[OpenFOAM.org] compile OpenFOAM v5 source on Ubuntu 1706?
Like Tree1Likes
  • 1 Post By wyldckat
Old   August 20, 2017, 10:55
Default compile OpenFOAM v5 source on Ubuntu 1706?
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Dear OpenFOAMers,
I am wondering if anyone posted steps on how to compile OpenFOAM v5 source codes on UBuntu 1706?
I tried to following the steps for OpenFOAM v4.1 on Ubuntu 1606, but, the steps did not work for v5 on Ubuntu 1706.
Thanks!
Pei
phsieh2005 is offline   Reply With Quote
Old   August 25, 2017, 13:57
Retired Super Moderator
Bruno Santos
Quick answer: The official installation instructions are provided here: https://openfoam.org/download/5-0-source/
They don't provide step-by-step instructions as detailed as the ones at openfoamwiki.net, but if people don't complain about the official ones, then the current format will stay as-is.
As for the ones that are provided at openfoamwiki.net, I haven't had the time+patience to write and test the installation of OpenFOAM 5.0. However, I have revised and updated the ones for OpenFOAM-dev here: https://openfoamwiki.net/index.php/I...OAM-dev/Ubuntu
Although I haven't tried using Ubuntu 17.04 yet... and there are a few bugs in how makeParaView works on the "ThirdParty-5.0" package, which should use instead the one from "ThirdParty-5.x". I will try to look into this during this weekend.
phsieh2005 likes this.
Old   August 26, 2017, 08:37
Pei-Ying Hsieh
Thanks a lot Bruno!
I will give the OpenFOAM-dev installation a try.
where should we post suggestion that a step-by-step instructions be provided? I think it is worth it to provide step-by-step instructions for people who are not experts in both linux and OpenFOAM.
Pei
Old   August 26, 2017, 14:57
Bruno Santos
Hi Pei,
For the distributions done by the OpenFOAM Foundation, you can report this on their bug tracker: https://bugs.openfoam.org
I do strongly suggest that you make a strong case on what specific improvements should be done to the instructions on the OpenFOAM Foundation website. Simply stating "we need official step-by-step instructions" will likely be disregarded.
As for the distributions done by ESI-OpenCFD, you can report this on their issue tracker: https://develop.openfoam.com/Develop...AM-plus/issues
The same protocol still applies, namely that a strong case should be made regarding the need to have step-by-step instructions.
Best regards,
Bruno
[waves2Foam] Tripping over several build issues with OpenFOAM 2.1.1 Yage OpenFOAM Community Contributions 18 February 15, 2016 02:02
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
Installation of OpenFOAM-1.6 on Ubuntu 9.10 marval OpenFOAM Installation 2 March 17, 2010 08:33
