[foam-extend.org] foam-extend-3.2 glaros.dtc.umn.edu connection timed out |
May 25, 2016, 16:46 |
Virgilio Abraham Gomez
Rep Power: 9 |
I am trying to compile foam-extend-3.2 with the ./Allwmake.firstInstall command. It starts compiling and installing the thirdparty softwares but when it gets to the part of installing parmetis 4.0.3, I get: --2016-05-25 15:39:17-- (try:14) http://glaros.dtc.umn.edu/gkhome/fet...s-4.0.3.tar.gz Connecting to glaros.dtc.umn.edu (glaros.dtc.umn.edu)|160.94.77.162|:80... failed: Connection timed out. Retrying. Help! Thanks. Virgilio |
May 25, 2016, 19:56 |
Same problem
Sourabh Supanekar
Rep Power: 10 |
Hello Virgilio,
I am facing a similar problem. But after around 20 or so tries (to connect) I think it just skipped that part and continued compiling. After completion of compiling, I tries to run a small case, but it doesnt work. So, let me know if you figure out anything on this issue. Regards, Sourabh |
May 26, 2016, 02:15 |
same problem too
LOU Lida
Rep Power: 11 |
same problem.
It seems the parMetis website is out-of service. The installation may continue without metis. I think it will cause the problem that when doing decomposePar, metis cannot be used. I was wondering whether other functions will be effecte? Lida |
May 26, 2016, 09:59 |
more installation issues
Rep Power: 9 |
It finished compiling but like how Sourabh said, none of the solvers work. I typed icoFoam -help and I get command not found. Also, the thirdparty installation of bison and swak4foam were unsuccessful.
------------------------------------------------------------------- No file 'swakConfiguration'. Python etc won't work. See README for details Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems Checking swak4Foam-version and generating file Swak version is 0.3.2 No 'bison' found. This is absolutely essential for swak4Foam. Can't go on Every Linux has a binary package that installs bison (http://www.gnu.org/software/bison/). Install it. Then go on As an alternative you can install a local copy of bison by running ./maintainanceScripts/compileRequirements.sh from the installation directory BTW: it was listed as a requirement in the README. You read that, didn't you? Requirements for Library not satisfied. I see no sense in going on Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard -------------------------------------------------------------------------- Lida/Sourabh, did you get this message at the end of compiling? Virgilio |
May 26, 2016, 10:17 |
LOU Lida
Rep Power: 11 |
Hi, Virgilio
I did not get the same error as yours. The third party software bison or Python can be installed by using the command "sudo apt-get install bison" in ubuntu or something like this in other os. And wtih the command not found problem: Before you start compile(./Allmake.firstime), you should install the openfoam required packages which shows in this link. http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04 Lida |
May 26, 2016, 12:05 |
Rep Power: 9 |
Lida,
So all the thirdparty packages should be installed before installing foam-extend? The list of thirdparties are in that link. https://sourceforge.net/p/openfoam-e...eNotes.txt#I65 Virgilio |
May 26, 2016, 12:06 |
LOU Lida
Rep Power: 11 |
I think so. You may try it and re-compile it.
Lida |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
