Failed wmake
Old   April 1, 2022, 12:06
Default Failed wmake
SAIKAT SARKAR
SAIKATmac is on a distinguished road
saikat@SAIKATSARKA9BF8:~/OpenFOAM/OpenFOAM-v2012/tutorials/basic/laplacianFoam/6/conduction$ laplacianFoam
| \\ / O peration | Version: v2012 |
| \\ / A nd | Website: www.openfoam.com |
| \\/ M anipulation | |
Build : _7bdb509494-20201222 OPENFOAM=2012
Arch : "LSB;label=32;scalar=64"
Exec : laplacianFoam
Date : Apr 01 2022
Time : 10:57:10
Host : SAIKATSARKA9BF8
PID : 6020
I/O : uncollated
Case : /home/saikat/OpenFOAM/OpenFOAM-v2012/tutorials/basic/laplacianFoam/6/conduction
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
SIMPLE: no convergence criteria found. Calculations will run for 0.09 steps.
Reading field T
Reading diffusivity DT
No finite volume options present
Calculating temperature distribution
Reading set description:
lineZ
lineX1
lineX2
lineX3
lineX4
Using dynamicCode for functionObject totalHeatRate at line 111 in "/home/saikat/OpenFOAM/OpenFOAM-v2012/tutorials/basic/laplacianFoam/6/conduction/system/controlDict.functions.totalHeatRate"
Could not load "/home/saikat/OpenFOAM/OpenFOAM-v2012/tutorials/basic/laplacianFoam/6/conduction/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libtotalHeatRate_f20066b31204778858c702a93d600fbc5 5a710a7.so"
/home/saikat/OpenFOAM/OpenFOAM-v2012/tutorials/basic/laplacianFoam/6/conduction/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libtotalHeatRate_f20066b31204778858c702a93d600fbc5 5a710a7.so: cannot open shared object file: No such file or directory
Invoking wmake libso /home/saikat/OpenFOAM/OpenFOAM-v2012/tutorials/basic/laplacianFoam/6/conduction/dynamicCode/totalHeatRate
/home/saikat/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 637: make: command not found
/home/saikat/OpenFOAM/OpenFOAM-v2012/wmake/wmake: line 640: make: command not found
wmake error: file '/home/saikat/OpenFOAM/OpenFOAM-v2012/build/linux64Gcc63DPInt32Opt/tutorials/basic/laplacianFoam/6/conduction/dynamicCode/totalHeatRate/sourceFiles' could not be created in /home/saikat/OpenFOAM/OpenFOAM-v2012/tutorials/basic/laplacianFoam/6/conduction/dynamicCode/totalHeatRate
--> FOAM FATAL IO ERROR: (openfoam-2012)
Failed wmake "dynamicCode/totalHeatRate/platforms/linux64Gcc63DPInt32Opt/lib/libtotalHeatRate_f20066b31204778858c702a93d600fbc5 5a710a7.so"
From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
in file db/dynamicLibrary/codedBase/codedBase.C at line 201.
FOAM exiting
SAIKATmac is offline   Reply With Quote
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 01:36
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 13:28
user defined function cfduser CFX 0 April 29, 2006 10:58
