[OpenFOAM.org] Can't find openfoam directory, ubuntu in windows 10 |
January 26, 2019, 14:41 |
Jay
Linux rookie here (a couple of simple pi builds). I'm following the openfoam user manual. Installed Ubuntu into Win10 from the MS app store. Solved connection issues by temporarily disabling AV/FW, then apt-get OF6 worked, downloaded a ton, then installed, then it looked like it installed successfully. I can't find the files or diectories.
I'm in the command line, ls doesnt show subfolders. So I mkdir a test folder and then ls does show the test folder but nothing else. I'm hoping my problem is obvious to someone more experienced. |
January 26, 2019, 15:22 |
Jay
EDIT: Ok making progress...
January 27, 2019, 15:08 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: Don't jump directly to section 2.1, please first read and go through the instructions given at the start of chapter 2: https://cfd.direct/openfoam/user-guide/v6-tutorials/
If the commands that rely on "$FOAM_RUN" do not work, then it's because the OpenFOAM shell environment was not activated, so make sure to first activate it by running: Code:
source /opt/openfoam6/etc/bashrc
install |
Ansys Licence Serve on Ubuntu 16.04 LTS | david.pasquale | ANSYS | 2 | January 20, 2017 11:52 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
Caelus: fork of OpenFOAM | cnsidero | OpenFOAM Announcements from Other Sources | 7 | November 11, 2014 22:55 |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 10:22 |
