[foam-extend.org] 3.2 OpenSUSE Leap Installation Error
Like Tree1Likes
  • 1 Post By JFM
Old   June 3, 2016, 09:28
Default 3.2 OpenSUSE Leap Installation Error
JFM
JFM's Avatar
John Anonymous
JFM is on a distinguished road
Send a message via Skype™ to JFM
Hello everybody
I have been trying to install foam-extend-3.2 for a very, very long time. Inthe end I decided to change my OS from Ubuntu to OpenSUSE Leap (a clean install) in an attempt to get this up and running.
Could someone have a look at the following error and let me know if there is a way to resolve this.
jfm@linux-1afo:~/foam/foam-extend-3.2> echo unset WM_THIRD_PARTY_USE_CMAKE_322 >> etc/prefs.sh
jfm@linux-1afo:~/foam/foam-extend-3.2> echo export WM_MPLIB=SYSTEMOPENMPI >> etc/prefs.sh
jfm@linux-1afo:~/foam/foam-extend-3.2> source etc/bashrc
which: no mpicc in (/home/jfm/foam/jfm-3.2/applications/bin/linux64GccDPOpt:/home/jfm/foam/site/3.2/bin/linux64GccDPOpt:/home/jfm/foam/foam-extend-3.2/applications/bin/linux64GccDPOpt:/home/jfm/foam/foam-extend-3.2/wmake:/home/jfm/foam/foam-extend-3.2/bin:/home/jfm/foam/foam-extend-3.2/wmake:/home/jfm/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/games)
dirname: missing operand
Could not find anything specifically about the mpicc message on-line
Any guidance will be greatly appreciated.
Regards
JFM
JFM is offline   Reply With Quote
Old   June 17, 2016, 09:38
Default [SOLVED] foam-extend-3.2 OpenSUSE Leap Installation Error
JFM
JFM's Avatar
John Anonymous
Good day All
I managed to address the error by running the following command:
sudo zypper install lam lam-devel
Information on this can be found at:
https://forums.opensuse.org/showthre...ng-MPI-library
Hopefully it helps someone else.
Regards
John
ordinary likes this.
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
