[OpenFOAM.org] OpenFOAM-dev on CentOS 7.9: Segmentation Fault when executing any application
Like Tree5Likes
  • 1 Post By hendriks
  • 3 Post By wyldckat
  • 1 Post By funnyspell22
Old   February 22, 2022, 04:26
Default OpenFOAM-dev on CentOS 7.9: Segmentation Fault when executing any application
JNSN's Avatar
Jan
JNSN is on a distinguished road
Dear all,
I am facing a problem with a self compiled OpenFOAM-dev installation on a cluster running CentOS7.9:
As soon as there is any #include directive within the function list of the controlDict, every OpenFOAM application immediately exits with Segmentation fault (core dumped), as soon as it is called, even e.g. blockMesh -help
Compilation runs without any errror message. I used gcc7.3.1 from SCL devtoolset7, as the system gcc is verison 4.8.5, which does not support the c++14 option. I also tried clang version 7.0.1, with same result.
Does anyone have an idea? Of course I can avoid using includes, but thats not very convenient, and also I would like to understand, what's going on.
Thanks and best regards,
Jan
JNSN is offline   Reply With Quote
Old   March 18, 2022, 12:28
Hendrik Söhnholz
hendriks is on a distinguished road
Hello Jan,
I had the same problem recently.
I tried to compile OpenFOAM-9 on CentOS 7 with GCC 7.3.1 from
devtoolset-7. I also tried with GCC 9 and Clang from the RHEL package
llvm-toolset-7. In all cases I got segmentation faults.
I solved this by compiling GCC 5.5.0 and using this to compile
OpenFOAM-9.
Unfortunately, the OpenFOAM developers don't specify which compilers
they use or have tested. The information on the website is outdated.
Best wishes,
Hendrik
JNSN likes this.
hendriks is offline   Reply With Quote
Old   March 21, 2022, 10:01
JNSN's Avatar
Jan
Hi Hendrik,
thanks a lot for your reply! As soon as I find the time, I will compile GCC 5.5.0 and use it for building OF.
Best regards,
Jan
Old   October 7, 2022, 11:18
Retired Super Moderator
Bruno Santos
FYI: Solution for this specific problem reported here, in order to be able to use SCL's GCC builds: https://bugs.openfoam.org/view.php?id=3898
In a nutshell:
  1. Edit the file "src/OpenFOAM/db/dictionary/entry/entryIO.C"
  2. Go to line 159:
                     && functionName == functionEntries::inputSyntaxEntry::typeName
  3. Change to this:
                      && functionName == functionEntries::inputSyntaxEntry::typeName_()
  4. Save and close.
  5. Build OpenFOAM, no cleaning required, simply run Allwmake as per installation instructions.
hswzzz, Raphael_Santos and czzz like this.
Old   February 21, 2023, 13:37
Oliver stone
poltushima is on a distinguished road
That segmentation fault issue is frustrating, especially when you're trying to include directives in the controlDict. I've seen similar issues before and usually, and it's usually due to compatibility issues between different compilers. Have you tried reaching out to the OpenFOAM community for help? They might have some insights into what's causing the issue.
Also, CentOS 7 is reaching its end of life soon, so it'll stop receiving security updates and bug fixes. You may consider upgrading to a newer version with Extended Lifecycle Support (ELS).
poltushima is offline   Reply With Quote
Old   April 15, 2023, 16:58
Smile
Matt
funnyspell22 is on a distinguished road
In a nutshell:
  2. Go to line 159:
  3. Change to this:
  4. Save and close.
Finally, had spent two days compiling different gcc and mpi versions of OpenFOAM 9 on CentOS7 and this is what fixed everything. Thanks so much!
Raphael_Santos likes this.
funnyspell22 is offline   Reply With Quote
Old   October 2, 2023, 13:52
Raphael Santos
Raphael_Santos is on a distinguished road
Thank you very much! It worked!
Raphael_Santos is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel francesco OpenFOAM Bugs 4 May 2, 2017 21:59
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 14:53
'Segmentation fault: 11' on running application in parallel ulfaslak OpenFOAM Running, Solving & CFD 2 November 27, 2013 07:57
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
