December 30, 2020, 10:55 |
unknown type name ‘off64_t’
Fabian Friberg
Rep Power: 5 |
I get the following output when running ./makeParaview on my 32-bit Ubuntu 18.04:
/home/pc/OpenFOAM/ThirdParty-7/ParaView-5.6.0/ThirdParty/cgns/vtkcgns/src/adf/ADF_internals.c:225:12: error: unknown type name ‘off64_t’ typedef off64_t file_offset_t; ^~~~~~~ ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/build.make:182: recipe for target 'ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/adf/ADF_internals.c.o' failed make[2]: *** [ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/adf/ADF_internals.c.o] Error 1 CMakeFiles/Makefile2:16607: recipe for target 'ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/all' failed make[1]: *** [ThirdParty/cgns/vtkcgns/src/CMakeFiles/vtkcgns.dir/all] Error 2 make[1]: *** Waiting for unfinished jobs.... [ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeUInt32Array.cxx.o [ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeUInt64Array.cxx.o [ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeFloat32Array.cxx.o [ 12%] Building CXX object VTK/Common/Core/CMakeFiles/vtkCommonCore.dir/vtkTypeFloat64Array.cxx.o [ 12%] Linking CXX shared library ../../../lib/libvtkCommonCore-pv5.6.so [ 12%] Built target vtkCommonCore Makefile:151: recipe for target 'all' failed make: *** [all] Error 2 Command exited with non-zero status 2 1642.02user 124.75system 34:33.66elapsed 85%CPU (0avgtext+0avgdata 586548maxresident)k 17456inputs+443968outputs (60major+12097231minor)pagefaults 0swaps Code:
/home/pc/OpenFOAM/ThirdParty-7/ParaView-5.6.0/ThirdParty/cgns/vtkcgns/src/adf/ADF_internals.c:225:12: error: unknown type name ‘off64_t’ typedef off64_t file_offset_t; ^~~~~~~ Any help would be appreciated. Last edited by lumpor; December 31, 2020 at 04:52. |
FOAM FATAL ERROR: Maximum number of iterations exceeded: 100 | antoniomollo | OpenFOAM Running, Solving & CFD | 5 | March 2, 2023 06:13 |
2DOF Planning hull resistance study with overset | CFD_fan | OpenFOAM Running, Solving & CFD | 7 | July 13, 2021 05:03 |
twoPhaseEulerFoam confined plunging jet simulation failed | ves | OpenFOAM Running, Solving & CFD | 2 | June 17, 2020 05:08 |
Foam::error::printStack(Foam::Ostream&) at ??:? | mdhfiz | OpenFOAM Running, Solving & CFD | 1 | September 19, 2019 09:46 |
Time step continuity error | lpz_michele | OpenFOAM Running, Solving & CFD | 0 | October 12, 2015 06:05 |
