April 9, 2008, 08:32 |
Hello.
Is there a problem w
Sebastian Gatzka
Rep Power: 20 |
Hello.
Is there a problem with gcc? I have the following output from foamInstallationTest: Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc WARNING: Conflicting installations: foam settings: /home/sega/OpenFOAM/linux/gcc-4.2.1/bin/gcc current path : /usr/bin/gcc CRITICAL ERROR Thanks & Greetings
Schrödingers wife: "What did you do to the cat? It's half dead!" |
June 25, 2008, 01:09 |
I had the same problem install
Cesar Belaunde Zarate
I had the same problem installing OpenFoam 1.3 in Suse v10.3.
Any answer is a help. Thanks. Cesar. PD. I just unpacking (in linux64 directory) the gcc-4-1.0.linuxAMD64.tgz file, but I don't do any more else for install gcc, I should do something more? |
June 25, 2008, 02:43 |
Although I have this error I c
Sebastian Gatzka
Rep Power: 20 |
Although I have this error I can use OpenFOAM without problems.
VOF diffuse problem on two fluids problem | Fang Jin | FLUENT | 5 | February 17, 2011 05:38 |
Problem in Modelling Heat Transfer Problem | Deepak R | FLUENT | 1 | December 6, 2007 09:37 |
Problem in cavity flow problem | saad | Main CFD Forum | 4 | November 1, 2007 07:45 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
problem in solving "wave generation" problem | san | FLUENT | 2 | April 3, 2006 23:37 |
