[OpenFOAM.org] unknown type name ‘off64_t’
Old   December 30, 2020, 10:55
Default unknown type name ‘off64_t’
Fabian Friberg
lumpor is on a distinguished road
I get the following output when running ./makeParaview on my 32-bit Ubuntu 18.04:
/home/pc/OpenFOAM/ThirdParty-7/ParaView-5.6.0/ThirdParty/cgns/vtkcgns/src/adf/ADF_internals.c:225:12: error: unknown type name ‘off64_t’
    typedef off64_t file_offset_t;
ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/build.make:182: recipe for target 'ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/adf/ADF_internals.c.o' failed
make[2]: *** [ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/adf/ADF_internals.c.o] Error 1
CMakeFiles/Makefile2:16607: recipe for target 'ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/all' failed
make[1]: *** [ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
[ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeUInt32Array.cxx.o
[ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeUInt64Array.cxx.o
[ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeFloat32Array.cxx.o
[ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeFloat64Array.cxx.o
[ 12%] Linking CXX shared library ../../../lib/libvtkCommonCore-pv5.6.so
[ 12%] Built target vtkCommonCore
Makefile:151: recipe for target 'all' failed
make: *** [all] Error 2
Command exited with non-zero status 2
1642.02user 124.75system 34:33.66elapsed 85%CPU (0avgtext+0avgdata 586548maxresident)k
17456inputs+443968outputs (60major+12097231minor)pagefaults 0swaps
Only the error message:
I tried to follow the steps for installing openfoam v7 via the source code.
Any help would be appreciated.
lumpor is offline   Reply With Quote
FOAM FATAL ERROR: Maximum number of iterations exceeded: 100 antoniomollo OpenFOAM Running, Solving & CFD 5 March 2, 2023 06:13
2DOF Planning hull resistance study with overset CFD_fan OpenFOAM Running, Solving & CFD 7 July 13, 2021 05:03
twoPhaseEulerFoam confined plunging jet simulation failed ves OpenFOAM Running, Solving & CFD 2 June 17, 2020 05:08
Foam::error::printStack(Foam::Ostream&) at ??:? mdhfiz OpenFOAM Running, Solving & CFD 1 September 19, 2019 09:46
Time step continuity error lpz_michele OpenFOAM Running, Solving & CFD 0 October 12, 2015 06:05
