[OpenFOAM.com] I have problem in install openFoam 1.5
Old   October 21, 2015, 00:33
Default I have problem in install openFoam 1.5
emad hamdy
emadhamdy is on a distinguished road
i am new user for openfoam and ubuntu
i install ubuntu 12.04 and openfoam 1.5
but after openfoam istallation finish the command " icoFoam -help" not work as below
emad@malek:~/OpenFOAM/OpenFOAM-1.5$ icoFoam -help
and message appear are :
icoFoam: command not found
then what i can do to solve this problem, and thank u
emadhamdy is offline   Reply With Quote
Old   October 22, 2015, 16:22
Retired Super Moderator
Bruno Santos
Quick answer: That seems to indicate that OpenFOAM 1.5 is not installed.
A few questions:
  1. Which installation instructions did you follow?
  2. Why are you trying to use such an old version of OpenFOAM?
Old   October 23, 2015, 01:57
emad hamdy
A few questions:
thank u for your attention to my question and i will tell u the following:
1. i take instruction steps which exist in the following web page:
https://openfoamwiki.net/index.php/I...OAM-1.5/Ubuntu
2. i want to use old version of openFoam for the reason is, i do scientific search in specific problem and the recent previous research related to my problem was done by openfoam 1.5 dev. and i had tried to use new version of openfoam to run this related research with my research point but this was not compatible and not running with the openfoam new version as well. so that i try to install the same version of openfoam that used in previous research
Old   October 24, 2015, 14:45
Bruno Santos
Greetings emadhamdy,
I was afraid of this... OpenFOAM 1.5 is not the same as OpenFOAM 1.5-dev. The 1.5-dev is a variant of the standard OpenFOAM version: https://openfoamwiki.net/index.php/F...ts#foam-extend
The bigger problem is that I haven't been able to compile OpenFOAM 1.5-dev, which is why there aren't any updated instructions on the wiki for it.
Nonetheless, you can try installing Ubuntu 10.04 in a virtual machine and follow the instructions given here: http://openfoamwiki.net/index.php/In...ucid_10.04_LTS
Edit: I tested just now in an old virtual machine that I have with Ubuntu 10.04 and unfortunately the 1.5-dev deb package is no longer available
Best regards,
Bruno
Old   October 24, 2015, 23:55
Smile
emad hamdy
greetting wyldckat "bruno"
alot thanks for your attention and i will try this and replay to u
best regards,
emadhamdy
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
[OpenFOAM.org] Installation notes: OpenFOAM 2.3.x (git repo) on OSX 10.9 opedrofunk OpenFOAM Installation 7 July 1, 2015 13:51
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
