[OpenFOAM.com] Installing v1612+ on Fedora 25 |
January 19, 2017, 12:02 |
Jon Elvar Wallevik
Rep Power: 19 |
Hello foamers
I just finished installing OpenFOAM-v1612+ on Fedora 25 and this is what I did (note that the dnf install part is a bit messy, haven't had time to clean it, but this works on my pc). Hope this helps and good luck ... First install some stuff on your system,... sudo dnf groupinstall 'Development Tools' sudo dnf groupinstall 'C Development Tools and Libraries' sudo dnf install openmpi openmpi-devel qt-devel qt-webkit-devel zlib-devel cmake wget boost-devel gmp-devel mpfr-devel patch readline-devel ncurses-devel python python-devel sudo dnf install git gitk sudo dnf install openmpi-devel qt-devel qtwebkit-devel zlib-devel cmake sudo dnf install openmpi openmpi-devel qt-devel qt-webkit-devel zlib-devel cmake wget git gitk sudo dnf install boost-devel gmp-devel mpfr-devel patch readline-devel ncurses-devel python python-devel sudo dnf install CGAL CGAL-devel binutils-devel mercurial sudo dnf install compat-gcc-34-g77 sudo dnf install freeglut freeglut-devel flex bison cmake zlib zlib-devel boost-thread boost-system boost-devel libXt-devel libXt scotch scotch-devel qt5-qtwebkit-devel sudo dnf install qtwebkit qtwebkit-devel CGAL CGAL-devel openmpi openmpi-devel sudo dnf install zlib zlib-devel boost boost-math boost-thread boost-system boost-devel openmpi openmpi-devel readline readline-devel ncurses-devel ncurses-libs ncurses libXt libXt-devel sudo dnf install scotch scotch-devel ptscotch-openmpi ptscotch-openmpi-devel ptscotch-openmpi-devel-parmetis sudo dnf install metis metis-devel sudo dnf install qt5-qttools-static ----------------------------------------------------- (0) Download, unpack and rename the following as explained on the home page... http://www.openfoam.com/download/install-source.php OpenFOAM-v1612+.tgz ThirdParty-v1612+.tgz --------------------------- (1) In your .bashrc, put... alias of1612='export PATH=/usr/lib64/openmpi/bin/:/usr/lib64/ccache:/usr/local/bin:/usr/bin:/bin:/usr/local/sbin:/usr/sbin:/home/jonelvar/.local/bin:/home/jonelvar/bin && export LD_LIBRARY_PATH=/usr/lib64/openmpi/lib/: && source /home/jonelvar/OpenFOAM/OpenFOAM-v1612+/etc/bashrc && PS1='\''\[\e[1;31m\][1612]\[\e[0m\]\[\e[1;32m\][pts/1]\[\e[0m\][\W]\[\e[1;31m\]:\[\e[0m\] '\'' ' (you can also have the mpi-path part in the beginning of your .bashrc instead, if you like) --------------------------- (2) Download... http://www.cmake.org/files/v3.2/cmake-3.2.2.tar.gz unpack (i.e. tar xzf cmake-3.2.2.tar.gz) and put in $WM_THIRD_PARTY_DIR --------------------------- (3) New terminal and type of1612 cd $WM_THIRD_PARTY_DIR ./makeCmake cmake-3.2.2 2>&1 | tee makeLogFile_tmp1.txt Please note, there is a possibility that you don't have to compile cmake. I did it, because I got into problems (which was due to missing "sudo dnf install qt5-qttools-static") --------------------------- (4) If you have not done so already, then do... cd /usr/bin sudo ln -s qmake-qt5 qmake --------------------------- (5) New terminal and type of1612 --------------------------- (6) cd $WM_THIRD_PARTY_DIR ./makeParaView --------------------------- (7) New terminal and type of1612 --------------------------- (8) foam export WM_NCOMPPROCS=$(cat /proc/cpuinfo | grep processor | wc -l) ./Allwmake --------------------------- (9) New terminal and type of1612 --------------------------- (10) ./Allwmake 2>&1 | tee wmake_log_file_1.txt check for error in wmake_log_file_1.txt --------------------------- (11) Do the post-compilation steps as explained in http://www.openfoam.com/code/build-guide.php e.g. mkdir -p $FOAM_USER_LIBBIN $FOAM_SITE_LIBBIN $FOAM_USER_APPBIN $FOAM_SITE_APPBIN $WM_PROJECT_USER_DIR --------------------------- |
January 19, 2017, 14:15 |
3 tiny errors,... nothing to worry about
Jon Elvar Wallevik
Rep Power: 19 |
OK, I was bit fast here.
There are 3 tiny errors that occur during the compile. These are... ------------------------------------------------------ collect2: error: ld returned 1 exit status CMakeFiles/runTimePostProcessing.dir/build.make:538: recipe for target '/home/jonelvar/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/librunTimePostProcessing.so' failed make[2]: *** [/home/jonelvar/OpenFOAM/OpenFOAM-v1612+/platforms/linux64GccDPInt32Opt/lib/librunTimePostProcessing.so] Error 1 CMakeFiles/Makefile2:67: recipe for target 'CMakeFiles/runTimePostProcessing.dir/all' failed make[1]: *** [CMakeFiles/runTimePostProcessing.dir/all] Error 2 Makefile:83: recipe for target 'all' failed make: *** [all] Error 2 WARNING: incomplete build of VTK-based post-processing ------------------------------------------------------ ...But, parafoam and foamToVTK works just fine. To test the important stuff: Just done some tests in the tutorials, with mpirun reconstruct etc. and everything works just fine. If you can find how to get rid of the above (minor/tiny) errors, then please tell. Cheers J. |
January 24, 2017, 16:22 |
#3 | |
Mark Olesen
Rep Power: 40 |
src/functionObjects/graphics/runTimePostProcessing/Allwclean src/functionObjects/graphics/runTimePostProcessing/Allwmake If this also fails to solve the problem, it could be useful to see if there are more error messages available. /mark |
January 24, 2017, 16:37 |
#4 | |
Mark Olesen
Rep Power: 40 |
You can either edit the relevant Code:
etc/config.sh/ Code:
bin/tools/foamConfigurePaths Eg, Code:
cd $WM_PROJECT_DIR bin/tools/foamConfigurePaths -boost boost-system -cgal cgal-system wmRefresh |
January 27, 2017, 15:38 |
Jon Elvar Wallevik
Rep Power: 19 |
Thanks for this olesen, I will most certainly try this out.
Cheers J. |
[OpenFOAM.com] v1606+ Installing on Fedora 23 | JonW | OpenFOAM Installation | 3 | August 8, 2017 14:57 |
[OpenFOAM.org] Installing OpenFOAM 4.0 on Fedora 23 | JonW | OpenFOAM Installation | 6 | June 13, 2017 14:29 |
[OpenFOAM.com] v1606+ Installing on Fedora 24 | JonW | OpenFOAM Installation | 2 | September 11, 2016 15:54 |
Problem of Installing “engrid” using Fedora 19 | sbvawt | enGrid | 3 | November 3, 2014 04:06 |
why i get this error during installing Linux Fedora? | gholamghar | Main CFD Forum | 1 | July 23, 2010 03:14 |
