FoamX binaries for CygwinWindows is now available
Old   November 11, 2006, 01:16
Default As I mentioned earlier in the
Takuya OSHIMA
7islands is on a distinguished road
As I mentioned earlier in the Preprocessing/FoamX board ( http://www.cfd-online.com/OpenFOAM_D...es/1/3287.html ), I've been doing a porting work of FoamX to Cygwin/Windows over the Unofficial OpenFOAM Cygwin Port. Now binary distribution is downloadable from the following URL.
http://www002.upp.so-net.ne.jp/ohshima/OpenFOAM/FoamX-cygwin/README-20061031.htm l
7islands is offline   Reply With Quote
Old   November 30, 2006, 01:02
Default HI Takuya: i have some questi
wayne.zhang
waynezw0618 is on a distinguished road
Send a message via MSN to waynezw0618 Send a message via Skype™ to waynezw0618
HI Takuya:
i have some question about installation of OpenFoam on cygwin. in my computer some tutorials of special application can not be open or creat new case of these application, for example cooles,boundaryFoam and so on. but no all. some of the application are quiet well for example IcoFoam.what is the problem?can you help me? thanks!
waynezw0618 is offline   Reply With Quote
Old   November 30, 2006, 05:39
Default I think I've had the same prob
Luca Gasparini
luca_g is on a distinguished road
I think I've had the same problem and it is related to the fact that in cygwin filenames are not case sensitive.
Thus, if you look in folder OpenFOAM-1.3\.OpenFOAM-1.3\apps\FoamX\entries\dimensionedScalar
you will see for example a file c1.cfg and a file C1_.cfg
The underscore has been added in the cygwin port to differentiate the upper case file from the lower case one but if you look for example at the file ...entries\turbulenceModels\incompressible\kEpsilo nCoeffs.cfg you will see that it is still pointing to a file C1.cfg
In cygwin this actually means c1.cfg which is not the right one.
You should thus edit the kEpsilonCoeffs.cfg file to point to C1_.cfg
You will find that there are a few similar situations and several files to edit...
Then opening a case with FoamX should work fine.
luca_g is offline   Reply With Quote
Old   December 1, 2006, 00:04
Default Hi Luca is there any rule or
wayne.zhang
Hi Luca
is there any rule or even patch file to make this change easy?
Old   December 1, 2006, 02:43
Default I've done it by hand; it is no
Luca Gasparini
I've done it by hand; it is not a big number of files that you must edit.
Basically each time you get an error from FoamX you go and edit the file which is causing the problem.
Old   December 1, 2006, 07:56
Default Hi wayng and Luca, Okay I u
Takuya OSHIMA
Hi wayng and Luca,
Okay I understand the errors you are talking about. Probably what wayng states is "invalid application class name" which seems to be caused by the lack of a config file in the solver directory (http://www.cfd-online.com/OpenFOAM_D...es/1/1698.html) and which is not a cygwin-specific behavior. Anyway actually I haven't realized all those problems until now because I've run just two or three cases. I'll provide a patch for what Luca states if I can make it.
Old   December 1, 2006, 12:25
Default Dear Takuya, one further po
Luca Gasparini
Dear Takuya,
one further point about your very interesting porting: until parafoam is not available it could be useful to include the foamToVTK dataconversion utility in the FoamX menu.
Infact, it seems to me that paraview 2.4.4 crashes when opening files generated with foamToEnsight but it works well with VTK files.
As you certainly know it is just a matter of including the FoamX folder with a foamToVTk.cfg file in the foamToVTK utility folder.
Old   December 2, 2006, 04:21
Default Hi Luca, it sounds a good idea
Takuya OSHIMA
Hi Luca, it sounds a good idea. I also experienced the same crash by foamToEnsight. I hope the native OpenFOAM reader module in the CVS version of paraview (http://www.cfd-online.com/OpenFOAM_D...es/1/3429.html) become usable soon (which still seems to have a little glitch).
Old   December 4, 2006, 06:30
Default hi Luca: i have read all the
wayne.zhang
hi Luca:
i have read all the .cfg files of lesinterfoam in$Home/OpenFoam/OpenmFoam1.3/applications/solvers/Multiphase/lesinterfoam/FoamX / and sub folder.i do not find any similar situations.is there any other problems?
waiting for your help
thanks!
Old   December 4, 2006, 08:45
Default Dear Wayng, just follow the
Luca Gasparini
Dear Wayng,
just follow the indications of the error message: it says "non-optional dictionary entry 'b'..." in "..FoamX/defaults/system/fvSolution::solvers".
