[OpenFOAM.org] Problem Installing OpenFOAM V 2.3.1 in Ubuntu 17.04
Old   August 30, 2017, 12:51
Default Problem Installing OpenFOAM V 2.3.1 in Ubuntu 17.04
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hi All,
I have installed the latest version of Ubuntu, Version 17.04 and then when I tried to install OpenFoam V 2.3.1 from OpenFoamwiki https://openfoamwiki.net/index.php/I...M-2.3.1/Ubuntu, I got the following error;
make: Target 'application' not remade because of errors.
I have attached the log.make file so that it would be easy to track the error. I would be so thankful for any help to get it installed.
Thank you very much,
tareqkh is offline   Reply With Quote
Old   September 2, 2017, 10:10
Retired Super Moderator
Bruno Santos
Quick answer: I looks like you didn't follow the instructions to the letter. In the log file there are indications that the option "-j" was used with Allwmake, which does not work on OpenFOAM 2.3.1.
Please use the same exact commands as instructed on that wiki page.
Beyond that, I have not tested those instructions on Ubuntu 17.04, therefore I don't know if they work well or not.
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
[OpenFOAM.com] Problem installing Openfoam from source. Allwmake doesn't work artymk4 OpenFOAM Installation 1 December 4, 2018 17:03
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 14:24
[OpenFOAM.org] Problem of openFOAM 2.3.1 installation in Ubuntu 14.04LTS mukut OpenFOAM Installation 9 January 19, 2015 00:48
Installing OpenFOAM 2.2.0 on Ubuntu 12.10 i686 AHutchison OpenFOAM Installation 6 June 4, 2013 12:11
