OpenFOAM 15 icc build
Old   July 31, 2008, 10:44
Default I've recently been working on
Michael Schoenberg
mschoenberg is on a distinguished road
I've recently been working on installing OpenFOAM 1.5 on a 64-bit Linux machine. It's being installed in /tmp rather than the normal directory, and I would like to build it from source with icc. I've fixed a couple library linking issues, but one continues to elude me.
ld: cannot find -lrhoCentralFoam
Attempting to compile applications.solvers.compressible.rhoCentralFoam with Allwmake throws the following error:
SOURCE=U/maxwellSlipUFvPatchVectorField.C ; icpc -Dlinux64 -DDP -wd654,819,1125,1476,1505,1572 -xT -O3 -no-prec-div -DNoRepository -I/tmp/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/tmp/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/basic/lnInclude -I/tmp/OpenFOAM/OpenFOAM-1.5/src/thermophysicalModels/specie/lnInclude -IlnInclude -I. -I/tmp/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/tmp/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/maxwellSlipUFvPatchVectorField.o
U/maxwellSlipUFvPatchVectorField.C(160): error: type "Foam::fvPatchField<type>::fvPatchField [with Type=Foam::vector]" is not a class template
const GeometricField<scalar,>& vsfT =
This is followed by a large number of other errors which stem from the first, all involving GeometricField and FieldField, and all originating in maxwellSlipUFvPatchVectorField.C.
I'm not quite sure what's going on here, but any advice would be greatly appreciated.
mschoenberg is offline   Reply With Quote
Old   August 4, 2008, 12:18
Default No ideas? Shoot. I'm having
Michael Schoenberg
No ideas? Shoot. I'm having an additional problem with recompiling ParaView. When I invoke the build script, I get:
Building ParaView3.3-cvs
MPI support : OFF
Python support : OFF
MESA support : OFF
Source : /tmp/OpenFOAM/ThirdParty/ParaView3.3-cvs
Target : /tmp/OpenFOAM/ThirdParty/ParaView3.3-cvs/platforms/linux64Icc
CMake Error: ParaView requires an out of source Build. Please create a separate binary directory and run CMake there.
-- Configuring done
make: *** No targets specified and no makefile found. Stop.
done
I've looked in the build script and its functions, and though I'm unclear as to the source of the error, I notice that PARAVIEW_APP_DIR is never initialized in the build script or its functions. Is this the source of the issue? Any suggestions?
Old   August 7, 2008, 10:36
Default As an addendum, I've solved th
Michael Schoenberg
As an addendum, I've solved the ParaView problem - there was a CMakeCache file that was causing the issue.
Still not sure about the missing library.
Old   August 13, 2008, 11:40
Default I'm encountering another compi
Michael Schoenberg
I'm encountering another compiler error with fieldAverage.
SOURCE=fieldAverage/fieldAverage.C ; icpc -Dlinux64 -DDP -wd654,819,1125,1476,1505,1572 -O3 -no-prec-div -DNoRepository -I/home/michael/OpenFOAM/OpenFOAM-1.5/src/finiteVolume/lnInclude -I/home/michael/OpenFOAM/OpenFOAM-1.5/src/sampling/lnInclude -IlnInclude -I. -I/home/michael/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude -I/home/michael/OpenFOAM/OpenFOAM-1.5/src/OSspecific/Unix/lnInclude -fPIC -c $SOURCE -o Make/linux64IccDPOpt/fieldAverage.o
/home/michael/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/UListIO.C(76): error: no operator "!=" matches these operands
operand types are: const Foam::fieldAverageItem != const Foam::fieldAverageItem
if (L[i] != L[0])
detected during:
instantiation of "Foam:stream &Foam::operator<<(foam::ostream> &) [with T=Foam::fieldAverageItem]" at line 237 of "/home/michael/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/token.H"
instantiation of "void Foam::token::Compound<t>::write(Foam:stream &) const [with T=Foam::List<foam::fieldaverageitem>]" at line 83 of "/home/michael/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/typeInfo.H"
instantiation of "To &Foam::dynamicCast<to,from>(From &) [with To=Foam::token::Compound<foam::list<foam::fieldave rageitem>>, From=Foam::token::compound]" at line 70 of "/home/michael/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/ListIO.C"
instantiation of "Foam::Istream &Foam::operator>>(Foam::Istream &, Foam::List<t> &) [with T=Foam::fieldAverageItem]" at line 46 of "/home/michael/OpenFOAM/OpenFOAM-1.5/src/OpenFOAM/lnInclude/ListIO.C"
instantiation of "Foam::List<t>::List(Foam::Istream &) [with T=Foam::fieldAverageItem]" at line 173 of "fieldAverage/fieldAverage.C"
compilation aborted for fieldAverage/fieldAverage.C (code 2)
make: *** [Make/linux64IccDPOpt/fieldAverage.o] Error 2
Does fieldAverageItem not have equality operators?
Old   October 2, 2008, 00:09
Default Hello Michael, Have you sol
Guanghao Wu
guanghaowu is on a distinguished road
Hello Michael,
Have you solved the fieldAverage compile problem? I am encounting the same problem with the same error message.
Thanks in advance.
Guanghao
guanghaowu is offline   Reply With Quote
How can I build OpenFOAM in cygwin joywe OpenFOAM Installation 10 September 12, 2008 09:39
Build OpenFOAM on MacOSX Mauro Augelli (Augelli) OpenFOAM Installation 101 July 21, 2008 06:42
OpenFOAM 14 Parallel build mplongjr OpenFOAM Installation 3 May 15, 2007 03:32
OpenFOAM build from source instructions tj22 OpenFOAM Installation 7 April 6, 2006 16:15
Build OpenFOAM on Tru64 francois OpenFOAM Installation 18 April 4, 2006 05:45
