[OpenFOAM.org] Cannot compile OpenFOAM-dev with Intel compiler (17.0.0 20160721)
Old   November 27, 2016, 08:23
Default Cannot compile OpenFOAM-dev with Intel compiler (17.0.0 20160721)
Svensen is on a distinguished road
I want to compile OpenFOAM-dev with Intel compiler. Therefore I've changed WM_COMPILER to Icc in ./etc/bashrc file.
During execution of ./Allwmake script the following error occurred:
sergey@sergey-HP:~/intel/OpenFOAM-dev$ ./Allwmake -j
Compiling enabled on 12 cores
Allwmake /home/sergey/intel/OpenFOAM-dev
make: Nothing to be done for `all'.
Start ThirdParty Allwmake
Build MPI libraries if required
    have OPENMPI shared library (openmpi-1.10.2)
Build Scotch decomposition library scotch_6.0.3
    /home/sergey/intel/ThirdParty-dev/platforms/linux64IccDPInt32/scotch_6.0.3
    scotch header in /home/sergey/intel/ThirdParty-dev/platforms/linux64IccDPInt32/scotch_6.0.3/include
    scotch libs   in /home/sergey/intel/ThirdParty-dev/platforms/linux64IccDPInt32/lib
Build PTScotch decomposition library scotch_6.0.3 (uses MPI)
    ptscotch header in /home/sergey/intel/ThirdParty-dev/platforms/linux64IccDPInt32/scotch_6.0.3/include/openmpi-1.10.2
    ptscotch libs   in /home/sergey/intel/ThirdParty-dev/platforms/linux64IccDPInt32/lib/openmpi-1.10.2
Build Metis decomposition
    optional component Metis was not found
Build CGAL
    optional component was not found
Done ThirdParty Allwmake
Allwmake src
version changed from previous build
removing .o files corresponding to OpenFOAM/global/global.o ...
Allwmake src/Pstream
wmake dummy
wmake mpi
Allwmake libo src/OSspecific/POSIX
wmake libo .
icpc -std=c++11 -fp-trap=common -fp-model precise -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -diag-disable 327,654,1125,2289,2304,11062,11074,11076 -O3 -xHost  -DNoRepository  -IlnInclude -I. -I/home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/home/sergey/intel/OpenFOAM-dev/src/OSspecific/POSIX/lnInclude   -fPIC -c signals/sigStopAtWriteNow.C -o /home/sergey/intel/OpenFOAM-dev/platforms/linux64IccDPInt32Opt/src/OSspecific/POSIX/signals/sigStopAtWriteNow.o
icpc -std=c++11 -fp-trap=common -fp-model precise -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -diag-disable 327,654,1125,2289,2304,11062,11074,11076 -O3 -xHost  -DNoRepository  -IlnInclude -I. -I/home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude -I/home/sergey/intel/OpenFOAM-dev/src/OSspecific/POSIX/lnInclude   -fPIC -c signals/sigWriteNow.C -o /home/sergey/intel/OpenFOAM-dev/platforms/linux64IccDPInt32Opt/src/OSspecific/POSIX/signals/sigWriteNow.o
In file included from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/MatrixSpace.H(322),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/Tensor.H(45),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/SymmTensorI.H(27),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/SymmTensor.H(155),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/symmTensor.H(38),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/fieldTypes.H(37),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/flipOp.H(40),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/mapDistributeBaseTemplates.C(29),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/mapDistributeBase.H(488),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.C(30),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/Field.H(408),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/scalarField.H(38),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/dimensionSet.H(46),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/dimensionedType.H(40),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/dimensionedScalar.H(38),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/TimeState.H(38),
                 from /home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/Time.H(47),
                 from signals/sigWriteNow.C(30):
/home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/MatrixSpaceI.H(494): warning #2357: "Foam::MatrixSpace<Form2, Cmpt, SubTensor::mRows, SubTensor::nCols>" cannot be specified in a template member definition -- "Foam::MatrixSpace<Form, Cmpt, Mrows, Ncols>" assumed instead
      const MatrixSpace<Form2, Cmpt, SubTensor::mRows, SubTensor::nCols>& matrix
/home/sergey/intel/OpenFOAM-dev/src/OpenFOAM/lnInclude/MatrixSpaceI.H(492): error: no instance of overloaded function "Foam::MatrixSpace<Form, Cmpt, Mrows, Ncols>::Block<SubTensor, BRowStart, BColStart>::operator=" matches the specified type
  operator=
                 from signals/sigStopAtWriteNow.C(30):
  operator=
compilation aborted for signals/sigWriteNow.C (code 2)
compilation aborted for signals/sigStopAtWriteNow.C (code 2)
make: *** [/home/sergey/intel/OpenFOAM-dev/platforms/linux64IccDPInt32Opt/src/OSspecific/POSIX/signals/sigWriteNow.o] Error 2
make: *** Waiting for unfinished jobs....
make: *** [/home/sergey/intel/OpenFOAM-dev/platforms/linux64IccDPInt32Opt/src/OSspecific/POSIX/signals/sigStopAtWriteNow.o] Error 2
What can be wrong in this compilation ?
Thanks
Svensen is offline   Reply With Quote
Old   November 29, 2016, 16:01
Retired Super Moderator
Bruno Santos
For future reference, this was already answered here: http://bugs.openfoam.org/view.php?id=2357
compilation error, intel compiler, openfoam-dev
Map of the OpenFOAM Forum - Understanding where to post your questions! wyldckat OpenFOAM 10 September 2, 2021 05:29
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 01:39
OpenFOAM 1.5 dev LVDH OpenFOAM 98 May 5, 2010 17:01
