16 memory:fd000000-fdffffff memory:e0000000-efffffff memory:fa000000-fbffffff ioport:cc00(size=128) memory:fea80000-feafffff
Now I was following the instructions in the link below to install OpenFOAM
http://openfoamwiki.net/index.php/In...M-2.2.0/Ubuntu
After completing the step 8 with the command
wmSET $FOAM_SETTINGS
I still get the error as below
Warning in /home/user/OpenFOAM/OpenFOAM-2.2.0/etc/config/settings.sh:
    Cannot find /home/user/OpenFOAM/ThirdParty-2.2.0/platforms/linux64/gcc-4.5.2 installation.
    Please install this compiler version or if you wish to use the system compiler,
    change the 'foamCompiler' setting to 'system'
I found the gcc-4.5.2 was located in the folder /home/user/OpenFOAM/ThirdParty-2.2.0/ INSTEAD OF /home/user/OpenFOAM/ThirdParty-2.2.0/platforms/linux64/
I moved the gcc-4.5.2 to /home/user/OpenFOAM/ThirdParty-2.2.0/platforms/linux64/
And then as expected there was no error and continued till building the openFOAM without any issues.
The build log has errors(seeming due to the change I made above) as follows...
 ollect2: error: ld returned 1 exit status
make[2]: *** [/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/bin/MRFMultiphaseInterFoam] Error 1
make[1]: *** [multiphaseInterFoam] Error 2
/home/rinoy/OpenFOAM/ThirdParty-2.2.0/platforms/linux64/gcc-4.5.2/bin/ld: this linker was not configured to use sysroots
collect2: error: ld returned 1 exit status
make[2]: *** [/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/bin/twoLiquidMixingFoam] Error 1
make[1]: *** [twoLiquidMixingFoam] Error 2
+ wmake libso phaseModel
make[2]: *** [/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/lib/libphaseModel.so] Error 1
make[2]: Target `libso' not remade because of errors.
+ wmake libso interfacialModels
make[2]: *** [/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/lib/libEulerianInterfacialModels.so] Error 1
+ wmake libso kineticTheoryModels
make[2]: *** [/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/lib/libkineticTheoryModel.so] Error 1
+ wmake
g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-100 -I/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/src/finiteVolume/lnInclude -I/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/src/transportModels/incompressible/lnInclude -IturbulenceModel -IkineticTheoryModels/lnInclude -IinterfacialModels/lnInclude -IphaseModel/lnInclude -Iaveraging -IlnInclude -I. -I/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/src/OpenFOAM/lnInclude -I/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/src/OSspecific/POSIX/lnInclude   -fPIC -Xlinker --add-needed -Xlinker --no-as-needed Make/linux64Gcc45DPOpt/twoPhaseEulerFoam.o -L/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/lib \
             -lEulerianInterfacialModels -lfiniteVolume -lmeshTools -lincompressibleTransportModels -lphaseModel -lkineticTheoryModel -lOpenFOAM -ldl   -lm -o /home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/bin/twoPhaseEulerFoam
make[2]: *** [/home/rinoy/OpenFOAM/OpenFOAM-2.2.0/platforms/linux64Gcc45DPOpt/bin/twoPhaseEulerFoam] Error 1
make[1]: *** [twoPhaseEulerFoam] Error 2
make[1]: Target `application' not remade because of errors.
make: *** [multiphase] Error 2
make: Target `application' not remade because of errors.
Could you please tell me how to proceed now?
Cheers,
J
Hi Johny,
Best regards,
Bruno
Old   April 13, 2014, 15:32
Bruno Santos
Hi Johny,
I'm glad the NVidia drivers have been installed with success. But I think you got lost in the instructions for installing OpenFOAM, because:
  1. You're using Ubuntu 13.10, therefore you should be following the instructions that start at the respective section of the same name! But from your description, you accidentally followed the instructions that are meant for Ubuntu 10.04!!
  2. I suggest that you go for OpenFOAM 2.2.2, instead of 2.2.0: http://openfoamwiki.net/index.php/In...u#Ubuntu_13.10
  3. If the instructions don't mention anything about moving "gcc-4.5.2", then you should not have move it either
    Because what you actually did was move the source code folder and not the installation of GCC toolkit.
If you follow the instructions on the section "Ubuntu 13.10", you should not have any of these problems and possibly no problems whatsoever!
Please be very careful in following the instructions, since any mistake, no matter how small, can result it not reaching a successful installation
You might ask why this is so hard and detailed. The answer is simple: because OpenFOAM is at a similar level of detail, therefore you should learn to keep a very close attention to all details when installing and using OpenFOAM
Best regards,
Bruno
Old   April 15, 2014, 14:56
johny
Hi Bruno,
The complete OF installation works now :-)
Thanks a lot.
Cheers,
J
Hi Johny,
Best regards,
Bruno
Old   April 16, 2014, 22:31
johny
Hi Bruno,
I got yet another problem. Right after my installation I had opened an stl geometry and viewed it properly in paraview. I don't know what changes I made, but now I simply can't view the same stl file. The file opens and instead of a 3D geometry I see just a line. I'm sure its some settings issue. Could you please provide some insight? Please see the screenshot.
Cheers,
J
Hi Bruno,
Thanks a lot.
Cheers,
J
Old   April 17, 2014, 07:59
johny
Hi Bruno,
I figured it out that the stl file was in the plain text format and after conversion to binary it worked. But still wondering how it worked couple of days ago after which the file was never altered. Anyway now it works.
Cheers,
J
Hi Bruno,
Thanks a lot.
Cheers,
J
[OpenFOAM] Problem switching from terminal to paraView Maxime Thomas ParaView 10 October 4, 2014 10:59
[OpenFOAM] Problem with paraView starting PS87 ParaView 1 August 2, 2012 15:28
Paraview fliter problem (surface flow) (segmentation fault) maysmech OpenFOAM 1 October 6, 2011 11:01
[OpenFOAM] paraview split screen problem ziemowitzima ParaView 1 March 16, 2011 14:07
Problem with Paraview graphics Ronnfors OpenFOAM 8 November 4, 2009 12:49
