[OpenFOAM.org] SloanRenumber, compilation error.
Old   November 21, 2015, 08:14
Default SloanRenumber, compilation error.
anton
echo.motd is on a distinguished road
I have got this error. Please advise.
Making dependency list for source file SloanRenumber.C
g++ -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I/usr/local/OpenFOAM/ThirdParty-3.0.x/platforms/linux64Gcc/boost-system/include -I/usr/local/OpenFOAM/OpenFOAM-3.0.x/src/meshTools/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-3.0.x/src/parallel/decompose/decompositionMethods/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-3.0.x/src/renumber/renumberMethods/lnInclude -IlnInclude -I. -I/usr/local/OpenFOAM/OpenFOAM-3.0.x/src/OpenFOAM/lnInclude -I/usr/local/OpenFOAM/OpenFOAM-3.0.x/src/OSspecific/POSIX/lnInclude -fPIC -c SloanRenumber.C -o /usr/local/OpenFOAM/OpenFOAM-3.0.x/platforms/linux64GccDPInt32Opt/src/renumber/SloanRenumber/SloanRenumber.o
SloanRenumber.C:34:28: fatal error: boost/config.hpp: No such file or directory
compilation terminated.
Thanks
echo.motd is offline   Reply With Quote
Old   November 21, 2015, 09:26
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Since SloanRenumber depends on boost, you have to set BOOST_ARCH_PATH environment variable to the path where boost is installed (so $(BOOST_ARCH_PATH)/include contains boost folder with header files and $(BOOST_ARCH_PATH)/lib contains libraries). By default it points to
export BOOST_ARCH_PATH=$WM_THIRD_PARTY_DIR/platforms/$WM_ARCH$WM_COMPILER/$boost_version
If you install boost using package manager usually it is safe to set BOOST_ARCH_PATH to /usr (though on RHEL clones you need to correct src/renumber/SloanRenumber/Make/options, since libraries are stored in /usr/lib64).
You can follow installation guide here:
https://openfoamwiki.net/index.php/I...CentOS_SL_RHEL
or here
https://openfoamwiki.net/index.php/I...M-3.0.x/Ubuntu
Though they both assume that you ADORE building third-party software from sources.
alexeym is offline   Reply With Quote
Old   November 21, 2015, 16:10
Default boost and boost libraries missed
anton
Hello Alexey,
Thank you for replay.
I have just compiled OpenFOAM. I did not install all dependences. After your post I had realised that I do not have boost and boost libraries since it is not mentioned at Arch Linux OpenFOAM Wiki.
Kind Regards
Pressure outlet boundary condition rolando OpenFOAM Running, Solving & CFD 62 September 18, 2017 06:45
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