So the problem is in the fvSolution.cfg file inside "..FoamX".
Infact, if you open the file you will see the following line:
include "$FOAMX_CONFIG/dictionaries/fvSolution/solvers/B.cfg";
If you check in the directory tree you will find that in the "..dictionaries/fvSolution/solvers" folder there actually is a "b.cfg" file (not the right one, we need the upper case) and a "B_.cfg" file.
So you need to edit the line to read like:
include "$FOAMX_CONFIG/dictionaries/fvSolution/solvers/B_.cfg";
Just do like this any time you find an error until it will work.
Old   December 12, 2006, 07:44
Default Hi Cygwin users, I'm happy
  #11
Takuya OSHIMA
Hi Cygwin users,
I'm happy to announce availability of the second version of FoamX-cygwin, FoamX-cygwin-20061212. Both source and binary distributions are available. Also, an update patch from the previous version, FoamX-cygwin-20061031, is available as there's no change in binary executables (just applying the patch will do). See the "Updating from the previous version" section in the following URL to update. I'd like to thank those who reported problems and gave suggestions as to the previous version.
The URL:
http://www002.upp.so-net.ne.jp/ohshima/OpenFOAM/FoamX-cygwin/README-20061212.htm l
What's new in FoamX-cygwin-20061212:
* Fix: FoamX doesn't allow to enter numbers in a non-English environment.
* Fix: Some tutorial cases refuse to open saying ``FoamXIOError "Non-optional dictionary entry '****' not found in dictionary ****::default"''.
* New: Now you can run FoamX in a csh (or tcsh) environment.
* New: Now you have the foamToVTK menu item in the FoamX right-click menu (Foam Utilities -> postProcessing -> dataConversion -> foamToVTK).
* Change: The binary distribution now includes iordump and nsadmin so that you can do some troubleshooting and administrative works (which is described in the section 5.1.1 of the User Guide).
* Change: The version of JDK which JAVA_HOME variable points to is updated to jdk1.5.0_10 from jdk1.5.0_09. If you'd like to continue to use jdk1.5.0_09, rewrite the JAVA_HOME line in $WM_PROJECT_DIR/.bashrc or .cshrc accordingly.
Old   December 21, 2006, 11:57
Default Hello, I am a total noob to
  #12
Ron Soule
rsoule is on a distinguished road
I am a total noob to this I normaly deal with standard windows programs. I am having a hard time setting OpenFoam up under MS windows. I have followed the instructions but I am still having problems. Is it possable that some one could write a detailed step by step instalation procedure under MS Windows. If its too much trouble then I understand.
Thanks for the help
Ron
rsoule is offline   Reply With Quote
Old   December 22, 2006, 19:36
Default Hello Ron, maybe you are makin
  #13
Takuya OSHIMA
Hello Ron, maybe you are making easy things (at least if you are familiar with basic usage of Cygwin) a little too difficult. It's true it takes some time but is basically a matter of downloading and unpacking the distribution files.
1. Downlaod and install the default Cygwin packages plus sed, make, cygutils and openssh packages using http://cygwin.com/setup.exe.
2. Download and install JDK 5.0 Update 10 which is available at http://java.sun.com/javase/downloads/index_jdk5.jsp with the default settings.
3. Download
OpenFOAM-1.3.cygwin-src-0.5.tar.gz
OpenFOAM-1.3.cygwin-bin-0.5.tar.gz
OpenFOAM-1.3.Docs.tar.gz
gcc-4.1.0.cygwin-OpenFOAM.tar.gz
from http://dpdx.net/openfoam-cygwin/ and
FoamX-cygwin-20061212.tar.bz2
from http://www002.upp.so-net.ne.jp/ohshima/OpenFOAM/FoamX-cygwin/README-20061212.htm l
into your home directory.
