[OpenFOAM.org] Problem in installing OpenFOAM 2.3.0 !!!
Like Tree3Likes
  • 1 Post By hk318i
  • 1 Post By hk318i
  • 1 Post By hk318i
Old   July 27, 2016, 16:00
Default Problem in installing OpenFOAM 2.3.0 !!!
Sadegh Ebadi
omid20110 is on a distinguished road
Hello everybody,
I'm trying to install openfoam 2.3.0 but I get this error:
" sudo apt-get install openfoam230
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package openfoam230 "
I should mention that I already have installed openfoam 3.0.1 and openfoam 2.4 but now whenever I try to install openfoam 2.3.0 (that is needed for installing flameletfoam...) I get this type of error!
Please help me to solve this problem.
omid20110 is offline   Reply With Quote
Old   July 29, 2016, 10:10
Hassan Kassem
hk318i is on a distinguished road
Probably, you have a recent Ubuntu version which does not support OpenFOAM-2.3 binary package. Check [LINK1][LINK2]
You can compile the source files on your system directly.
omid20110 likes this.
@HIKassem | HassanKassem.me
hk318i is offline   Reply With Quote
Old   July 29, 2016, 13:59
Sadegh Ebadi
Yes you're right I have ubuntu 14.04 LTS..
Thanks but I don't know how to install openfoam 2.3 using these links!
Could you please explain it?
Old   July 30, 2016, 06:28
Hassan Kassem
You install OpenFOAM-2.3.1 on Ubuntu 14.04 LTS.
sudo apt-get install openfoam231
To install from source, you can follow these instructions [LINK]. Also, you can follow OFWiki detailed guide.
Old   July 30, 2016, 18:35
Sadegh Ebadi
Thanks for your help.
I have followed the instructions in this link
http://openfoam.org/download/2-3-0-source/
I have unpacked the sources in opt directory and I have set environment variables in .bashrc like this:
alias of30='. /opt/openfoam30/etc/bashrc'
alias of240='. /opt/openfoam240/etc/bashrc'
alias of230='. /opt/OpenFOAM-2.3.0/etc/bashrc'
now when I run ./Allwmake I get this error:
linux@linux-K550ZE:~$ sudo su -
[sudo] password for linux:
root@linux-K550ZE:~# cd /opt/OpenFOAM-2.3.0
root@linux-K550ZE:/opt/OpenFOAM-2.3.0# ./Allwmake
./Allwmake: 4: ./Allwmake: wmakeCheckPwd: not found
Error: Current directory is not $WM_PROJECT_DIR
The environment variables are inconsistent with the installation.
Check the OpenFOAM entries in your dot-files and source them.
Old   July 31, 2016, 05:20
Hassan Kassem
You need to change the location of OpenFOAM installation in ``OpenFOAM-2.3.0/etc/bashrc`` or simple install it in ``$HOME/OpenFOAM/OpenFOAM-2.3.0``
Old   August 1, 2016, 11:20
Sadegh Ebadi
Thanks it solved my problem
openfoam2.3.0
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology wyldckat OpenFOAM 17 November 10, 2017 15:54
[OpenFOAM.org] Problem Installing OpenFOAM V 2.3.1 in Ubuntu 17.04 tareqkh OpenFOAM Installation 1 September 2, 2017 10:10
[OpenFOAM.org] OpenFOAM 2.3.0 Installation Problem on CentOS 6.6 shenzhou1987 OpenFOAM Installation 1 December 14, 2014 13:34
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Problem on installing Openfoam on 64bit sgi station gregjunqua OpenFOAM Installation 4 October 12, 2011 16:28
