[OpenFOAM.com] v1606+ Installing on Fedora 23
Like Tree2Likes
  • 1 Post By JonW
  • 1 Post By wyldckat
Old   July 13, 2016, 20:00
Default v1606+ Installing on Fedora 23
Jon Elvar Wallevik
JonW will become famous soon enough
Hello foamers
I just finished installing the ozom OpenFOAM-v1606+ on Fedora 23 and this is what I did (as before with the OF 4.0 installation, note that the dnf install part is a bit messy. Still, I haven't had time to clean it, but this works on my pc). Hope this helps...
First install some stuff on your system (same with the of4.0, see prevous post),...
sudo dnf groupinstall 'Development Tools'
sudo dnf groupinstall 'C Development Tools and Libraries'
sudo dnf install openmpi openmpi-devel qt-devel qt-webkit-devel zlib-devel cmake wget boost-devel gmp-devel mpfr-devel patch readline-devel ncurses-devel python python-devel
sudo dnf install git gitk
sudo dnf install openmpi-devel qt-devel qtwebkit-devel zlib-devel cmake
sudo dnf install openmpi openmpi-devel qt-devel qt-webkit-devel zlib-devel cmake wget git gitk
sudo dnf install boost-devel gmp-devel mpfr-devel patch readline-devel ncurses-devel python python-devel
sudo dnf install CGAL CGAL-devel binutils-devel mercurial
sudo dnf install compat-gcc-34-g77
sudo dnf install freeglut freeglut-devel flex bison cmake zlib zlib-devel boost-thread boost-system boost-devel libXt-devel libXt scotch scotch-devel qt5-qtwebkit-devel
sudo dnf install qtwebkit qtwebkit-devel CGAL CGAL-devel openmpi openmpi-devel
sudo dnf install zlib zlib-devel boost boost-math boost-thread boost-system boost-devel openmpi openmpi-devel readline readline-devel ncurses-devel ncurses-libs ncurses libXt libXt-devel
sudo dnf install scotch scotch-devel ptscotch-openmpi ptscotch-openmpi-devel ptscotch-openmpi-devel-parmetis
(0)
Download, unpack and rename the following as explained on the home page...
http://www.openfoam.com/download/install-source.php
OpenFOAM-v1606+.tgz
ThirdParty-v1606+.tgz
... and note also the md5sum discussion in
http://www.cfd-online.com/Forums/ope...oam-v1606.html
(1)
In your .bashrc, put...
alias of1606='export PATH=/usr/lib64/openmpi/bin/:/usr/lib64/ccache:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/home/jonelvar/.local/bin:/home/jonelvar/bin && export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/: && source /home/jonelvar/OpenFOAM/OpenFOAM-v1606+/etc/bashrc && PS1='\''\[\e[1;31m\][1606]\[\e[0m\]\[\e[1;32m\][pts/1]\[\e[0m\][\W]\[\e[1;31m\]:\[\e[0m\] '\'' '
(you can also have the path part in the beginning of your .bashrc instead, if you like)
(2)
Download...
http://www.cmake.org/files/v3.2/cmake-3.2.1.tar.gz
unpack (i.e. tar xzf cmake-3.2.1.tar.gz) and put in $WM_THIRD_PARTY_DIR
(3)
New terminal and type of1606
cd $WM_THIRD_PARTY_DIR
./makeCmake 2>&1 | tee makeLogFile_tmp1.txt
wmSET $FOAM_SETTINGS
(4) If you have not done so already, then do...
cd /usr/bin
sudo ln -s qmake-qt5 qmake
(5)
(6)
./makeParaView
(7)
(8)
foam
export WM_NCOMPPROCS=$(cat /proc/cpuinfo | grep processor | wc -l)
./Allwmake
(9)
(10)
./Allwmake 2>&1 | tee wmake_log_file_1.txt
In this file you can check if there any errors.
(11)
Do the post-compilation steps as explained in
http://www.openfoam.com/code/build-guide.php
JonW is offline   Reply With Quote
Old   July 13, 2016, 20:03
Default regarding cmake
Jon Elvar Wallevik
I just forgot to mention
README.org in ThirdParty-v1606+, says to use version 3.5.2, but the makeCmake wants 3.2.1
I used the latter (i.e. 3.2.1) and everything went OK
mm.abdollahzadeh likes this.
Old   September 11, 2016, 10:50
Retired Super Moderator
Bruno Santos
Quick note: I've added a link to this thread here: https://openfoamwiki.net/index.php/I...dora#Fedora_23
Anyone can create these wiki pages, you can even copy-paste-adapt the instructions from other wiki pages that are listed here: https://openfoamwiki.net/index.php/Installation - in section "How to help" it's even explained how to do it.
JonW likes this.
Old   August 8, 2017, 14:57
Default small adjustment of step 1, about $HOME
Jon Elvar Wallevik
The "step (1)" above, is supposed to be as follows:
alias ofva1606="export PATH=/usr/lib64/openmpi/bin/:$PATH && export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/:$LD_LIBRARY_PATH && source $HOME/OpenFOAM/OpenFOAM-v1606+/etc/bashrc && PS1='\[\e[1;30m\][v1606]\[\e[0m\]\[\e[1;30m\][$(tty | cut -d/ -f3,4)]\[\e[0m\][\W]\[\e[1;30m\]:\[\e[0m\] ' "
I don't understand why "$HOME" didn't copy as is, when I did this post.
J.
[OpenFOAM.org] Installing OpenFOAM 4.0 on Fedora 23 JonW OpenFOAM Installation 6 June 13, 2017 14:29
[OpenFOAM.com] Installing v1612+ on Fedora 25 JonW OpenFOAM Installation 4 January 27, 2017 15:38
[OpenFOAM.com] v1606+ Installing on Fedora 24 JonW OpenFOAM Installation 2 September 11, 2016 15:54
Problem of Installing “engrid” using Fedora 19 sbvawt enGrid 3 November 3, 2014 04:06
why i get this error during installing Linux Fedora? gholamghar Main CFD Forum 1 July 23, 2010 03:14
