[OpenFOAM.com] segmentation fault when running paraview after installed the OPENFOAM11 |
March 13, 2024, 03:38 |
Jungpin Chen
Rep Power: 2 |
Hi, Sir / Madam;
I had a “segmentation fault” (as following picture) when running paraview after installed the latest openfoam11 in ubuntu 22.04 WSL V2 environment under Window11 23H2. I follow exactly the procedures showed in the link (https://openfoam.org/download/windows/) to install OPENFOAM11 but it seems cannot run the paraview in Ubuntu. I had asked Paraview Forum and they suggest me to raise such question here at Openfoam forum. Anyone can help me with this is really appreciated! Thank you! |
March 18, 2024, 02:18 |
Anon42
Rep Power: 2 |
Hi
I have the same problem - have you found a solution? |
March 18, 2024, 04:55 |
Jungpin Chen
Rep Power: 2 |
nope! There is no solution yet!
March 18, 2024, 12:15 |
Anon42
Rep Power: 2 |
OK, please give an update if you should find a solution
March 18, 2024, 14:00 |
Mark Olesen
Rep Power: 40 |
why not simply use a windows binary for paraview?
March 18, 2024, 14:08 |
Anon42
Rep Power: 2 |
March 21, 2024, 03:45 |
Benico
same here:
Paraview 5.11 and 5.12 seg faults but paraview 5.6 and 510 is working fine (using nvidia 470 driver on ubuntu 22.04) Got all fixed with: sudo apt autoremove sudo apt purge paraview sudo apt autoremove sudo apt install paraview OOOPSY: if I run the paraviews on their own - then all is fine (have to "touch zzz.foam" and then manually open zzz.foam with paraview) BUT - running source /opt/openfoam11/etc/bashrc and THEN running paraFoam OR paraview ... makes everything crashes again. My Solution thus: Open paraview OR /opt/openfoam11/bin/paraFoam [separately in another terminal where the openfoam11/etc/bashrc] was NOT applied ... and manually open the case via zzz.foam Last edited by benico; March 21, 2024 at 04:17. Reason: fixed |
March 26, 2024, 02:01 |
my problem solved!
Jungpin Chen
Rep Power: 2 |
Hi, I got my problem solved. I can run the Paraview 5.10.1 from Ubuntu terminal now (no more segmentation fault). What I did were following procedures :
1. unregistered my original Ubuntu at Powershell, 2. re-install Ubuntu-20.04 from Powershell and 3. follow the openFOAM11 installation procedure again. Now, running Paraview 5.10.1 from Ubuntu terminal is OK. I leave this message in case someone want to try above procedures as I did. Hope this can help other’s question! |
openfoam11, paraview, segmentation fault |
[OpenFOAM] Paraview segmentation fault core dumped | GLfast80 | ParaView | 0 | March 13, 2021 12:53 |
[OpenFOAM.com] Problem when running Paraview on ubuntu bash for windows 10 | Nazim | OpenFOAM Installation | 0 | April 26, 2020 19:07 |
segmentation fault - parallel running | CrisMoreira | OpenFOAM Running, Solving & CFD | 13 | November 1, 2015 16:13 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
paraFoam reader for OpenFOAM 1.6 | smart | OpenFOAM Installation | 13 | November 16, 2009 21:41 |
