[OpenFOAM.com] Installing OpenFOAM with MPICH |
November 6, 2019, 04:56 |
Rep Power: 10 |
Hello!
I am trying to install with mpich3.2 in CentOS7. I made couple of changes in the root folder. In etc/bashrc, I have changed the following Code:
export WM_MPLIB=MPICH Code:
MPICH) export FOAM_MPI=mpich-3.2 export MPI_ARCH_PATH=/home/D/mpich-3.2/install export MPI_HOME=$MPI_ARCH_PATH export FOAM_MPI_LIBBIN=$FOAM_LIBBIN/mpich-3.2 # Could be sourced from ThirdParty with incomplete environment if command -v _foamAddLibAuto > /dev/null 2>&1 # Normal sourcing then _foamAddPath $MPI_ARCH_PATH/bin _foamAddMan $MPI_ARCH_PATH/share/man _foamAddLib $MPI_ARCH_PATH/lib fi ;; Code:
/home/D/foam/OpenFOAM-v1812/src/OpenFOAM/lnInclude/IOobject.H:497:14: note: because ‘Foam::IOobject’ has user-provided ‘void Foam::IOobject::operator=(const Foam::IOobject&)’ 497 | void operator=(const IOobject& io); | ^~~~~~~~ In file included from /home/D/foam/OpenFOAM-v1812/src/OpenFOAM/lnInclude/postProcess.H:131, from coldEngineFoam.C:55: ../XiFoam/createFields.H: In function ‘int main(int, char**)’: ../XiFoam/createFields.H:3:9: error: ‘psiuReactionThermo’ was not declared in this scope 3 | autoPtr<psiuReactionThermo> pThermo | ^~~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:3:27: error: template argument 1 is invalid 3 | autoPtr<psiuReactionThermo> pThermo | ^ ../XiFoam/createFields.H:5:5: error: ‘psiuReactionThermo’ is not a class, namespace, or enumeration 5 | psiuReactionThermo::New(mesh) | ^~~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:7:21: error: ‘thermo’ was not declared in this scope; did you mean ‘pThermo’? 7 | psiuReactionThermo& thermo = pThermo(); | ^~~~~~ | pThermo ../XiFoam/createFields.H:7:38: error: ‘pThermo’ cannot be used as a function 7 | psiuReactionThermo& thermo = pThermo(); | ^ ../XiFoam/createFields.H:10:1: error: ‘basicSpecieMixture’ was not declared in this scope 10 | basicSpecieMixture& composition = thermo.composition(); | ^~~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:10:21: error: ‘composition’ was not declared in this scope 10 | basicSpecieMixture& composition = thermo.composition(); | ^~~~~~~~~~~ In file included from /home/D/foam/OpenFOAM-v1812/src/OpenFOAM/lnInclude/postProcess.H:131, from coldEngineFoam.C:55: ../XiFoam/createFields.H:78:9: error: ‘laminarFlameSpeed’ was not declared in this scope 78 | autoPtr<laminarFlameSpeed> unstrainedLaminarFlameSpeed | ^~~~~~~~~~~~~~~~~ ../XiFoam/createFields.H:78:26: error: template argument 1 is invalid 78 | autoPtr<laminarFlameSpeed> unstrainedLaminarFlameSpeed | ^ ../XiFoam/createFields.H:80:5: error: ‘laminarFlameSpeed’ is not a class, namespace, or enumeration 80 | laminarFlameSpeed::New(thermo) I would like to know if I need to change anything else apart from these values. Thanks for your time. |
December 4, 2019, 17:06 |
Herpes Free Engineer
Rep Power: 12 |
Hmmm.. let's issue a ticket in the issue tracker in GitLab.
Any further information you can provide regarding your compilation?
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 13, 2019, 03:14 |
Rep Power: 10 |
Thanks for the reply!
Let me know the information will be required and helpful to identify the error? I have used GCC 9 and MPICH 3.2 for compilation. |
December 20, 2019, 11:56 |
Rep Power: 12 |
I assume you've downloaded the mp* package into the ThirdParty dir?
December 25, 2019, 19:17 |
One workaround
LUQILIN
Rep Power: 10 |
I have run into the same problem but I have figured it out on Ubuntu 18.04. But I bet it will work on Centos 8 as well. Here is what I propose, you may want to install Openmpi alongside with the MPICH compiled from source. And once you got a way to switch back and forth, Problem solved! I suggest using "bash", which is a way to edit your ~/.bashrc or ~/.profile.
Add following lines to .bashrc ## switch between mpich and openmpi use_mpi () { shopt -s nocaematch case "$1" in mpich) export PATH=/home/to/your/MPICH/bin:$PATH openmpi) export PATH=/usr/bin:$PATH ;; *) return 1 ;; esac shopt -u nocasematch } After adding those lines, type 1. "source ~/.bashrc" to activate the commands; 2. "use_mpi mpich" will allow you to use mpich in the current terminal; 3. "use_mpi openmpi" will allow you to use openmpi. Then you can handle different versions of MPI on your system (not limited to two, could be three, four, ..., etc) . I feel this is more elegant other than messing with OpenFoam source code before you are an advanced user. Hope this will help you. |
January 18, 2020, 05:13 |
Rep Power: 10 |
January 18, 2020, 05:20 |
#7 | |
Rep Power: 10 |
I was able to install OpenFOAM with IntelMPI. Thanks for your help! Will try and get back to you. |
mpich |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
[waves2Foam] A few notes about problems and solutions when installing with OpenFOAM v1712 | oceanFoam | OpenFOAM Community Contributions | 0 | June 22, 2018 08:52 |
[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster | hello177 | OpenFOAM Installation | 1 | April 24, 2016 08:35 |
question about installing Openfoam 1.6-ext | Haotian | OpenFOAM Installation | 2 | November 17, 2013 18:47 |
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 | wyldckat | OpenFOAM Announcements from Other Sources | 3 | September 8, 2010 06:25 |
