[OpenFOAM.com] v1612+ on CentOS 6.8, installed at "/opt"
Old   April 3, 2017, 10:44
Default v1612+ on CentOS 6.8, installed at "/opt"
grumpyadmin is on a distinguished road
I've been trying to compile OpenFOAM 16.12+ on a CentOS 6.8 machine. I set the path to /opt/OpenFOAM. The compile has been successful. However, when I use it as a normal user and do the post compilation steps, foamInstallationTest for example, it does not find the correct gcc (4.8.5) used to compile OpenFOAM, it does not find some of the libraries, and it cannot find icoFoam. Do I need to modify the config.sh files for the settings to be set correctly?
grumpyadmin is offline   Reply With Quote
Old   April 8, 2017, 07:07
Retired Super Moderator
Bruno Santos
Quick answer: I'm guessing that you have followed the instructions given here: https://openfoamwiki.net/index.php/I...HEL#CentOS_6.8
If you did follow those instructions, then you need to do step #7 once again on your normal user account, although taking into account that you installed it at "/opt".
You can also create the file "etc/prefs.sh" and place the following line inside it:
export WM_COMPILER_TYPE=ThirdParty
And if you build with 64-bit labels, also add the respective entry:
export WM_LABEL_SIZE=64
Issues with poor performance in faster CPU gian93 Hardware 9 October 29, 2018 13:34
[Other] CentOS 6.7 - Paraview - X Error: BadDrawable Vyssion OpenFOAM Installation 2 May 1, 2016 17:55
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 11:03
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
