[OpenFOAM.org] OpenFOAM 2.4.0 OpenMPI Epoll warning on parallel job |
November 15, 2015, 07:56 |
Tom Alderweireldt
Rep Power: 11 |
I ported my existing OpenFOAM cases from version 2.3.0 to 2.4.0. The 2.4.0 version compiled without issues on a Fedora 23 Linux system. When I start a parallel test case with : >> mpirun -np 8 icoFoam -parallel > log & it starts, but I get the following openmpi related warning: "[WARN] Epoll ADD(4) on fd 1 failed ..." The result is that the log file is not written while the case is running. When the job finishes, the log file appears. I can't find anything wrong with the results, but it is annoying that I can't 'tail' the log file during execution to check progress or errors. Is this a known issue, can anyone suggest a solution ? Tom. |
November 15, 2015, 08:46 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: From my blog post: Notes about running OpenFOAM in parallel
November 15, 2015, 10:41 |
Tom Alderweireldt
Rep Power: 11 |
the output indeed only comes out at the end of the mpirun.
It is clearly the same issue as mentioned in the other post you mentioned (thanks for that). However I'm unable to find the 'mca-params.conf' file at the location given in this other post. Checking mpirun --version gives me 1.8.8 I don't find any /usr/mpi/gcc/openmpi-1.8.8 directory. A full search gives me 2 locations with a mca-params.conf file - one in /etc/openmpi-x86_64 - one in /home/myuser/OpenFOAM/Thirdparty-2.4.0/..openmpi-1.8.5/... unfortunately both are fully commented out, so I don't see what I could change to disable this epoll function. |
November 15, 2015, 12:24 |
Bruno Santos
Rep Power: 128 |
Quick answer: When in doubt, ask Open-MPI:
ompi_info -a -c > log.ompi_info
mpirun --mca opal_event_include poll ... |
How to use setField to create sphere | sega | OpenFOAM Pre-Processing | 38 | January 13, 2022 00:39 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
