March 6, 2020, 06:04 |
swak4Foam installation error
Kabir Shariff
Rep Power: 9 |
I am trying to install swak4Foam to enable me use the groovyBC for my pulsating flow. I followed the steps for installation but the ./Alwmake is not compiling. I get this message Thank you. %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% Previously compiled for OpenFOAM (7) /home/kbshariff/swak4Foam/privateRequirements/bin existing. Prepending to PATH-variable (private version of Bison) No file 'swakConfiguration'. Python etc won't work. See README for details Try 'ln -s swakConfiguration.automatic swakConfiguration' for automatic configuration. BEWARE: this does not work on some systems Checking swak4Foam-version and generating file abort: no repository found in '/home/kbshariff/swak4Foam' (.hg not found)! Swak version is 0.4.1 Bison is version 2.7.12-4996 Flex is version 2.6.4 (Minor version: 4) OpenFOAM-version: Major 7 Minor 0 Patch -1 (-1 == x / 98) Fork: openfoam No change to swak4FoamParsers/foamVersion4swak.H wmake libso swak4FoamParsers g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -IMake/linux64GccDPInt32Opt -I/opt/openfoam7/src/finiteVolume/lnInclude -I/opt/openfoam7/src/surfMesh/lnInclude -I/opt/openfoam7/src/sampling/lnInclude -I/opt/openfoam7/src/fileFormats/lnInclude -I/opt/openfoam7/src/triSurface/lnInclude -I/opt/openfoam7/src/dynamicMesh/lnInclude -I/opt/openfoam7/src/lagrangian/basic/lnInclude -I/opt/openfoam7/src/surfMesh/lnInclude -I/opt/openfoam7/src/meshTools/lnInclude -I../filesThatAreOnlyInSomeDistributions/OutputFilerDropin/ -IlnInclude -I. -I/opt/openfoam7/src/OpenFOAM/lnInclude -I/opt/openfoam7/src/OSspecific/POSIX/lnInclude -fPIC -c helpers/exprString.C -o Make/linux64GccDPInt32Opt/helpers/exprString.o In file included from lnInclude/CommonValueExpressionDriver.H:847:0, from helpers/exprString.C:39: lnInclude/CommonValueExpressionDriverI.H: In member function ‘bool Foam::CommonValueExpressionDriver::updateSet(Foam: :autoPtr<T>&, const Foam::word&, Foam::CommonValueExpressionDriver::SetOrigin) const’: lnInclude/CommonValueExpressionDriverI.H:326:32: error: ‘class Foam::IOobject’ has no member named ‘headerOk’ header.headerOk() ^~~~~~~~ lnInclude/CommonValueExpressionDriverI.H:336:43: error: ‘class Foam::IOobject’ has no member named ‘filePath’; did you mean ‘rootPath’? << header.filePath() ^~~~~~~~ rootPath /opt/openfoam7/wmake/rules/General/transform:25: recipe for target 'Make/linux64GccDPInt32Opt/helpers/exprString.o' failed make: *** [Make/linux64GccDPInt32Opt/helpers/exprString.o] Error 1 Parser library did not compile OK. No sense continuing as everything else depends on it Requirements for Library not satisfied. I see no sense in going on Check the README before you go on to ask. And search: Most likely your problem occured to 5 other people before and has been solved on the MessageBoard |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 18:11 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 06:35 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