4. Issue the following commands from a Cygwin terminal.<pre> cd
mkdir OpenFOAM
cd OpenFOAM
tar -xzf ../OpenFOAM-1.3.cygwin-src-0.5.tar.gz
tar -xzf ../OpenFOAM-1.3.cygwin-bin-0.5.tar.gz
tar -xzf ../OpenFOAM-1.3.Docs.tar.gz
tar -jxf ../FoamX-cygwin-20061212.tar.bz2
mkdir cygwin
cd cygwin
tar -xzf ../../gcc-4.1.0.cygwin-OpenFOAM.tar.gz
cd
source ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc
~/OpenFOAM/OpenFOAM-1.3/postinstall.sh</pre>
5. If you want to start tutorials, do so by typing the followings.<pre> mkdir -p $FOAM_RUN
cp -r $FOAM_TUTORIALS $FOAM_RUN
FoamX</pre>
Old   January 2, 2007, 17:22
Default Thanks for the help. Your exp
  #14
Ron Soule
Thanks for the help. Your explanation helped but now I have new problems. Could you explaine the last and second to last line? And where should all the files be installed in the root C:/OpenFOAM drive? And the last question, it is looking for the path /usr/java/jdk1.4, Java dosen't install here, how is this fixed?
Thanks for the help
Ron
Old   January 2, 2007, 19:37
Default 1. Explanation of step 4: Typ
  #15
Takuya OSHIMA
Typing "cd" without argument (the first and eleventh line) takes you to your home directory (C:\cygwin\home\Ron or somewhere depending on your login name) and the "~" characters in the last two lines stand for your home directory. Just like the linux version of OpenFOAM you should install all the files to the OpenFOAM directory under your home directory (~/OpenFOAM), not under the root directory (C:\OpenFOAM). And beware that the order of unpacking the distribution fies matters; FoamX-cygwin-20061212.tar.bz2 must be unpacked after the other three OpenFOAM-1.3.* files have been unpacked.
2. Java path problem:
It usually should not happen so could you fix the above first and try again? If it does happen again could you give me some more details (as to what you did and what you get).
Old   January 3, 2007, 10:54
Default Again thanks for the help. I
  #16
Ron Soule
Again thanks for the help. I created the OpenFOAM directory in the following loacation (is this right). That is the home directory cygwin creates:
C:\Documents and Settings\rsoule1\
I followed you directions in the order given. When I try to run the "source ~/OpenFoam..." line i get the following error:
bash: [: too many arguments
Thanks for the help
Ron
Old   January 4, 2007, 06:23
Default Usually the Cygwin setup progr
  #17
Takuya OSHIMA
Usually the Cygwin setup program configures the home directory to be under C:\cygwin\home, but on occasion it seems to misconfigure it to be under C:\Documents and Settings just like your unfortunate case. Apparently OpenFOAM (including its initialization scripts) is not meant to be run under directory structure which contains whitespace in its pathname (such as "C:\Documents and Settings"), that might be the cause of the error (although I can't conclude). So could you try fixing the home directory carefully following the "Cygwin installing into wrong directory" thread in http://www.cygwin.com/ml/cygwin/2006...ads.html#00999 .
I hope all these things won't tire you out to give up
Old   February 6, 2007, 16:31
Default Thanks for posting the instruc
  #18
liamm
Thanks for posting the instructions as i was getting stuck with the windows install, however after following your instructions i'm still having a few problems that i hope someone can help me with.
After I type the last line ~/OpenFOAM/OpenFOAM-1.3/postinstall.sh I get the responce ":set WM_PROJECT_DIR and FOAMX_PATH" then when i type FoamX to open foamx it replies "bash: FoamX: Command not found" does anyone know what the problem is?
Thanks for yor help
Liam
Old   February 6, 2007, 19:03
Default Hi, To run postinstall.sh WM_
  #19
Takuya OSHIMA
To run postinstall.sh WM_PROJECT_DIR and FOAMX_PATH environment variables must be correctly set, which is done by running "source ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc". Are you sure to have run before running postinstall.sh?
If you are sure what message did you get?
Takuya
Old   February 7, 2007, 07:03
Default Thanks for the fast reply. ber
  #20
liamm
Thanks for the fast reply. berore i run postinstall.sh i am running
source ~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3/bashrc and the reply i get is
~/OpenFOAM/OpenFOAM-1.3/.OpenFOAM-1.3: is a directory.
OpenFOAM Windows Binaries in Sourceforge philippose OpenFOAM Installation 2 March 19, 2009 03:48
Installation using the precompiled binaries on Suse 103 pamdirac OpenFOAM Installation 1 March 9, 2009 03:05
Installation using the precompiled binaries on Suse 103 pamdirac OpenFOAM Installation 0 March 6, 2009 20:39
[OpenFOAM] ParaFOAM using binaries tj22 ParaView 3 July 11, 2006 12:19
Run FoamX ghazi OpenFOAM Pre-Processing 7 July 9, 2006 14:48
