OpenFOAM15 on Ubuntu810
Old   November 10, 2008, 14:17
Default Hi Guys, I am having troubl
Sumit Sinha
forsumit is an unknown quantity at this point
Hi Guys,
I am having trouble with the last step of installation of Open-FOAM. I am using Ubuntu-8.10.
I am able to install Open-FOAM but compilation of ParaView is giving me trouble. When I follow the steps mentioned in the download page it gives me the error about cmake file not found.
I have also tried the version 1.5.x and get the same results.
I installed Qt-4.3.4 which is working properly, I confirmed by typing in qtdemo.
Any help or suggestion will be greatly appreciated.
Thanks,
Sumit
forsumit is offline   Reply With Quote
Old   November 10, 2008, 16:37
Default Just to give a detail info of
Sumit Sinha
Just to give a detail info of the error message that I am getting.
Building ParaView3.3-cvs
MPI support : OFF
Python support : OFF
MESA support : OFF
Source : /home/sumit/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/sumit/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc
/home/sumit/OpenFOAM/OpenFOAM-1.5.x/bin/buildParaView3.3-cvs: 88: cmake: not found
make: *** No targets specified and no makefile found. Stop.
done
If any one got any hints, it will be greatly appreciated.
Thanks,
Sumit
Old   November 10, 2008, 16:51
Default sudo apt-get install cmake
Srinath Madhavan (a.k.a pUl|)
msrinath80 is on a distinguished road
msrinath80 is offline   Reply With Quote
Old   November 10, 2008, 17:03
Default Hey Srinath, Thanks for the
Sumit Sinha
Hey Srinath,
Thanks for the reply but now I am getting some other message.
MPI support : OFF
MESA support : OFF
CMake Error: Could not find CMAKE_ROOT !!!
CMake has most likely not been installed correctly.
Modules directory not found in
/home/sumit/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin
CMake Error: Error executing cmake::LoadCache(). Aborting.
done
Can help me further?
Thanks,
Sumit
Old   November 11, 2008, 13:06
Default Hi Sumit, I had a similar p
Gijsbert Wierink
gwierink is on a distinguished road
Hi Sumit,
I had a similar problem and installing Qt-4.3.5 fixed it.
Cheers, Gijsbert
Regards, Gijs
gwierink is offline   Reply With Quote
Old   November 12, 2008, 02:15
Default provided you have the right qt
Leonardo Honfi Camilo
lhcamilo is on a distinguished road
provided you have the right qt, you have to download the packages specified in this link
http://ubuntuforums.org/showpost.php...2&postcount=46
lhcamilo is offline   Reply With Quote
Old   November 12, 2008, 02:16
Default oh you might wanna make sure t
oh you might wanna make sure that you have "build-essential" package installed and installing cmake won't hurt either
Old   November 18, 2008, 04:26
Default Hi Guys, I have problem with
Dalibor
dado is on a distinguished road
Hi Guys,
I have problem with installing the OpenFoam (1.5.x) on the Ubuntu 8.10!
8.10 is coming with Qt4-4 and I don't know how to get the Qt4-3 version.
Then, I saw that the new version of the Para View is 3.4. Is it possible to install it instead for the v3.3 (without so much complications)?
Thanks,
Dado
dado is offline   Reply With Quote
Old   November 18, 2008, 04:46
Default ok, this mahy sound weird, I a
ok, this mahy sound weird, I am running I have a partition with hardy (8.04) and a partition with intrepid (8.10)[64 bit]. Obviously hardy runs without a hitch.Since I am preparing to dump my hardy partition soon in order to start testing the new release 9.04 (jaunty) I decided to test OF on intrepid. Since I didn't want to have to download all the files again I just copied all my OF-1.5 folder onto my intrepid /home (I did also edit the bashrc file). Oddly enough it worked, the paraFoam command loads paraview without a hitch.
I've run qmake and it does not show anyversion installed.
is it possible that it is still linked to the hardy files, or it just works? since I have some kde programs here I reckon some qt libraries should be installed.
if that doesn't work, you may just use the seach for packages engine in firefox to search for the appropriate hardy version packages.
Old   November 18, 2008, 08:15
Default Hi Dado! I don't know about
Assistant Moderator
Bernhard Gschaider
Hi Dado!
