[Other] Installation of two versions of OF, cannot find after installation |
July 16, 2017, 17:59 |
Rep Power: 8 |
I have had OF from OF.org now I installed OFplus from OF.com.
I followed the instructions at. Also in my bashrc before installation I did: alias OF='source /opt/openfoam4/etc/bashrc' alias OFPlus='source /opt/OpenFOAM-v1706/etc/bashrc' my original OF was already in /opt/ so since I thought OFPlus also will be installed there so I put the address for it as source /opt/OpenFOAM-v1706/etc/bashrc. After OFPlus installation got finished I cannot find where it has been installed, it's not in opt folder. I am sure that it is installed correctly since after installation finished immediately I ran the test case mentioned on the webpage for the check, but now I cannot find where are the solvers, tutorials, and all other folders are located. |
July 16, 2017, 18:44 |
Rep Power: 8 |
Solved, the issue was that it did not get installed in opt folder however, it was in home/openFOAM directory and I had to refer to this directory in my bashrc as
alias OFPlus='source /home/soes/OpenFOAM/OpenFOAM-v1706/etc/bashrc' |
openfoam |
how do i fix installation error of ansys 19.0 on ubuntu 18.04 | rid_taki | ANSYS | 15 | June 7, 2021 06:32 |
LaminarSMOKE installation error: cannot find #include OpenSMOKEpp | sahmed | Main CFD Forum | 2 | November 6, 2018 01:19 |
[OpenFOAM] Use one installation of preview / ParaFoam for all versions of OpenFoam | cfd___ | ParaView | 0 | December 20, 2016 10:51 |
Installation of two versions side by side | umar82088 | OpenFOAM Installation | 1 | May 23, 2013 18:51 |
Installation paraFoam - still problem | nhl | OpenFOAM Installation | 7 | June 22, 2010 09:22 |
