[foam-extend.org] Trying to install foam-extend 3.1 on Ubuntu 14.04 |
February 11, 2015, 09:33 |
James
Rep Power: 13 |
Running Ubuntu 14.04 LTS and following instructions detailed here.
When I source the bash with Code:
foam-extend-3.1$ . etc/bashrc Code:
bash: /opt/foam-extend-3.1/bin/foamGetSystemInfo: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/etc/settings.sh: No such file or directory bash: /opt/foam-extend-3.1/etc/aliases.sh: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory bash: /opt/foam-extend-3.1/bin/foamCleanPath: No such file or directory Code:
foamInstall=$HOME/$WM_PROJECT I also have OpenFOAM installed, could this be an issue? I'm wondering whether I should remove it anyway. Are there any features in OpenFOAM that aren't in OpenFOAM extension? |
February 11, 2015, 10:09 |
You have got OpenFOAM installed and seems to set up environment for it, that is why foam-extend is trying to look into /opt. Before ". etc/bashrc" issue "wmUNSET" command. |
February 11, 2015, 12:48 |
#3 | |
James
Rep Power: 13 |
Some other conflicts I've found today is that paraFoam doesn't really work with the new foam extend case files but it also does not work as intended in previously functioning OpenFOAM case files. I'm working around this at the moment by just doing Code:
$ touch anything.foam $ paraview anything.foam |
February 11, 2015, 12:54 |
#4 | |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 14:07 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
[foam-extend.org] Installing foam-extend 3.1 on Ubuntu 14.04 | stephie | OpenFOAM Installation | 16 | April 23, 2015 16:18 |
fvSchemes in FOAM extend 3.1 | Shenan | OpenFOAM Running, Solving & CFD | 3 | December 22, 2014 09:45 |
How to Install Openfoam 2.2.2 in Ubuntu 14.04? | satty_00 | OpenFOAM Installation | 7 | May 18, 2014 10:04 |
