[OpenFOAM.com] Error getting while installing openFoam 1606 on ubuntu22.04 |
September 9, 2023, 08:06 |
Swaraj Bhure
Hi community
I am trying to install openFoam-v1606 on ubuntu 22.04 using source code with help of https://openfoamwiki.net/index.php/I...1606%2B/Ubuntu commands from the above website. After putting the ./Allwmake command I am getting the following error: fileStat.C:78:13: error: ‘major’ was not declared in this scope 78 | major(status_.st_dev) == major(stat2.status().st_dev) | ^~~~~ fileStat.C:79:13: error: ‘minor’ was not declared in this scope 79 | && minor(status_.st_dev) == minor(stat2.status().st_dev) | ^~~~~ fileStat.C: In function ‘Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::fileStat&)’: fileStat.C:104:20: error: ‘makedev’ was not declared in this scope 104 | dev_t st_dev = makedev(stat[1], stat[2]); | ^~~~~~~ fileStat.C: In function ‘Foam::Ostream& Foam:perator<<(Foam::Ostream&, const Foam::fileStat&)’: fileStat.C:132:21: error: ‘major’ was not declared in this scope 132 | stat[1] = label(major(fStat.status_.st_dev)); | ^~~~~ fileStat.C:133:21: error: ‘minor’ was not declared in this scope 133 | stat[2] = label(minor(fStat.status_.st_dev)); | ^~~~~ In file included from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/token.H:46, from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/Istream.H:47, from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/ISstream.H:39, from /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/IOstreams.H:38, from fileStat.C:27: /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/typeInfo.H: In instantiation of ‘To& Foam::dynamicCast(From&) [with To = Foam::token::Compound<Foam::List<int> >; From = Foam::token::compound]’: /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/FixedListIO.C:58:13: required from ‘Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::FixedList<T, Size>&) [with T = int; unsigned int Size = 13]’ /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/FixedListIO.C:37:15: required from ‘Foam::FixedList<T, Size>::FixedList(Foam::Istream&) [with T = int; unsigned int Size = 13]’ fileStat.C:100:33: required from here /home/varphi/OpenFOAM/OpenFOAM-plus/src/OpenFOAM/lnInclude/typeInfo.H:91:5: warning: catching polymorphic type ‘class std::bad_cast’ by value [-Wcatch-value=] 91 | catch (std::bad_cast) | ^~~~~ make: * [/home/varphi/OpenFOAM/OpenFOAM-plus/wmake/rules/General/transform:8: /home/varphi/OpenFOAM/OpenFOAM-plus/platforms/linux64GccDPInt32Opt/src/OSspecific/POSIX/fileStat.o] Error 1. Please tell me, what should I do to resolve this error. @wyldkat |
openfoam installation |
Frequently Asked Questions about Installing OpenFOAM | wyldckat | OpenFOAM Installation | 3 | November 14, 2023 11:58 |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 15:54 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 05:40 |
[OpenFOAM.org] Installing OpenFoam 3.0.1 on cluster | hello177 | OpenFOAM Installation | 1 | April 24, 2016 08:35 |
Installing OpenFOAM 2.1.1 and ParaView 3.12.0 on Ubuntu 12.10 | wyldckat | OpenFOAM Installation | 14 | February 12, 2013 04:43 |
