[OpenFOAM.org] Installation of openfoam 6 on Ubuntu 18.04 |
March 7, 2019, 11:52 |
Eric Murphy
Rep Power: 7 |
Greetings,
I am having problems following the installation of openfoam 6 on my Ubuntu 18.04 build. I should note that there are different mpi's in use on my machine and are in use for different software. I have installed using the directions of I solved the error of "gcc: error: unrecognized command line option ‘--showme:link’; did you mean ‘--force-link’?", when mpirun was called by adding "export WM_MPLIB=OPENMPI" to the file /opt/openfoam6/etc/prefs.sh. This file of course was copied into that director from /opt/openfoam6/etc/config.sh/example/. However, now when attempting to run a parallel case I obtain, interFoam: symbol lookup error: /opt/openfoam6/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so: undefined symbol: pthread_create. Any recommendations on how to remedy this would be appreciated. Serial computations work fine. |
March 7, 2019, 18:32 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer:
errors, installation of openfoam, mpi |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[OpenFOAM.org] OpenFOAM 3.0.1 installation on Ubuntu 14.04 | Hrushi | OpenFOAM Installation | 6 | July 8, 2017 18:47 |
[OpenFOAM.org] OpenFoam 3.0 installation on Ubuntu 14.04.3 | tab2001ng | OpenFOAM Installation | 3 | March 8, 2016 01:38 |
Problem? with Installation of OpenFOAM 2.1.0 on to Ubuntu 10.4.4 VirtualBox | Stubby | OpenFOAM Installation | 8 | March 5, 2012 15:12 |
openFOAM installation in ubuntu 11.10 | kirubhakaran | OpenFOAM Installation | 5 | February 17, 2012 02:16 |
