[OpenFOAM.org] OF7 compiling error on RHEL 6.5
Like Tree4Likes
  • 2 Post By wyldckat
  • 1 Post By ssdoria
  • 1 Post By ssdoria
Old   July 24, 2019, 14:47
Default OF7 compiling error on RHEL 6.5
Sidney Doria
ssdoria is on a distinguished road
I'm using a RHEL 6.5 with GCC 8.2 and OF6 compiles well, but OF7 throws the following:
wmake dummy
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3  -DNoRepository -ftemplate-depth-100   -IlnInclude -I. -I/opt/share/OpenFOAM/OpenFOAM-7/src/OpenFOAM/lnInclude -I/opt/share/OpenFOAM/OpenFOAM-7/src/OSspecific/POSIX/lnInclude   -fPIC -fuse-ld=bfd -shared -Xlinker --add-needed -Xlinker --no-as-needed /opt/share/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/UPstream.o /opt/share/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/UIPread.o /opt/share/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/src/Pstream/dummy/UOPwrite.o -L/opt/share/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib \
            -lpthread  -o /opt/share/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/dummy/libPstream.so
collect2: fatal error: cannot find 'ld'
compilation terminated.
make: *** [/opt/share/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/lib/dummy/libPstream.so] Error 1
GCC version:
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/opt/share/gcc/8.2.0/libexec/gcc/x86_64-pc-linux-gnu/8.2.0/lto-wrapper
Target: x86_64-pc-linux-gnu
Configured with: ./configure --disable-multilib --enable-languages=c,c++,fortran --with-isl=/opt/share/isl/0.18/ --with-mpc=/opt/share/mpc/1.0.3/ --with-mpfr=/opt/share/mpfr/3.1.4/ --with-gmp=/opt/share/gmp/6.1.0/ --prefix=/opt/share/gcc/8.2.0/
Thread model: posix
gcc version 8.2.0 (GCC)
ld version:
ld -v
GNU ld version 2.20.51.0.2-5.36.el6 20100205
Last edited by wyldckat; July 25, 2019 at 18:59. Reason: Added [CODE][/CODE] markers
ssdoria is offline   Reply With Quote
Old   July 25, 2019, 19:02
Retired Super Moderator
Bruno Santos
Quick answer:
  1. Edit these two text files in OpenFOAM-7:
    wmake/rules/linux64Gcc/c++
  2. Remove from the last two lines in that file the following argument:
    -fuse-ld=bfd
  3. Try building OpenFOAM once again.
This is because the conventional installations of GCC+Binutils will provide the gold and bfd variants of ld, but your installation only has the bfd one apparently.
Knowing how you install GCC+Binutils would make it easier to figure out in which situations we need this change.
AnthonyP and anon_q like this.
Old   July 25, 2019, 22:34
Default It worked like a charm!
Sidney Doria
Bruno, it worked like a charm. Thanx a lot.
Obrigadão. Abri uma garrafa de ginja em sua homenagem! Abraços,
gabrielfelix likes this.
Old   July 27, 2019, 09:13
Bruno Santos
You're welcome. Please also let us know how GCC+Binutils in that machine.
Old   July 27, 2019, 20:33
Sidney Doria
binutils-2.20.51.0.2-5.36.el6.x86_64
Gcc is 8.2 loaded by module. This is an HPC.
module unload
gcc/8.2.0 isl/0.18 mpfr/3.1.4 paraview/4
gmp/6.1.0 mpc/1.0.3 openmpi/3.1.2 zlib/1.2.8
gcc -v
COLLECT_GCC=gcc
wrapper
Thread model: posix
wyldckat likes this.
Old   August 3, 2019, 14:36
Bruno Santos
@ssdoria: Many thanks! OK, then it's a custom build done by the HPC system administrators... I guess that the "binutils" they custom built only has a single ld, hence the error.
of7, rhel6
[OpenFOAM.org] Error when compiling OF 5.x in RedHat 6.5 agustinvo OpenFOAM Installation 2 May 31, 2018 08:47
[OLAFLOW] wmake error when installing on RHEL 6.5 Lewis Liang OpenFOAM Community Contributions 10 November 26, 2016 10:10
[OpenFOAM.org] problems with installation of OpenFOAM-2.1.1 on cluster with RHEL 6.5 lisa_china OpenFOAM Installation 1 March 29, 2016 08:08
Fluent compliance with RHEL 4 hervé FLUENT 2 January 25, 2006 04:39
