[OpenFOAM.org] Unable to source bashrc since today...
Old   July 21, 2016, 10:10
Default Unable to source bashrc since today...
Sebastian Trunk
sisetrun is on a distinguished road
Dear Foamers,
I run OF2.3.x on Ubuntu14.04. Everything was running fine.
But since today, I get
HTML Code:
User@User:~$ OF23x
bash: /home/User/OpenFOAM/OpenFOAM-2.3.x/etc/bashrc: line 152: syntax error near unexpected token `)'
bash: /home/User/OpenFOAM/OpenFOAM-2.3.x/etc/bashrc: line 152: `        -*)
I doublechecked the bashrc file with
https://github.com/OpenFOAM/OpenFOAM...ter/etc/bashrc
and it is completely the same...
To be 100% sure, I changed the bashrc file to the above one and got the same error
Does anybody have an idea what I could have changed?!
I do not know how to continue...
Thanks a lot
sisetrun is offline   Reply With Quote
Old   July 21, 2016, 15:03
ChGr is on a distinguished road
could you post your .bashrc?
ChGr is offline   Reply With Quote
Old   July 21, 2016, 15:18
Sebastian Trunk
#----------------------------------*-sh-*--------------------------------------
# \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
#  \\    /   O peration     |
#   \\  /    A nd           | Copyright (C) 2011-2015 OpenFOAM Foundation
#    \\/     M anipulation  |
# License
#     This file is part of OpenFOAM.
#     OpenFOAM is free software: you can redistribute it and/or modify it
#     under the terms of the GNU General Public License as published by
#     the Free Software Foundation, either version 3 of the License, or
#     (at your option) any later version.
#     OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
#     ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
#     FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
#     for more details.
#     You should have received a copy of the GNU General Public License
#     along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
# File
#     etc/bashrc
# Description
#     Startup file for OpenFOAM
#     Sourced from ~/.profile or ~/.bashrc
#     Should be usable by any POSIX-compliant shell (eg, ksh)
export WM_PROJECT=OpenFOAM
export WM_PROJECT_VERSION=2.3.x
# USER EDITABLE PART: Changes made here may be lost with the next upgrade
# either set $FOAM_INST_DIR before sourcing this file or set
# 'foamInstall' below to where OpenFOAM is installed
# Location of the OpenFOAM installation
foamInstall=$HOME/$WM_PROJECT
# foamInstall=~$WM_PROJECT
# foamInstall=/opt/$WM_PROJECT
# foamInstall=/usr/local/$WM_PROJECT
# END OF (NORMAL) USER EDITABLE PART
# These are the defaults for this version which should generally be
# overridden from the prefs.sh file or from command-line specification
#- note the location for later use (eg, in job scripts)
: ${FOAM_INST_DIR:=$foamInstall}; export FOAM_INST_DIR
#- Compiler location:
#    foamCompiler= system | ThirdParty (OpenFOAM)
foamCompiler=system
#- Compiler:
#    WM_COMPILER = Gcc | Gcc45 | Gcc46 | Gcc47 | Clang | Icc (Intel icc)
export WM_COMPILER=Gcc
unset WM_COMPILER_ARCH WM_COMPILER_LIB_ARCH
#- Architecture:
#    WM_ARCH_OPTION = 32 | 64
export WM_ARCH_OPTION=64
#- Precision:
#    WM_PRECISION_OPTION = DP | SP
export WM_PRECISION_OPTION=DP
#- Optimised, debug, profiling:
#    WM_COMPILE_OPTION = Opt | Debug | Prof
export WM_COMPILE_OPTION=Opt
#- MPI implementation:
#    WM_MPLIB = SYSTEMOPENMPI | OPENMPI | SYSTEMMPI | MPICH | MPICH-GM | HPMPI
#               | MPI | QSMPI | SGIMPI
export WM_MPLIB=SYSTEMOPENMPI
#- Operating System:
#    WM_OSTYPE = POSIX | ???
export WM_OSTYPE=POSIX
#- Floating-point signal handling:
#    set or unset
export FOAM_SIGFPE=
#- memory initialisation:
