[OpenFOAM.org] v6: Problems installing paraFoam |
January 3, 2019, 06:11 |
Paul Johnston
Rep Power: 7 |
Hi
I have to install OpenFoam on Centos 7.5 (no don't ask!) and following issues with the graphics I have moved to building from source. I'm using openfoam-6 The actual openfoam is okay but issues with installing openFoam I have a work around at the bottom but was wondering if anyone has the same issue. Installing paraView /paraFoam As per notes https://openfoam.org/download/source...arty-software/ Code:
[paulj@pjux3 ThirdParty-6]$ ./makeParaView ... Code:
... [ 99%] Linking CXX shared library ../../lib/libNonOrthogonalSource.so [ 99%] Built target paraview [ 99%] Built target NonOrthogonalSource make: *** [all] Error 2 Code:
[paulj@pjux3 ThirdParty-6]$ ./makeParaView -qmake $(which qmake-qt4) > log.makePV 2>&1 Code:
-------------- [ 99%] Compiling Qt help project StreamLinesRepresentation.qhp Error copying directory from "/home/paulj/OpenFOAM/ThirdParty-6/ParaView-5.4.0/Plugins/StreamLinesRepresentation/doc" to "/home/paulj/OpenFOAM/ThirdParty-6/build/linux64Gcc/ParaView-5.4.0/Plugins/StreamLinesRepresentation/doc". [ 99%] Compiling Qt help project NonOrthogonalSource.qhp ------------------------- As a consequence Code:
[paulj@pjux3 cavity]$ paraFoam FATAL ERROR: ParaView reader module libraries do not exist Please build the reader module before continuing: cd $FOAM_UTILITIES/postProcessing/graphics/PVReaders ./Allwclean ./Allwmake Code:
[paulj@pjux3 PVReaders]$ ./Allwmake Allwmake applications/utilities/postProcessing/graphics/PVReaders ERROR: ParaView not found in /home/paulj/OpenFOAM/ThirdParty-6/platforms/linux64Gcc/ParaView-5.4.0 Code:
[paulj@pjux3 ~]$ ls /home/paulj/OpenFOAM/ThirdParty-6/platforms/ linux64GccDPInt32 I copied the paraFoam from my Ubuntu box and initially got: Code:
[paulj@pjux3 cavity]$ ~/paraFoam & [1] 28895 [paulj@pjux3 cavity]$ FATAL ERROR: The official reader module for OpenFOAM data does not exist on your system. This means that the version of ParaView you are using was not compiled with OpenFOAM, or distributed with a packaged version of OpenFOAM. For information on packaged versions of OpenFOAM/ParaView and compilation of OpenFOAM/ParaView, see https://openfoam.org/download Alternatively, you might be able to view your OpenFOAM data with the reader module provided with ParaView by running: paraFoam -builtin [1]+ Exit 1 ~/paraFoam Code:
[paulj@pjux3 cavity]$ ~/paraFoam -builtin Created temporary 'cavity.foam' Last edited by wyldckat; January 5, 2019 at 15:00. Reason: Added [CODE][/CODE] markers |
January 6, 2019, 08:56 |
#2 | |
Mark Olesen
Rep Power: 40 |
With "paraFoam -builtin" you are really only doing this: Code:
touch case.foam paraview case.foam rm case.foam |
January 6, 2019, 16:14 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick request @paulj: Any chance you can attach the complete log file (zipped, so it can be attached) to your next post?
I ask this because I have built OpenFOAM 6 and ParaView 5.4 on CentOS 7.5 without problems, as detailed here: https://openfoamwiki.net/index.php/I...7.5_.281804.29
January 7, 2019, 10:45 |
Attachment as requested
Paul Johnston
Rep Power: 7 |
Here it is
January 8, 2019, 17:34 |
Bruno Santos
Rep Power: 128 |
Quick answer: I knew this was really strange, given that I had managed to build without problems on CentOS 7.5...
