[OpenFOAM.org] OF 2.4.0 Paraview not installing correctly |
June 10, 2015, 12:56 |
Chris Coutinho
Rep Power: 11 |
Hello Foamers,
Relevant details:
I have downloaded of24x today to upgrade from of231, and I am having some issues in the last part where I am supposed to install Paraview. Previously I had always installed from source using the instructions seen here. This time I wanted to try the git repo method of installation, mostly out of curiosity and because I've never used git before. Everything worked great until I reached the steps involved in compiling Paraview. Here are my steps: 1. test cmake version Code:
cmake -- version Code:
cmake version 3.0.2 Code:
cd $WM_THIRD_PARTY_DIR ./makeParaView4 2>&1 | tee log.makeParaView4 3. Compile ParaView plugins Code:
cd $FOAM_UTILITIES/postProcessing/graphics/PV4Readers wmSET ./Allwclean ./Allwmake Code:
ERROR: ParaView not found in /home/chris/OpenFOAM/ThirdParty-2.4.x/platforms/linux64Gcc/ParaView-4.1.0 |
June 10, 2015, 15:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: I think the error and solution is the same: http://www.openfoam.org/mantisbt/view.php?id=1734
June 11, 2015, 04:36 |
Chris Coutinho
Rep Power: 11 |
Hey Bruno,
Thanks for link, that has solved the problem on my system. I didn't see a way to add a note to that bug report, is it possible to add a note saying it worked for me as well? People don't say it enough on this site, thanks for all your hard work Bruno. Cheers, C |
June 12, 2015, 17:03 |
Bruno Santos
Rep Power: 128 |
Hi Chris,
No need to add a note to that report. The issue is already known and I think it had been fixed for 2.3.1... I still gotta check what happened for this to happen again. Either that, or I'm confusing with the instructions I write on the wiki... Best regards, Bruno
error, installation, openfoam, paraview |
[OpenFOAM.org] problem installing ParaView with openFoam5 | enginpower | OpenFOAM Installation | 3 | March 26, 2018 10:34 |
[OpenFOAM.org] Paraview not found when installing OpenFoam to Ubuntu 14.04 | tabsquare | OpenFOAM Installation | 75 | December 30, 2017 11:21 |
[OpenFOAM.org] Two different versions of ParaView with same OpenFOAM release | FJSJ | OpenFOAM Installation | 2 | July 23, 2017 05:48 |
paraview not working after installing OpenFOAM in Ubuntu 12.04 | Jackie Chen | OpenFOAM Installation | 5 | October 9, 2014 06:28 |
Paraview version update errors | Dan Pearce | OpenFOAM Installation | 5 | January 8, 2014 05:47 |
