[OpenFOAM.org] Openfoam 6 on Centos 7.7 - makeParaview error.
Old   January 21, 2020, 06:54
Default Openfoam 6 on Centos 7.7 - makeParaview error.
ssa
ssa_cfd is on a distinguished road
Hi all,
I followed the instructions on https://openfoamwiki.net/index.php/Installation/Linux/OpenFOAM-6/CentOS_SL_RHEL#CentOS_7.5_.281804.29
when running the below command, I got error.
./makeParaView -mpi -python -qmake $(which qmake-qt4) > log.makePV 2>&1
errors:
collect2: error: ld returned 1 exit status
make[2]: *** [lib/site-packages/mpi4py/MPI.so] Error 1
make[1]: *** [VTK/ThirdParty/mpi4py/vtkmpi4py/CMakeFiles/mpi4py.MPI.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
ssa_cfd is offline   Reply With Quote
Old   January 26, 2020, 14:56
Damian Berghof
virengos will become famous soon enough
I did the same few weeks ago and had some trouble with the right qt configuration, if I remember correctly, since my experimental machine has crashed yesterday
I configured the most libs in a conda python environment and run the building process inside of it.
Can you post the entire log file?
best,
Damian
Get more support about Meshing with Salome and Visualization with ParaView in my growing groups
https://bit.ly/2lFfDkQ
https://bit.ly/2k2u8Pj
virengos is offline   Reply With Quote
Old   January 27, 2020, 11:03
ssa
I attach you the log file.
I think the problem is not with Qt.
I read in the below thread that I should patch the paraview. But those commands are not working with this paraview version 5.4.
https://www.cfd-online.com/Forums/paraview/129356-building-paraview-4-1-0-mpi-python-support.html#post480315
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 06:25
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 04:53
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 09:40
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
