Problem in installing OpenFOAM-ParaView-0.1.1-1.x86_64
Old   July 23, 2014, 04:29
Default Problem in installing OpenFOAM-ParaView-0.1.1-1.x86_64
Hassan Zarei
hassan5565 is on a distinguished road
Hi Dear Foamers
I have OpenFOAM 2.2.0 installed on my OpenSUSE 12.2, now i want to install OpenFOAM 2.3.0 rpm pack.but after installing OpenFOAM-2.3.0-1.x86_64.rpm successfully, i encounter the following error when i want to install OpenFOAM-ParaView-4.1.0-1.x86_64.rpm:
package OpenFOAM-ParaView-3.12.0-1.x86_64 (which is newer than OpenFOAM-ParaView-0.1.1-1.x86_64) is already installed
could you please help me...
thanks
hassan5565 is offline   Reply With Quote
Old   August 5, 2014, 13:05
Retired Super Moderator
Bruno Santos
Greetings Hassan,
Sorry for the late reply. I don't know if you've managed to solve this issue already or not?
If you haven't solved this yet, can you please confirm the error message you're getting?
I ask this because the version indicated in the error message "ParaView-0.1.1" is really strange and it should indicate "ParaView-4.1.0".
Best regards,
Bruno
paraview 4.1.0
[OpenFOAM] No eye icon when using ParaView with OpenFOAM rmvega ParaView 0 July 2, 2014 09:59
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 02:28
[OpenFOAM] Installation problem with ParaView 3.8.0 on openSUSE 11.2 aero_ ParaView 14 August 2, 2010 18:13
Pls help last problem to be solved for installing OPENfoam daydayuper OpenFOAM Installation 5 November 9, 2008 04:59
Problem installing OpenFOAM 141 sachin OpenFOAM Installation 2 February 22, 2008 10:20
