[OpenFOAM.org] decomposePar: no available formula for scotch
Like Tree1Likes
  • 1 Post By alexeym
Prev Previous Post   Next Post Next
Old   September 6, 2015, 05:25
Default decomposePar: no available formula for scotch
KateEisenhower is on a distinguished road
Dear all,
I somehow screwed my OpenFOAM installation. After installing gnuplot via homebrew I am getting the following problems when mounting the OpenFOAM sparsebundle:
Last login: Sun Sep  6 10:27:14 on ttys000
kates-mbp:~ kateeisenhower$ hdiutil attach -mountpoint $HOME/OpenFOAM OpenFOAM.sparsebundle
/dev/disk2          	GUID_partition_scheme
/dev/disk2s1        	EFI
/dev/disk2s2        	Apple_HFS                      	/Users/kateeisenhower/OpenFOAM
kates-mbp:~ kateeisenhower$ source $HOME/OpenFOAM/OpenFOAM-2.3.1/etc/bashrc
-bash: openmpi_help: command not found
Using paraview in directory /Applications/paraview.app
-bash: boost_help: command not found
Error: No available formula for scotch
kates-mbp:~ kateeisenhower$ checkMesh -help
Apps like checkMesh are running fine. But if I try the command
decomposePar
, I'm getting the following output:
kates-mbp:100mmhkverfeinert_symm kateeisenhower$ decomposePar
dyld: Library not loaded: /usr/local/lib/libscotch.dylib
  Referenced from: /Users/kateeisenhower/OpenFOAM/OpenFOAM-2.3.1/platforms/darwinIntel64ClangDPOpt/lib/libscotchDecomp.dylib
  Reason: image not found
Trace/BPT trap: 5
Any help would be appreciated!
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 12:01
decomposePar for custom solvers and boundary conditions cfdopenfoam OpenFOAM Programming & Development 4 October 31, 2015 09:05
decomposePar 4-core warning/error? Boloar OpenFOAM Bugs 23 April 8, 2014 08:57
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 05:27
Benetton Formula 1 CD adapco Group Marketing Siemens 13 February 7, 2002 09:33