I don't know about Ubuntu, but I'm using paraview3.4 on my MacBook right now. The only modifications I had to do were:
- copy the buildParaview-script and modify it to have the right version number
- modify etc/apps/paraview3/bashrc (or cshrc if that is your drug of choice)
- start a new terminal
- compile paraview and the PV-plugin the way it is described in the README
Bernhard
PS: OK. I did some other modifications to the script, but those had to do with enabling Python
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 18, 2008, 19:55
Default Hi Dado, I just installed t
  #11
Su Xiaohui
sxhdhi is on a distinguished road
Send a message via Skype™ to sxhdhi
Hi Dado,
I just installed them sucessfully on Ubuntu8.10.
Actually I met the same problem as yours.
The solution is you have to download qt-x11-opensource-src-4.3.5.tar firstly, next,configure it to ~/ThirdParty/Qt4.3.5, make, then make install, at last follow the instruction in installation guide step 7.1 and 7.2.
try above steps you can get it.
Su Xiaohui
sxhdhi is offline   Reply With Quote
Old   November 19, 2008, 01:47
Default Thanks, I will try it when I a
  #12
Dalibor
Thanks, I will try it when I am at home.
Regards
/dado
Old   December 10, 2008, 20:27
Default Dear FOAMers: I tried to in
  #13
Pei-Ying Hsieh
hsieh is on a distinguished road
Dear FOAMers:
I tried to install OF-1.5 on 64 bit Ubuntu 8.10.
I have installed the following:
cmake, libmpfr-dev libmpfr1|db|, installed qt-4.3.5 to ThirdParty/Qt-4.3.5.
(qmake --version showed corrected Qt version - 4.3.5).
I still got the following error:
peiyinghsieh@ubuntu:~/OpenFOAM/ThirdParty$ qmake --version
QMake version 2.01a
Using Qt version 4.3.5 in /home/peiyinghsieh/OpenFOAM/ThirdParty/Qt-4.3.5/lib
peiyinghsieh@ubuntu:~/OpenFOAM/ThirdParty$ buildParaView3.3-cvs
MPI support : OFF
MESA support : OFF
Source : /home/peiyinghsieh/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /home/peiyinghsieh/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Gcc
/home/peiyinghsieh/OpenFOAM/ThirdParty/cmake-2.4.6/platforms/linux64/bin
done
On my SuSE 11.0 systems, I had no problem.
Any suggestion?
Pei
hsieh is offline   Reply With Quote
Old   December 11, 2008, 02:39
Default Doesn't paraview work out of t
  #14
Doesn't paraview work out of the box without having to compile on ubuntu 8.10, I have installed it on two ubuntu 8.10 boxes (amd64), with the latest qt (4.4.3) and they ran paraview (paraFoam) just fine. This also seems to be the case with fedora 10.
Old   December 12, 2008, 10:00
Default Hi, Leonardo, On my Ubuntu
  #15
Pei-Ying Hsieh
Hi, Leonardo,
On my Ubuntu 8.10 64, I was not able to run paraFoam. Also, display kinda looked strange when using paraview (after foamToVTK).
I tried Ubnutu 8.10 32 bit, and did not get the cmake error. Acutally, paraview starts to compile after comment out the Qt check (using native Qt (4.4.0?) intalled with Ubuntu). I will check if this completes paraview reader compilation too.
So, I suspect cmake under OpenFOAM/ThirdParty did not find correct library for 64 bit OS, hence causing the "CMake Error: Could not find CMAKE_ROOT !!! "
Pei
Old   December 13, 2008, 09:15
Default Hi, On Ubuntu 8.1 32 bit,
  #16
Pei-Ying Hsieh
On Ubuntu 8.1 32 bit, I was able to install Qt-4.3.5, and recompiled paraview and paraFoam successfully.
Next step is to find out how to resolve the CMAKE_ROOT error on 64 bit OS.
Pei
Old   December 22, 2008, 08:19
Default Hello OpenFOAM users,
  #17
Maruthamuthu Venkatraman
maruthamuthu_venkatraman is on a distinguished road
I just now started to instal Openfoam on my 32 bit system on UBUNTU platform. Iam new to LINUX and found difficulty in installing the same. I have 2 errors in the foaminstalltion test which is attached for your reference. If anybody could guide me then it will save my time.