So what I found from the log file you've shared is that CMake 3.11 or newer is being used, instead of CMake 2.8.12. Allow me to explain:
My guess is that you've somehow installed CMake 3.12 from EPEL and then enforced /usr/bin/cmake to be the same as /usr/bin/cmake3, either through a symbolic link or something else. Perhaps it's the RPM itself that did this. But unfortunately, this is what broke the build. There are two possible workarounds:
January 9, 2019, 04:05 |
Version of cmake
Paul Johnston
Rep Power: 7 |
Hi
I did this because initially I got Code:
[paulj@pjux3 ThirdParty-6]$ ./makeParaView ParaView-5.4.0 exists. Not downloading... ParaView_SOURCE_DIR=/home/paulj/OpenFOAM/ThirdParty-6/ParaView-5.4.0 ParaView_BINARY_DIR=/home/paulj/OpenFOAM/ThirdParty-6/build/linux64Gcc/ParaView-5.4.0 ParaView_DIR=/home/paulj/OpenFOAM/ThirdParty-6/platforms/linux64Gcc/ParaView-5.4.0 sed: can't read /home/paulj/OpenFOAM/ThirdParty-6/ParaView-5.4.0/VTK/Utilities/kwsys/kwsysDateStamp.cmake: No such file or directory date-stamp: Build stages selected --------------------- -config true -make true -install true --------------------- Features selected mesa false mpi false python false qt true --------------------- Version information qt 4.8.7 version 5.4.0 major 5.4 build Release MISMATCH! specified 5.4.0 found --------------------- removing old build directory /home/paulj/OpenFOAM/ThirdParty-6/build/linux64Gcc/ParaView-5.4.0 ---- Configuring paraview-5.4.0 (major version: 5.4) MPI support : false Python support : false MESA support : false Qt dev support : true Source : /home/paulj/OpenFOAM/ThirdParty-6/ParaView-5.4.0 Build : /home/paulj/OpenFOAM/ThirdParty-6/build/linux64Gcc/ParaView-5.4.0 Target : /home/paulj/OpenFOAM/ThirdParty-6/platforms/linux64Gcc/ParaView-5.4.0 Build type : Release ---- cmake -DCMAKE_INSTALL_PREFIX:PATH=/home/paulj/OpenFOAM/ThirdParty-6/platforms/linux64Gcc/ParaView-5.4.0 -DBUILD_SHARED_LIBS:BOOL=ON -DVTK_USE_RPATH:BOOL=OFF -DPARAVIEW_INSTALL_DEVELOPMENT_FILES:BOOL=ON -DBUILD_TESTING:BOOL=OFF -DPARAVIEW_BUILD_QT_GUI=ON -DPARAVIEW_QT_VERSION=4 -DVTK_RENDERING_BACKEND=OpenGL2 -DCMAKE_BUILD_TYPE:STRING=Release /home/paulj/OpenFOAM/ThirdParty-6/ParaView-5.4.0 ---- CMake Error at CMakeLists.txt:31 (cmake_minimum_required): CMake 3.3 or higher is required. You are running version 2.8.12.2 -- Configuring incomplete, errors occurred! [paulj@pjux3 ThirdParty-6]$ Last edited by wyldckat; January 9, 2019 at 17:19. Reason: Added [CODE][/CODE] markers |
January 9, 2019, 17:24 |
Bruno Santos
Rep Power: 128 |
Quick answer: My apologies, I should have read my own instructions on the wiki more carefully
I had left in the system's "cmake" in the instructions, but after that, there are steps on how to compile CMake 3.9.0 from source code. Please try the following commands, after activating the OpenFOAM shell environment: Code:
cd $WM_THIRD_PARTY_DIR mkdir download wget -P download https://www.cmake.org/files/v3.9/cmake-3.9.0.tar.gz tar -xzf download/cmake-3.9.0.tar.gz ./makeCmake > log.makeCmake 2>&1 wmRefresh |
January 10, 2019, 08:13 |
Result
Paul Johnston
Rep Power: 7 |
Working fine now!
[OpenFOAM] Unable to launch parafoam & | boonhow | ParaView | 5 | March 23, 2022 08:09 |
[OpenFOAM] Problems running paraFoam with OpenFOAM 6: "Illegal instruction (core dumped)" | nwm | ParaView | 1 | December 22, 2018 09:47 |
[OpenFOAM.org] Problems to install openfoam-2.4.0 on Ubuntu 16.04.01LTS | matheusmonjon | OpenFOAM Installation | 3 | February 25, 2017 14:46 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 | arieljeds | OpenFOAM Installation | 6 | August 19, 2015 07:39 |
Problems installing CFX on Sun Unix Platform | Haley | CFX | 2 | November 9, 2001 09:52 |
