[OpenFOAM.com] v1706 having difficulties getting started and unable to locate folders
Old   July 8, 2017, 14:47
Default v1706 having difficulties getting started and unable to locate folders
efstratioskrit is on a distinguished road
Hello all!!
When I try to open OpenFOAM_Start I get the following message.
What should I do?
efstratioskrit is offline   Reply With Quote
Old   July 21, 2017, 15:21
Default unable to locate folders
Hello NEWBIE WITH LINUX HERE!!!!!
I am having problems with the openfoam file directory. I can not find the applications folder anywhere! My opt folder is empty (I am running ubuntu on vmware). When I run OpenFOAM (./startOpenFOAM) and type the location of solvers folder at bash-4.2$ $FOAM_SOLVERS it returns
bash: /opt/OpenFOAM/OpenFOAM-v1706/applications/solvers: Is a directory
bash-4.2$
but when I try to find it via files I can't because as I said opt folder is empty!
and also when I type the location at a new terminal it says no such file or directory.
I am totaly frustrated. Your help will be deaply appreciated!!!!
The fl process could not be started because of UDF majid_kamyab Fluent UDF and Scheme Programming 6 December 15, 2015 08:42
Parallel Error in ANSYS FLUENT 12 zeusxx FLUENT 25 July 17, 2015 04:40
