Cc1plus error libmpfrso1not found
Old   July 29, 2008, 05:48
Default Hello, I am installing Open
John Deas
johndeas is on a distinguished road
I am installing OpenFOAM 1.5 on an Ubuntu machine (8.04).
foamInstallationTest gave me the following message, where everything seems ok: http://www.pastebin.org/58125
However, when I try to recompile icoFoam as a test, I get the following error:
Making dependency list for source file icoFoam.C
SOURCE=icoFoam.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/opt/OF/OpenFOAM-1.5/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/OF/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/opt/OF/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/icoFoam.o
/opt/OF/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i686-pc-linux-gn u/4.3.1/cc1plus: error while loading shared libraries: libmpfr.so.1: cannot open shared object file: No such file or directory
make: *** [Make/linuxGccDPOpt/icoFoam.o] Error 1
It happens that, regardless of the context, any time I launch /opt/OF/ThirdParty/gcc-4.3.1/platforms/linux/bin/../libexec/gcc/i686-pc-linux-gn u/4.3.1/cc1plus even without arguments, I get the same errors.
So, if anybody as an idea on this, or has successfully installed Ubuntu on Ubuntu 8.04, I would be pleased to hear from you.
johndeas is offline   Reply With Quote
Old   July 29, 2008, 05:55
Default You need to install mpfr.
Eugene de Villiers
eugene is on a distinguished road
eugene is offline   Reply With Quote
Old   July 29, 2008, 08:26
Default Which I will do, thank you.
John Deas
I found it strange as I thought OpenFOAM was quite self-contained, and it is not written in the README to install it.
Old   July 29, 2008, 08:52
Default The problem is that linux is i
Eugene de Villiers
The problem is that linux is inherently not self-contained.
The issue you are having is with gcc-4.3.1 not OpenFOAM-1.5. Unfortunately, if you use gcc-4.2.1 (which doesn't use mpfr) then the paraview/Qt stack has problems.
I am trying to build an entirely self-contained stack. It is proving difficult. Components on my list so far:
binutils
mpfr
gmp
gcc-4.3.1
zlib
flex++
qt-4.3.5
cmake
ParaView-3.3
and a few other bits and bobs.
As you can see, quite a list. If I succeed (i.e. I don't throw up my hands in despair along the way), I will post the build script and some instructions. If anyone else manages it earlier, please let me know.
Old   July 29, 2008, 13:45
Default hello hope you're doing gr
victor
torvic is on a distinguished road
hello
hope you're doing great.
For if it could be of aid, I installed some of the packages above for 64 bits, on SLED 10 sp1
first gmp with these flags in the configure:
CC="cc" CFLAGS="-m64 -O2 -fomit-frame-pointer -mtune=k8 -march=k8" ABI=64
and installed it.
then mpfr, forcing the path of gmp-build directory, with the same flags in the configure as for gmp:
-with-gmp-build=/home/foam15/OpenFOAM/extra/gmp-4.2.2 CC="cc" CFLAGS="-m64 -O2 -fomit-frame-pointer -mtune=k8 -march=k8"
and installed it.
then gcc-4.3.1, but this time without making a subdirectory for the obj, just a separate one in the same path, and build from it. In my case i have a directory "gnu-cc" in which i extract the .tar.gz. make a "gcc-build" directory and from it i execute the configure, which in in my case was:
../gcc-4.3.1/configure --prefix=$HOME/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64 --exec-prefix=$HOME/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64 --enable-languages=c,c++ --enable-shared --disable-multilib --with-gmp=/usr/local --with-mpfr=/usr/local
and installed it.
once installed qt-4.3.5 i put it in the PATH and LD_LIBRARY_PATH, in the .bashrc
then ran buildParaview-cvs.
best
V
torvic is offline   Reply With Quote
Old   August 13, 2008, 11:27
Default Dear FOAMers, I am having d
Kevin Maki
kjmaki is on a distinguished road
Dear FOAMers,
I am having difficulty compiling gcc 4.3.1 on my redhat linux machine. I have built and installed gmp and mpfr as per the instructions by Victor, but the gmake bootstrap fails with gcc. The configure command that I am using is:
../gcc-4.3.1/configure --prefix=/k/kjmaki/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64
--exec-prefix=/k/kjmaki/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux64 --enable-languages=c,c++
--enable-shared --disable-multilib --with-gmp=/k/kjmaki/OpenFOAM/ThirdParty/gmp-4.2.3
--with-mpfr=/k/kjmaki/OpenFOAM/ThirdParty/mpfr-2.3.1
And the failure on the gmake bootstrap reads:
checking for suffix of object files... configure: error: cannot compute suffix of object files: cannot compile
See `config.log' for more details.
Where a snippet of the config.log reads:
conftest.c:2: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'me'
configure:3636: $? = 1
configure: failed program was:
| #ifndef __cplusplus
| choke me
| #endif
Does anyone have any advice?
THANKS!!!
Kevin
kjmaki is offline   Reply With Quote
Old   August 15, 2008, 03:34
Default Hi Kevin, I had the same erro
Francesco Del Citto
fra76 is on a distinguished road
Hi Kevin,
I had the same error on a Suse machine. I gave up and used OF 4.2.2 for compiling OpenFOAM 1.5 from sources, as I could not even use the precompiled version (neither gcc 4.31 nor OF).
I only had to modify a couple of lines of code. You should easily come up with them when the compilation fails!
