[foam-extend.org] Fluid Structure Interaction Toolkit on foam extend 4.0
Old   January 21, 2020, 12:26
Default Fluid Structure Interaction Toolkit on foam extend 4.0
Bazinga is on a distinguished road
Hey,
I am following this page for the installation (running ubuntu 16.04):
https://openfoamwiki.net/index.php/E...oam-extend_4.0
I wanted to test the beamInCrossFlow tutorial. Everything works smoothly as far as I can tell until Allwmake tries "wmake libso setInletVelocity". Here I get the error message
SOURCE=setInletVelocity.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I../../../../src/fluidSolidInteraction/lnInclude     -I/opt/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/opt/foam/foam-extend-4.0/src/finiteArea/lnInclude     -I/opt/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/opt/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/opt/foam/foam-extend-4.0/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/opt/foam/foam-extend-4.0/src/foam/lnInclude -I/opt/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setInletVelocity.o
/usr/bin/ld: cannot open output file /opt/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsetInletVelocity.so: Permission denied
collect2: error: ld returned 1 exit status
The log of the solver fsiFoam then also shows that the library was not successfully loaded.
Reference point coordinates: (0.45 0.15 -0.15)
--> FOAM Warning :
    From function dlLibraryTable::open(const fileName& functionLibName)
    in file db/dlLibraryTable/dlLibraryTable.C at line 124
    could not load libsetInletVelocity.so: cannot open shared object file: No such file or directory
--> FOAM FATAL ERROR:
Unknown function type setInletVelocity
Valid functions are :
1
pointHistory
Tried the HronTurekFsi3 too and similar problem with loading a library.
Not quite sure how I have to deal with the challenge of loading the library correctly.
Bazinga is offline   Reply With Quote
Old   August 17, 2020, 22:51
Default The smae problem with you
Shaobin CAI
sHpherd is on a distinguished road
Originally Posted by Bazinga View Post
Hey,
--> FOAM Warning :
1
pointHistory
Hi, Bazinga
I am facing the same problem with you now, when trying to use the fisFoam solver on HPC where I have no root permission. I guess this problem is probably caused due to the libsetInletVelocity.so is compiled into the root directory. Have you solved the problem or do you have idea about this problem?
Best wishes
sHpherd is offline   Reply With Quote
Fluid structure interaction with VOF method utilized in fluent? mxl9549 ANSYS 0 July 22, 2016 13:40
Fluid structure interaction with VOF method utilized in fluent? mxl9549 FLUENT 0 July 22, 2016 13:39
Fluid Structure interaction prince_pahariaa FLUENT 3 March 19, 2013 12:16
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