Thanks,
Muthu
ERROR:
Shell: bash
Host: ubuntu
OS: Linux version 2.6.27-9-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/muthu/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/muthu/OpenFOAM/muthu-1.5 yes no
$WM_THIRD_PARTY_DIR /home/muthu/OpenFOAM/ThirdParty yes yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/muthu/OpenFOAM/OpenFOAM-1.5 yes yes yes
$FOAM_APPBIN ...M-1.5/applications/bin/linuxGccDPOpt yes yes yes
$FOAM_USER_APPBIN ...u-1.5/applications/bin/linuxGccDPOpt yes yes no
$WM_DIR /home/muthu/OpenFOAM/OpenFOAM-1.5/wmake yes yes yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...nFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt yes yes yes
$FOAM_USER_LIBBIN ...OpenFOAM/muthu-1.5/lib/linuxGccDPOpt yes yes no
$MPI_ARCH_PATH ...penmpi-1.2.6/platforms/linuxGccDPOpt yes yes yes
Third party software
Software Version Location
WARNING: gcc version does not match gcc supplied with this release of OpenFOAM
Supplied version: 4.3.1
User version : ../src/configure
4.3.2
Minimum required: 4.2.0
gcc ...figure
WARNING: Conflicting installations:
OpenFOAM settings : /home/muthu/OpenFOAM/ThirdParty/gcc-4.3.1/platforms/linux/bin/gcc
current path : /usr/bin/gcc
CRITICAL ERROR
gzip 1.3.12 /bin/gzip
tar 1.20 /bin/tar
icoFoam ...AM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/icoFoam
Checking networking...
Action Result Crit
Pinging_ubuntu Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Unsuccessful_connection_refused* yes
FATAL ERROR: No remote shell available.
OpenFOAM 1.5 enviroment requires either ssh and/or rsh.
Contact your system administrator.
The system test has evoked 1 fatal error(s).
The foam installation contains 1 critical error(s).
Review the output for warning messages and consult
the installation guide for trouble shooting.
done.
maruthamuthu_venkatraman is offline   Reply With Quote
Old   December 22, 2008, 08:45
Default Hello Mr.Maruthamuthu,
  #18
Suresh kumar Kannan
kumar is on a distinguished road
From the error message that you have posted I can see that the gcc version installed on your computer is not matching with the one required for OF-1.5. And the other error is due to ssh. You have to install ssh or rsh on your computer for remote connection.Just
# sudo apt-get install openssh-server openssh-client
this will install ssh on your computer.
If you look in the forum or search for a script to install OpenFOAM on UBUNTU. you can find a script to install OF-1.5. I used this script to install OF-1.5 on UBUNTU 8..
I suggest you to use this script. If you cannot find this script, let me know I will send you the location .
bye.
K.Suresh kumar
kumar is offline   Reply With Quote
Old   December 22, 2008, 08:46
Default You problems are not exaclty s
  #19
You problems are not exaclty serious, just go to a terminal windows and paste this
sudo apt-get install gcc
this should sort things out (there's another solution but I would rather not go there)
as for the other error, it has to do with ssh, unless you are going to use multiple computers in a network to calculate a case, then I wouldn't worry about it.
Old   December 22, 2008, 09:48
Default Hello, Thanks for your commen
  #20
Thanks for your comments. If you could send me the installation script location for OPENFOAM 1.5 suitable for UBUNTU 8.1 platform that would be useful to me.
I also found that ParaFOAM is not installed properly. To avoid all such bugs, let me install everything correctly by running the working script.
Note: i found one post in the following link . I am not sure will it be applicable for 8.10 Ubuntu.
http://www.cfd-online.com/OpenFOAM_D...tml?1222736035
Thanks
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
BuildParaView Error in Ubuntu810 liangyuly OpenFOAM Installation 2 February 26, 2009 02:08
Fedora 10 OpenFOAM15 philippose OpenFOAM Installation 7 February 18, 2009 04:37
ReconstructPar in OpenFOAM15 nicasch OpenFOAM Post-Processing 1 November 7, 2008 04:06
Updates for OpenFOAM15 olesen OpenFOAM Installation 9 July 18, 2008 03:18
