[OpenFOAM.org] Error while installing OpenFOAM on RHEL 7.3 based OS |
February 5, 2019, 01:55 |
Shashank
Rep Power: 11 |
While trying to install OF 5.x. I am getting following error
common_file_uncompress.c:65:18: fatal error: zlib.h: No such file or directory #include "zlib.h" Code:
./Allwmake > log.make 2>&1 We are following the below steps for installing OpenFOAM5.x https://openfoamwiki.net/index.php/I...7.4_.281708.29 Kindly guide us for installation. |
February 5, 2019, 16:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick question: Did you run the following command as root?
yum install zlib-devel
February 20, 2019, 23:55 |
Shashank
Rep Power: 11 |
Thanks for your reply I could get past zlib
However, I am now stuck at the next command while building Paraview. I use the command: Code:
./makeParaView -mpi -python -qmake $(which qmake-qt4) > log.makePV 2>&1 Following is the error I get: Code:
no qmake-qt4 in (/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin:/bin:/sbin:/home/awplab-7920/.local/bin:/home/awplab-7920/bin) |
February 22, 2019, 20:13 |
Bruno Santos
Rep Power: 128 |
Quick questions:
March 6, 2019, 00:25 |
#5 | |
Shashank
Rep Power: 11 |
Answer 1. Yes I installed it using the Code:
yum install zlib-devel Code:
yum install qt-devel Code:
Transaction check error: file /usr/lib64/libGLdispatch.so.0 from install of libglvnd-1:1.0.1-0.8.git5baa1e5.el7.x86_64 conflicts with file from package nvidia-375.20-x86_64.el7.1.x86_64 file /usr/lib64/libGLX.so.0 from install of libglvnd-glx-1:1.0.1-0.8.git5baa1e5.el7.x86_64 conflicts with file from package nvidia-375.20-x86_64.el7.1.x86_64 file /usr/lib64/libOpenGL.so.0 from install of libglvnd-opengl-1:1.0.1-0.8.git5baa1e5.el7.x86_64 conflicts with file from package nvidia-375.20-x86_64.el7.1.x86_64 file /usr/lib64/libGLESv1_CM.so.1 from install of libglvnd-gles-1:1.0.1-0.8.git5baa1e5.el7.x86_64 conflicts with file from package nvidia-375.20-x86_64.el7.1.x86_64 file /usr/lib64/libGLESv2.so.2 from install of libglvnd-gles-1:1.0.1-0.8.git5baa1e5.el7.x86_64 conflicts with file from package nvidia-375.20-x86_64.el7.1.x86_64 Code:
yum install libGLU-devel Code:
yum install qt-assistant Code:
No package qt-assistant available. Error: Nothing to do Last edited by wyldckat; March 6, 2019 at 19:42. Reason: removed broken HTML code and replaced HTML markers for CODE markers |
March 6, 2019, 19:50 |
#6 | |
Bruno Santos
Rep Power: 128 |
Quick answers:
March 7, 2019, 11:57 |
Shashank
Rep Power: 11 |
Thanks Bruno.
Updating to RHEL 7.6 solved the problem!!! I first uninstalled the nvidia drivers which were conflicting, using the command yum uninstall nvidia followed by yum upgrade yum update |
of5.x, rhel 7.3, zlib error |
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 21, 2016 11:50 |
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | September 14, 2016 03:19 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
[OpenFOAM.org] Installing OpenFOAM 2.1.0 on ROCKS cluster | aerospain | OpenFOAM Installation | 6 | December 15, 2014 03:35 |
