Problems while compiling OpenFOAM15 with OpenSuse 103
Old   November 5, 2008, 17:24
Default Dear Foamer, I downloaded t
Chuang Gao
coompressor is on a distinguished road
Dear Foamer,
I downloaded the software from the website. And followed the readme file to decompress all the files in the folder OpenFOAM and add the line . $HOME/OpenFoam/OpenFoam-1.5/etc/bashrc at the end of the file in the directory of my folder. At first, I just wanted to try the binary version without compilation. So I excute "fomaInstallationTest" to check my installation. And then it said "Base sysmte is ok", "critical system is ok". Then I copy the tutorial and run the three commands to run the cavity example see what happens.
1.first type blockMesh, fine. Mesh generated;
2.Type Icofoma, but with error of convergence times;
3. Then I type paraFoam, wa, a GUI interface appeared, however, it then gave me a warning that " A reader for cavity.openfoam couldn't be found" Then I've to close the window.
I don't what's going and the same problems occur on an Opensuse 11.0.
I'm quite a newbie, can any kind person help me?
3.
coompressor is offline   Reply With Quote
Old   November 6, 2008, 01:43
Default Hi, For the reader problem,
ep4
Pattyn Eric
ep4 is on a distinguished road
For the reader problem, a solution proposed in other posts is to convert the data in VTK format with the instruction foamToVTK and then run paraview in th VTK directory.
ep4 is offline   Reply With Quote
Old   November 6, 2008, 08:48
Default You can simply recompile the r
Francesco Del Citto
fra76 is on a distinguished road
You can simply recompile the reader, if you are lucky enough!
Try to go in the OpenFOAM installation directory:
OpenFOAM-1.5/applications/utilities/postProcessing/graphics/PV3FoamReader
then, call ./Allwmake
and cross your fingers...
Francesco
fra76 is offline   Reply With Quote
Old   November 7, 2008, 00:57
Default hi shixiong ,^-^, well, nice t
lding
daydayuper is on a distinguished road
hi shixiong ,^-^, well, nice to c u here
daydayuper is offline   Reply With Quote
Problems compiling OpenFOAM15 on Debian Etch geoffjay OpenFOAM Installation 1 February 5, 2009 16:29
GIT Compile of 15x on OpenSUSE 11 problems chrisd OpenFOAM Installation 2 January 30, 2009 12:25
Can anybody help me to solve the list errors while compiling Openfoam 15 on Opensuse 103 32bit coompressor OpenFOAM Installation 0 November 12, 2008 19:53
Dissimilarity in compiling new BC in 32bit OpenSuSE 103 versus 64bit CentOS 50 versus 64bit SLED 100 sponiar OpenFOAM Running, Solving & CFD 3 February 26, 2008 06:31
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 silent_missile OpenFOAM Installation 5 August 10, 2007 07:31
