Installing OpenFOAM
Old   April 8, 2008, 11:02
Default Hi, I would like to become
T Shoks
honcho is on a distinguished road
I would like to become better acquainted with the CFD world and have downloaded and installed OpenFOAM, but not been able to run it. I am hoping that someone will be able to help out. Here is a short list of the errors: 1. 'foamSystemCheck' - the program can not run Test_ssh and requires a passwordless connection. 2. 'foamInstallationTest' - it is unable to connect to the server. 3. 'runFOAMX' - it does not recognise the command 4. 'runFOAMXHB' - it can not access required libraries.
I have however been able to test-run an example using 'icoFOAM', but apart from that, nothing else. Even setting up a passphrase in 'ssh' has not helped.
Kindly advise on what you think the problem(s) is (are), and how you feel they can be solved.
Regards, Honcho.
honcho is offline   Reply With Quote
Old   April 9, 2008, 06:29
Default Hi Honcho, Post the listing f
dmoroian's Avatar
Dragos
dmoroian is on a distinguished road
Hi Honcho,
Post the listing from foamInstallationTest.
ssh is requested if you want to run in parallel.
FoamX is a very nice graphical user interface, but almost everybody runs in command line.
So basically, if you are able to run icoFoam, then you have a good enough installation.
Dragos
dmoroian is offline   Reply With Quote
Trouble with installing OpenFOAM on Ubuntu Milos OpenFOAM Installation 16 November 16, 2009 02:44
Pls help last problem to be solved for installing OPENfoam daydayuper OpenFOAM Installation 5 November 9, 2008 04:59
Installing OpenFOAM without Paraview quartzian OpenFOAM Installation 0 September 8, 2008 09:29
Problem installing OpenFOAM 141 sachin OpenFOAM Installation 2 February 22, 2008 10:20
Installing OpenFOAM on SuSE Linux 91 Lars Edvardsen (Edvardsen) OpenFOAM Installation 2 January 10, 2005 02:26