Francesco
fra76 is offline   Reply With Quote
Old   August 15, 2008, 08:42
Default Hello Francesco, Thanks for
Kevin Maki
Hello Francesco,
Thanks for your reply. I was able to build gcc-4.3.1, by installing gmp and mpfr. It was necessary for me to update my LD_LIBRARY_PATH to find those libraries.
With that done, I have build 1.5 from source and life is getting better :-), on to ParaView.....
Kevin
Old   August 19, 2008, 05:52
Default Hi Kevin, If this is of int
Hrvoje Jasak
hjasak will become famous soon enough
Hi Kevin,
If this is of interest, I've got paraview-2.4.4 working with OpenFOAM-1.5. Presumably, this fixes your post-processing problem on a Mac, right.
Please let me know if you want details,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   August 28, 2008, 22:35
Default I am having problems installin
musaddeque hossein
musahossein is on a distinguished road
I am having problems installing paraview 3.3 in OpenFOam 1.5. It looks for libmpfr.so.1. Also mpfr is required. However I dont see a mpfr for Suse 10.0 (32 bit machine)on line. Does anyone have suggestions or willing to share a build they may have created themselves for installing Paraview?
Alternately, can anyone tell me if upgrading to Suse 11 will make the uphill battle of finding missing files go away?
Thanks
Musa
musahossein is offline   Reply With Quote
Old   August 29, 2008, 02:31
Default Hello Mussaddeque, on Suse
  #11
Markus Rehm
markusrehm is on a distinguished road
Hello Mussaddeque,
on Suse 11 everything worked fine for me. Only paraFoam is a little unstable, but with foamToVTK no problem. With the reader of Takuya (http://www.cfd-online.com/OpenFOAM_D...0478#POST19470) et works nicely. So I had to rebuild only paraview taking Niklas' post into account.
On SLES 10 SP2 it was a bit more complicated but following Victors suggestions from above it is running. I built GMP, MPFR, GCC, Qt-3.5, paraview.
Thank's Victor!
Regards Markus
markusrehm is offline   Reply With Quote
Old   August 29, 2008, 08:35
Default what is foamToVTK?
  #12
musaddeque hossein
what is foamToVTK?
Old   August 29, 2008, 11:17
Default Hello Markus, Musaddeque and a
  #13
victor
Hello Markus, Musaddeque and all the OF community
@Musa:
there's a thread in which Mark Olesen states the need to have MPFR and GMP, since they are required for the last version of the gnu-c compiler, gcc-4.3.1. check out the gnu-c website.
So, in SUSE 10 I think they are not included.
Since OpenSUSE 11 has QT 4.4, I think you have to install Qt-4.3.5 in order to have a working PAraview.
@Markus: Nice to hear you have paraview working. You're welcome..
best and enjoy your weekend
V
Old   August 29, 2008, 12:45
Default Does anyone know if Suse 11 ha
  #14
musaddeque hossein
Does anyone know if Suse 11 has MPFR and GMP? I have Suse 10.0. I dont want to have to install Suse 11 unless I absoulutely have to.
Old   August 29, 2008, 13:45
Default please note, only gcc 4.3.1 ne
  #15
Eugene de Villiers
please note, only gcc 4.3.1 needs mpfr. However, OpenFOAM-1.5 compiles just fine using the gcc shipped with the previous version of OpenFOAM. (4.2.2 I think?)
Old   August 29, 2008, 15:33
Default But the problem lies in trying
  #16
musaddeque hossein
But the problem lies in trying to install Paraview 3.3 on suse 10. It requries libmpfr which in turn requires mpfr and gmp. Please refer to post by victor:
http://www.cfd-online.com/cgi-bin/Op...6185#POST26185
Please correct me if I am wrong.
Thanks
Musa
Old   August 30, 2008, 12:20
Default Hi Victor, just one thing I
  #17
Markus Rehm
Hi Victor,
just one thing I contradict: I work with Suse 11 and the standard Qt-4.4 coming with it. As mentioned before I compiled it with Takuya's reader and applied the change mentioned by Niklas to make Qt-4.4 work. So OpenSuse 11 makes things a lot easier, I think.
Regards Markus
Old   September 1, 2008, 15:21
Default Hello @Markus: you're righ
  #18
victor
Hello
@Markus: you're right.
@Musa:I installed gcc-4.3.5, in order to compile Paraview under SLED 10. Didn't consider the hint of Eugene
best
V
Old   September 2, 2008, 22:22
Default Arright gentlemen, now I am ev
  #19
musaddeque hossein
Arright gentlemen, now I am even more confused. gcc-4.3.5? I went to the GNU-C site and the latest download is 4.3.2. Does anyone have the link where I can download gcc-4.3.5 from?
Thanks.
This is refernce to Victor's post at the following link:
http://www.cfd-online.com/cgi-bin/Op...6291#POST26291
Old   September 3, 2008, 18:28
Default Dear Musa My sincere apolog
  #20
victor
Dear Musa
My sincere apologies.
I did want to mean gcc-4.3.1.
I mixed QT version with that of gcc while writing the post.
best
V
injection not found in domain error San FLUENT 3 March 17, 2009 22:24
Error found in stress tutorial mike_jaworski OpenFOAM Running, Solving & CFD 0 September 23, 2007 02:34
Error: Finite angle gap could not be found Richard CFX 0 December 8, 2005 08:39
Boundaries not found error Simone Siemens 2 June 13, 2005 07:36
No warning or error messages found. Atit Koonsrisuk CFX 5 January 14, 2003 11:06
