[OpenFOAM.org] Error while installing OF9 in Ubuntu22.04
Like Tree1Likes
  • 1 Post By night-hawk
Old   May 14, 2022, 03:46
Default Error while installing OF9 in Ubuntu22.04
VVN
Vijay
VVN is on a distinguished road
Need your help..
I am trying to install OF9 in virtualbox with Ubuntu22.04, but getting this error
vijay@vijay-VirtualBox: $ sudo add-apt-repository http://dl.openfoam.org/ubuntu [sudo] password for vijay:
Repository: 'deb http://dl.openfoam.org/ubuntu jammy matn' Description: Adding repository. Press [ENTER] to continue or Ctrl-c to cancel. Found existing deb entry in /etc/apt/sources.ltst.d/archive_urt-http_dl_open foam_org_ubuntu-jammy.list Adding deb entry to /etc/apt/sources.list.d/archive_urt-http_dl_openfoam_org_ubuntu-jammy.list Get:6 http://security.ubuntu.com/ubuntu jammy-security InRelease [110 kB] Reading package lists... Done
Archive for codename: jammy components: matn More info: http://dl.openfoam.org/ubuntu
Adding disabled deb-src entry to /etc/apt/sources.list.d/archive_urt-http_dl_open foam_org_ubuntu-jammy.list Hit:1 http://in.archive.ubuntu.com/ubuntu jammy InRelease
Hit:2 http://tn.archive.ubuntu.com/ubuntu jammy-updates InRelease Ign:3 http://dl.openfoam.org/ubuntu jammy InRelease
Hit:4 http://tn.archive.ubuntu.com/ubuntu jammy-backports InRelease Err:5 http://dl.openfoam.org/ubuntu jammy Release
404 Not Found [IP: 35.179.33.128 80]
E: The repository 'http://dl.openfoam.org/ubuntu jammy Release' does not have a Release file. N: Updating from such a repository can't be done securely, and is therefore disabled by default. N: See apt-secure(8) manpage for repository creation and user configuration details. vijay@vijay-VirtualBox: $
VVN is offline   Reply With Quote
Old   May 18, 2022, 11:24
Ashutosh
night-hawk is on a distinguished road
OpenFoam.org currently doesn't have binary package for Ubuntu22.04 (Jammy jellyfish). If you want to install OpenFoam use OpenFoam.com or compile it manually.
VVN likes this.
night-hawk is offline   Reply With Quote
Old   May 18, 2022, 14:30
VVN
Vijay
Thanks @night-hawk! You arr right..
Meanwhile I installed Ubuntu 20.04 LTS with Openfoam8 and it worked : )
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 11:58
SU2-7.0.1 on ubuntu 18.04 hyunko SU2 Installation 7 March 16, 2020 04:37
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 21:53
Install OF 1.6.ext on Arch based distribution miro2000 OpenFOAM Installation 4 October 9, 2013 14:39
My experience Installing Elmer (Open Source Multi physics programme) on Linux Ahmed Main CFD Forum 3 August 10, 2010 13:42
