[OpenFOAM.com] Scotch error when installing Openfoam on an Ubuntu Virtualbox |
April 23, 2021, 18:18 |
#1 | |
Paul Antoine
Hi everyone,
I recently discovered Openfoam and find it a really interesting tool by itself and with all the other codes using it so I tried to install it on a clean new Virtualbox VM on Ubuntu x64 (I use .bashrc) to experiment some code based on OpenFOAM. I followed the different steps for OpenFOAM installation on my Ubuntu machine HERE (yes I wrote every steps carefully as there is always problems when I first try to install an open source program) : Quote:
I tried multiple times to change the OpenFOAM version, uninstalled and installed Scotch, but nothing works and I always still have the same error. I found on this forum the following post which seem close "HERE", but I tried the answers and it didn't worked. It seems like the installing procedure know that scotch is in the ThirdParty-7 folder but still try to find a part on my OpenFOAM-7 folder so I don't really understand how I can solve this problem as the "scotchDecomp" element doesn't seem to be in any of my folders. My file tree is as follows in $HOME/OpenFOAM (cf. second attachment) : Did anyone encountered this problem or may know how to solve it ? I am really new on Ubuntu and OpenFOAM as I am just getting started and I would really need some help if someone would be so kind Thank you and have a nice weekend. |
April 26, 2021, 08:32 |
Mark Olesen
Rep Power: 40 |
Probably the same as this question: OpenFOAM 6 installation: ptscotch.h file not found
Same answer (I think) - probably easiest is to simply use the precompiled binaries for ubuntu: https://develop.openfoam.com/Develop...ompiled/debian |
[OpenFOAM.com] Installing OpenFOAM 2.4.0 on Ubuntu 20.04 for Windows | RKyle | OpenFOAM Installation | 5 | January 25, 2022 10:45 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 on Ubuntu 12.04 | arieljeds | OpenFOAM Installation | 6 | August 19, 2015 07:39 |
[OpenFOAM.com] Problem installing OpenFoam 1.5 on Ubuntu 12.04???? | tareqkh | OpenFOAM Installation | 5 | July 19, 2015 15:10 |
[OpenFOAM.org] Problems installing OpenFOAM 2.3.0 in Ubuntu 14.04 | iafpython | OpenFOAM Installation | 8 | November 10, 2014 16:43 |
Trouble with installing OpenFOAM on Ubuntu | Milos | OpenFOAM Installation | 16 | November 16, 2009 02:44 |
