[foam-extend.org] Fluid Structure Interaction Toolkit on foam extend 4.0 |
January 21, 2020, 12:26 |
Rep Power: 15 |
Hey,
I am following this page for the installation (running ubuntu 16.04): https://openfoamwiki.net/index.php/E...oam-extend_4.0 I wanted to test the beamInCrossFlow tutorial. Everything works smoothly as far as I can tell until Allwmake tries "wmake libso setInletVelocity". Here I get the error message Code:
SOURCE=setInletVelocity.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-200 -I../../../../src/fluidSolidInteraction/lnInclude -I/opt/foam/foam-extend-4.0/src/finiteVolume/lnInclude -I/opt/foam/foam-extend-4.0/src/finiteArea/lnInclude -I/opt/foam/foam-extend-4.0/src/meshTools/lnInclude -I/opt/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude -I/opt/foam/foam-extend-4.0/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/opt/foam/foam-extend-4.0/src/foam/lnInclude -I/opt/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/setInletVelocity.o /usr/bin/ld: cannot open output file /opt/foam/foam-extend-4.0/lib/linux64GccDPOpt/libsetInletVelocity.so: Permission denied collect2: error: ld returned 1 exit status Code:
(...) Reference point coordinates: (0.45 0.15 -0.15) --> FOAM Warning : From function dlLibraryTable::open(const fileName& functionLibName) in file db/dlLibraryTable/dlLibraryTable.C at line 124 could not load libsetInletVelocity.so: cannot open shared object file: No such file or directory --> FOAM FATAL ERROR: Unknown function type setInletVelocity Valid functions are : 1 ( pointHistory ) (...) Not quite sure how I have to deal with the challenge of loading the library correctly. |
August 17, 2020, 22:51 |
The smae problem with you
#2 | |
Shaobin CAI
Rep Power: 7 |
I am facing the same problem with you now, when trying to use the fisFoam solver on HPC where I have no root permission. I guess this problem is probably caused due to the libsetInletVelocity.so is compiled into the root directory. Have you solved the problem or do you have idea about this problem? Best wishes |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | ANSYS | 0 | July 22, 2016 13:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 13:39 |
Fluid Structure interaction | prince_pahariaa | FLUENT | 3 | March 19, 2013 12:16 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 04:04 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
