[OpenFOAM.org] Ubuntu 16.04 Active Directory Authentication/OpenFOAM
Old   June 28, 2016, 10:58
Default Ubuntu 16.04 Active Directory Authentication/OpenFOAM
Charlie
Gonzo1982 is on a distinguished road
Hi everyone,
For security reasons, I'm wanting to get all of my Linux users workstations on the Active Directory Domain for Authentication purposes. I'm running into an issue with OpenFoam removing the path from the .bashrc when run.
See the following error messages:
sed: -e expression #1, char 78: unknown option to `s'
bash: uname: No such file or directory
Your "" operating system is not supported by this release
of OpenFOAM. For further assistance, please contact www.OpenFOAM.org
Command 'sed' is available in '/bin/sed'
Command 'mpicc' is available in '/usr/bin/mpicc'
The command could not be located because '/usr/bin' is not included in the PATH environment variable.
mpicc: command not found
The command could not be located because '/bin' is not included in the PATH environment variable.
sed: command not found
/opt/openfoam4/bin/foamCleanPath: 110: /opt/openfoam4/bin/foamCleanPath: sed: not found
bash: sed: No such file or directory
/opt/openfoam4/bin/foamCleanPath: 129: /opt/openfoam4/bin/foamCleanPath: sed: not found
This only happens for users logging into their computers using their Domain creds.
Any advice or solution?
Gonzo1982 is offline   Reply With Quote
Old   June 28, 2016, 16:59
Charlie
This issue has been present on previous versions of OpenFoam. It's really frustrating. If anyone can provide some help, it would be greatly appreciated.
[swak4Foam] Error installing swak4Foam Hisham OpenFOAM Community Contributions 182 February 8, 2024 10:36
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
Ansys Licence Serve on Ubuntu 16.04 LTS david.pasquale ANSYS 2 January 20, 2017 11:52
Re : Problem Installing OpenFOAM on Centos -5.3 mohanphy OpenFOAM Installation 1 February 7, 2010 19:09
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
