[OpenFOAM.com] Problem installing on Yosemite |
June 25, 2016, 13:38 |
#21 |
S
Rep Power: 9 |
I followed the steps from Nann3r on OSX 10.11.5, but when I tried step 6 I received
Error response from daemon: ContainerInspect failed Error: failed to start containers: of_v3.0_plus Error: No such container: of_v3.0_plus the output from "$ docker-machine ls" is NAME ACTIVE DRIVER STATE URL SWARM DOCKER ERRORS default - virtualbox Running tcp://192.168.99.100:2376 v1.12.0-rc2 and from "$ docker-machine ssh default docker ps -a" is CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 7dd00d8cd06a openfoamplus/of_v30plus_rhel66 "/bin/bash --rcfile /" 11 minutes ago Up 11 minutes of_v3.0_plus but "$ docker ps -a" does not show any containers. CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES I re-configured my shell with eval $(docker-machine env) and then I could run ./startOpenFOAM_Mac |
June 26, 2016, 12:20 |
#22 |
Nick Hanson
June 28, 2016, 16:04 |
#23 |
S
Rep Power: 9 |
yup, it worked after that.
[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!! | omid20110 | OpenFOAM Installation | 6 | August 1, 2016 11:20 |
[swak4Foam] foam-extend-3.2 installing problem: swak4Foam failed to install due to Bison | lxwd | OpenFOAM Community Contributions | 1 | March 20, 2016 16:03 |
Problem with installing OpenFOAM 2.0.X | mohsen.boojari | OpenFOAM Installation | 3 | February 3, 2016 11:41 |
Problem installing OpenFOAM-1.6-ext on Ubuntu 14.04 | afrotimy | OpenFOAM Installation | 4 | October 4, 2014 11:36 |
Problem in installing OpenFOAM-ParaView-0.1.1-1.x86_64 | hassan5565 | OpenFOAM Installation | 1 | August 5, 2014 13:05 |
