January 1, 2019, 13:20 |
FATAL Error Paraview
Hi all,
I'm having this trouble with paraview and I can't run it. If I type: Code:
$ paraFoam FATAL ERROR: The official reader module for OpenFOAM data does not exist on your system. This means that the version of ParaView you are using was not compiled with OpenFOAM, or distributed with a packaged version of OpenFOAM. For information on packaged versions of OpenFOAM/ParaView and compilation of OpenFOAM/ParaView, see https://openfoam.org/download Alternatively, you might be able to view your OpenFOAM data with the reader module provided with ParaView by running: paraFoam -builtin Code:
paraFoam -builtin Created temporary 'run.foam' ********************************************************** ParaView failed to open using available graphics hardware. Trying fallback to software rendering using MESA. ********************************************************** /opt/openfoam-dev/bin/paraFoam: 67: /opt/openfoam-dev/bin/paraFoam: paraview: not found I'm using LinuxMint 19.1 cinnamon. thx for any help |
January 1, 2019, 13:58 |
[Solved]
ok, problem solved by installing manually the .deb package from
http://dl.openfoam.org/ubuntu/dists/.../binary-amd64/ Regards. |
April 27, 2020, 09:09 |
#3 | |
denglichuan
May 28, 2020, 04:29 |
still confused
Rep Power: 5 |
since you haven't told us which .deb package you downloaded, I downloaded the newest version of openfoam and paraview...
turns out I'm still not able to solve my problem: I installed the paraview package, because I thought this is what wasn't working... openfoam couldn't be installed due to unmet dependencies can anybody help? and how do I make sure, that the new installed packages are at the right place from my earlier installed openfoam / directory? |
May 28, 2020, 17:32 |
Herpes Free Engineer
Rep Power: 12 |
- Could you please clarify your question? I didn't understand whether you try to install ParaView version with whatsoever. Thank you.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
June 5, 2020, 06:57 |
Rep Power: 5 |
I'm sorry, I'm totally new to ubuntu and my first error was like the one in this thread:
tessa@tessa-MacBook:~/OpenFOAM/tessa-7/run/cavity$ paraFoam & [1] 2472 tessa@tessa-MacBook:~/OpenFOAM/tessa-7/run/cavity$ FATAL ERROR: The official reader module for OpenFOAM data does not exist on your system. This means that the version of ParaView you are using was not compiled with OpenFOAM, or distributed with a packaged version of OpenFOAM. For information on packaged versions of OpenFOAM/ParaView and compilation of OpenFOAM/ParaView, see https://openfoam.org/download Alternatively, you might be able to view your OpenFOAM data with the reader module provided with ParaView by running: paraFoam -builtin second message: tessa@tessa-MacBook:~/OpenFOAM/tessa-7/run/cavity$ paraFoam -builtin Created temporary 'cavity.foam' /home/tessa/OpenFOAM/OpenFOAM-7/bin/paraFoam: 67: paraview: not found so I thought my problem is the same... but I'm not sure what's the problem and downloading the package didn't solve my problem - although I'm not sure whether what and how I did it was right... Sorry for so less knowledge. Hoping somebody can help me (: |
November 23, 2020, 12:08 |
Follow Up.
malcolm
I have the same problem that's in this thread and haven't been able to resolve it. I followed the instructions here: https://openfoam.org/download/8-ubuntu/
and have the same error message as the original poster. I'm in the same point as sunflowers. Can anyone offer a solution? |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
[snappyHexMesh] sHM: FATAL ERROR: More than six unsigned transforms detected | Djub | OpenFOAM Meshing & Mesh Conversion | 0 | July 15, 2014 04:43 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