#    set or unset
#export FOAM_SETNAN=
# The old dirs to be cleaned from the various environment variables
# - remove anything under top-level directory.
# NB: the WM_PROJECT_INST_DIR might not be identical between versions
foamOldDirs="$FOAM_INST_DIR $WM_PROJECT_SITE $HOME/$WM_PROJECT/$USER"
if [ "$WM_PROJECT_INST_DIR" != "$FOAM_INST_DIR" ]
then
    foamOldDirs="$WM_PROJECT_INST_DIR $foamOldDirs"
fi
# Location of installation
export WM_PROJECT_INST_DIR=$FOAM_INST_DIR
export WM_PROJECT_DIR=$WM_PROJECT_INST_DIR/$WM_PROJECT-$WM_PROJECT_VERSION
# Location of third-party software
export WM_THIRD_PARTY_DIR=$WM_PROJECT_INST_DIR/ThirdParty-$WM_PROJECT_VERSION
# Location of site-specific templates etc
# unset is equivalent to $WM_PROJECT_INST_DIR/site
if [ -d "$WM_PROJECT_SITE" ]
then
    export WM_PROJECT_SITE
else
    unset WM_PROJECT_SITE
fi
# Location of user files
export WM_PROJECT_USER_DIR=$HOME/$WM_PROJECT/$USER-$WM_PROJECT_VERSION
# Source files, possibly with some verbosity
_foamSource()
    while [ $# -ge 1 ]
    do
        [ "$FOAM_VERBOSE" -a "$PS1" ] && echo "Sourcing: $1" 1>&2
        . $1
       shift
    done
# Evaluate command-line parameters
_foamEval()
    while [ $# -gt 0 ]
    do
        case "$1" in
            # stray option (not meant for us here) -> get out
            break
            # name=       -> unset name
            [ "$FOAM_VERBOSE" -a "$PS1" ] && echo "unset ${1%=}" 1>&2
            eval "unset ${1%=}"
            # name=value  -> export name=value
            [ "$FOAM_VERBOSE" -a "$PS1" ] && echo "export $1" 1>&2
            eval "export $1"
            # filename: source it
            if [ -f "$1" ]
            then
                _foamSource "$1"
            else
                _foamSource `$WM_PROJECT_DIR/bin/foamEtcFile -silent "$1"`
            fi
        esac
        shift
    done
# Add in preset user or site preferences:
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile prefs.sh`
# Evaluate command-line parameters and record settings for later
# these can be used to set/unset values, or specify alternative pref files
export FOAM_SETTINGS="$@"
_foamEval $@
# Clean standard environment variables (PATH, LD_LIBRARY_PATH, MANPATH)
foamClean=$WM_PROJECT_DIR/bin/foamCleanPath
#- Clean PATH
cleaned=`$foamClean "$PATH" "$foamOldDirs"` && PATH="$cleaned"
#- Clean LD_LIBRARY_PATH
cleaned=`$foamClean "$LD_LIBRARY_PATH" "$foamOldDirs"` \
    && LD_LIBRARY_PATH="$cleaned"
#- Clean MANPATH
cleaned=`$foamClean "$MANPATH" "$foamOldDirs"` && MANPATH="$cleaned"
export PATH LD_LIBRARY_PATH MANPATH
# Source project setup files
_foamSource $WM_PROJECT_DIR/etc/config/settings.sh
_foamSource $WM_PROJECT_DIR/etc/config/aliases.sh
# Source user setup files for optional packages
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/paraview.sh`
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/ensight.sh`
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/gperftools.sh`
_foamSource `$WM_PROJECT_DIR/bin/foamEtcFile config/CGAL.sh`
# Clean environment paths again. Only remove duplicates
#- Clean PATH
cleaned=`$foamClean "$PATH"` && PATH="$cleaned"
cleaned=`$foamClean "$LD_LIBRARY_PATH"` && LD_LIBRARY_PATH="$cleaned"
#- Clean MANPATH (trailing ':' to find system pages)
cleaned=`$foamClean "$MANPATH"`: && MANPATH="$cleaned"
#- Clean LD_PRELOAD
if [ -n "$LD_PRELOAD" ]
then
    cleaned=`$foamClean "$LD_PRELOAD"` && LD_PRELOAD="$cleaned"
    export LD_PRELOAD
fi
# cleanup environment:
unset cleaned foamClean foamInstall foamOldDirs
unset _foamSource _foamEval
# ----------------------------------------------------------------- end-of-file
Line 152 is -*)
    while [ $# -gt 0 ]
        do
            case "$1" in
                   break
User@User:~$ OF23x  bash: /home/User/OpenFOAM/OpenFOAM-2.3.x/etc/bashrc: line 152: syntax error near unexpected token `)'
Old   July 22, 2016, 01:26
Sebastian Trunk
Hello everybody,
I have no clue at all, but i tried the OF23x angain this morning and everything works fine again!
Did no reboot or anything else...
Quit surprised and even more confused but it seems to run!
Best regards
Sebastian
[swak4Foam] difficulties installing swak4foam newbie29 OpenFOAM Community Contributions 120 October 21, 2022 04:01
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 17:18
